TR4/4A Brake / Clutch Fluid for TR-4A
fpstude
I've always used Castrol GTLMA fluid for the brake and clutch system on our TR 4A. The Brake access cover says to use only Castrol Fluid. Castrol seem to be no longer available. What is the current recommendation?
Thanks,
Castrol was vegetable based, not pertrol based. Hence castor oil. My advice is DOT 5 after purge. Cannot know how "rubber" parts may react. They may have changed to an oil base to be like others. Hope this is some help.
LeT
I had the same problem in a car where I did not use silicone, but I am not sure what I did to fix it. I believe I was told LMA is the substitute and to use it because like you said plain Castrol is not around. I think LMA bottle even says synthetic I learned a lot from suppliers/parts places that sell only brake and clutch parts. Around here we have a couple plus they usually have a large selection of brake fluid types. The forum guys are smart but some of those general auto parts places are scary and terrifying.
steve
...I think LMA bottle even says synthetic...
As I recall Castrol won a legal battle that allows them (and anyone) to label a brake fluid (and other products) 'synthetic' since synthesis simply means 'the production of chemical compounds by reaction from simpler materials'.
Yeah, they sort of did for 'synthetic' what trailer parks did for the word 'estates'.
I only use DOT5 but that is a choice & opinion not universally shared.
I'm using Silicone DOT 5 in my Healey with 4-wheel discs. It's great for paint and cleanup, but I've always had a somewhat spongy pedal. Silicone captures air in the fluid which can be in there for ever.
When I converted, I cleaned the cylinders and blew out the lines with brake parts cleaner and compressed air. Replaced all the rubber parts in the calipers and masters as well as clutch system. It's not that expensive for the rebuild parts and I wanted to avoid any compatibility issues.
FWIW commonly available DOT 3 and 4 fluids have been OK in our systems for decades. I previously used NAPA DOT 4 because it came in quarts.
I’ve changed over to dot 5 as well and can’t tell any difference in pedal feel. Even if the pedal was a little less solid than before I think it’s a good swap considering the advantages.
Rut
Castrol is readily available, AutoZone, O'Reilly's and online. I always keep 2 qts on shelf. Prestone makes a DOT 4.
Yeah, Castrol brake fluid is still around,,,but it lost the LMA on the label and added the word "synthetic", which I believe it always was. Was there ever a 'natural' brake fluid ?
https://www.castrol.com/en_us/united-states/home/motor-oil-and-fluids/brake-fluids.html
The engine oil was and may still be available as castor bean oil and it smelled wonderful in two cycle engines.
http://www.off-road.com/dirtbike/tech/castor-bean-oil-fact-vs-fiction-54313.html
I finally broke down and switched to DOT5 silicone, just a few years ago..I couldn't tell any difference in the pedal.
When I lived in Sacramento I used a brake shop on 16 th street for my cars and such I do not remember name of shop just a hole in the wall place but knew a lot. They could be worth a call. Madflyer
Lin Brake/Clutch Fluid Austin Healey 11
S Clutch Fluid / Brake Fluid consumption Spridgets 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
richberman brakes/clutch fluid out top of brake reservoir Austin Healey 11
RAC68 BJ8 Brake/Clutch Reservoir Fluid Loss Austin Healey 14
Bruce_B Fluid for MC Brake and Clutch?? Synthetic--REgular Spridgets 4
F Brake and clutch fluid 73 TR6 Spridgets 9
BritCarFan Silicone brake and clutch fluid British Motor Corp 7
H BRAKE/CLUTCH FLUID Triumph 28
H Which Part of the Brake Fluid Canister for Clutch? Austin Healey 8
C T-Series Brake/clutch fluid MG 9
T reminder-brake & clutch fluid Triumph 16
tr6web Brake versus clutch fluid Triumph 14
S T-Series brake & clutch fluid MG 2
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
B Flushing brake/clutch Austin Healey 16
D TR2/3/3A clutch/brake pedal question Triumph 4
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
SD Bugeye Clutch and brake clevis and pins Spridgets 3
G Brake/clutch resevoid replaced do I have to bleed the system Austin Healey 9
vette Brake/Clutch Reservoir Austin Healey 14
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
M TR2/3/3A Brake/Clutch Reservoir Seal Triumph 9
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
K TR2/3/3A Brake and clutch MC housing.... Triumph 2
petnatcar GAS, BRAKE and CLUTCH PEDALS for a BT7 Austin Healey 2
D Brake/clutch lines Spridgets 14
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
A TR2/3/3A TR3 Brake / Clutch Resevior & Lines needed Triumph 2
Rob Glasgow Brake/Clutch Reservoir Lines Austin Healey 9
D brake /clutch pedals Austin Healey 2
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
I TR2/3/3A Clutch and brake pedal assembly problem Triumph 4
jlaird Brake and Clutch bleeding Spridgets 7
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
PatGalvin TR2/3/3A Brake and Clutch pedal to MC adjustments? Triumph 4
H master cylinder brake vs mc clutch Austin Healey 14
K TR2/3/3A Brake and Clutch MC pushrod/pedal bolt stops? Triumph 2
C Sealing Healey clutch fitting on brake reservoiur Austin Healey 13
Lukens More clutch / brake master cylinder questions. Triumph 7
Rut Brake and clutch pushrod Spridgets 1
