Billl, how are the floors coming along?
Yeah, good question TD. Where is Mr. Bill hiding?
Not the brown bottle I hope. The floors didn't push you over the edge I hope??
Nope. Been there, done that.
I finally got the wrong coating off the floors, and side walls, and rockers, and front foot panels...
I tested some POR15 on a small area and was not impressed. It went on like water, too thin.
Instead, since the metal was so clean now, I chose to coat the entire floor area with a PPG epoxy coating. (I've used it before) Goes on thick and fills all the seams. I got a semi-rigid seam sealer down and coated over that. I have to now re-tap all my bolt holes because the epoxy got in the threads. Half done with that. I'll get some pics tonight.
Bill,
Just pondering out loud. If you used the 2 part PPG
industrial grade epoxy coating, you probably should
let it fully cure out for 7 to 10 days before you apply
anything over it.
Depending upon what mil thickness you applied, you
might not need to put ANYTHING over it.
That is--IF you used the 2 part, industrial stuff.
When I read about your Crypty-ish floor nightmare,
I immediately decided I would go directly to epoxy
coatings for mine.
d
I guess you two really are Kindred Spirits, of sorts.........
Well, at least when it comes to floor pans.
Bill, POR 15 is very thin, but it does get as hard as a rock. The important thing is that you're happy with whatever you put on. And that your paint will stick to it.
Good luck,
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
S TR2/3/3A painting the floors of my tr3. Triumph 2
D Prepping Floors Before Installing Interior Restoration & Tools 6
D TR2/3/3A Patching, versus replacing floors? Triumph 15
maxwedge5281 healey floors Austin Healey 7
S TR2/3/3A new floors & removable transmission cover Triumph 3
drooartz MGB Finally some progress -- floors painted MG 4
B TR2/3/3A TR3 floors Triumph 13
KVH Rust on Car--Like floors or panels Triumph 2
1 GT6 1970 gt6 floors first look- not as bad I thought! Triumph 16
R TR2/3/3A New TR3 floors Triumph 39
MTribe TR6 LIGHT restoration of TR6 floors and chassis? Triumph 9
J getting someone to install my rockers and floors Triumph 14
J I pulled the trigger and ordered new floors Triumph 21
tony barnhill New Floors Racing 6
T Welding floors in a 1500. Who had it done? Spridgets 3
E MGB Ready to cover floors 77 MGB MG 8
Carlbanan56 MGB Stud coming lose MG 7
AngliaGT MGA Barney Gaylord Coming to Roanoke MG 0
sparkydave Zenith auto choke coming loose Spridgets 2
S TR2/3/3A Smoke coming out of crankcase vent? Triumph 21
sparkydave Zenith auto choke coming loose Spridgets 3
Trevor Jessie Any of you Spridget guys coming to MG2016 in June? Spridgets 3
7 brake warning light coming on Other Cars 5
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
jaegzie Maiden voyage coming up tomorrow for my bugeye. Spridgets 16
P TR6 tr6 coming on market Triumph 2
Martinld123 Water Coming Out of Exhaust at Start-up Austin Healey 7
Lukens TR2/3/3A The hits just keep coming Triumph 2
JPSmit Ms Triss is coming home today Spridgets 7
JPSmit MG 2015 - anyone going [or coming] repost from MG board Spridgets 1
Got_All_4 TR2/3/3A Paint code / formula coming to a head Triumph 28
B no fire coming out of coil Sunbeam (Rootes) 4
PAUL161 T-Series TF is slowly coming together MG 90
Geo Hahn TR4/4A Stumble Coming Off idle Triumph 9
Sarastro T-Series Coming down the home stretch... MG 19
DNK TR4/4A Irene's car coming to America ;] Triumph 5
MY66AH Coming to a Snap On Calendar near you. Spridgets 9
toysrrus TR2/3/3A Coming back soon. Triumph 8
dougie US Championship Winning Healey Coming to Auction Austin Healey 5
H Another big Healey coming my way? Austin Healey 3
Superwrench My BT-7 coming back to life ! Austin Healey 12
Mickey Richaud MGB New MGB Book Coming MG 3
duffy THE OLYMPICS ARE COMING Other British Cars 1
Pythias Portland Autojumble Coming Up. Spridgets 8
J Spitfire New Spitfire based Kit Car coming Triumph 28
Johnny Austin Healey in a new movie coming out... Austin Healey 0
longbridgehealey interior is coming along Spridgets 31
CZ_Dave They are coming out of the woodwork! MG 6
DrEntropy Just learned FIAT is coming! Other Cars 28
