    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
assembling doors
zimasprite
Do those out there that have put in door glass/assembled doors before, is it alright to put all the hardware on the door but not the glass. I don't have the waist seals/felt seals yet, but would like to get the rest of the stuff together. Also, I don't have door locks. Can they be fit on after all the latch mechanisms go on...etc. I don't want to install all the stuff then have to take it all off to get the locks on.
Car is a 1968 MK IV Sprite
Thanks again...Drew
Speedy_Pete
It's a lot easier to fit the glass when there's not too much else on the door, as you have easier access. Wait until you have all the parts to reassemble it, as you can guarantee that the one piece you are waiting on will require most of the bits off the door before fitting...
Just looked through the Lindsay Porter book, in disassembly sequence the glass is almost the last thing off the door, so reassembly would put it almost first.
Z
zimasprite
kinda what I figured, but it's hard not to get excited and want to put it all back.........you know, then to bang up the new paint job when you have to take it all apart after wrestling with it because it's all back!!
Thanks much - Drew
man, I had a hard time getting the drivers door to line up correctly....but it's ok. Not perfect gaps, but it will suffice.
Speedy_Pete
Don't sweat it, I've yet to get mine lined up: I've been waiting for a full day to get in the garage and sort them. Already spent a couple hours on them, but at least it's one of those jobs that only need doing once!
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
R TR2/3/3A Re-assembling 1954 TR-2 Engine Triumph 25
R TR4/4A Assembling the interior - dash support and radio plate screw holes don't match up Triumph 4
K TR2/3/3A When assembling a release bearing to the sleeve? Triumph 4
J Tips on Re-Assembling Lenses/Gaskets? Austin Healey 5
BN6_2197 Question on assembling BN6 hood Austin Healey 6
drooartz Assembling rear hubs -- do I have this right? Spridgets 5
algot1901 Putting the doors on Other British Cars 11
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
Healey Nut Aluminum doors Austin Healey 7
S TR2/3/3A OMG problem—the doors are too tight Triumph 12
H Healey Doors Austin Healey 5
S TR2/3/3A body work on doors Triumph 5
R Bugeye doors Spridgets 11
Jim_Gruber Adjusting Spridget Doors Spridgets 4
P Doors won't stay open [1959 100-6] Austin Healey 16
bighealeysource Best way to adjust doors Austin Healey 9
BlueMax Doors Finley Hung Spridgets 11
BlueMax Ready to hang doors! Spridgets 9
DanLewis Bugeye parts lot: hood, doors, seats, and more - $650 [NFI] Spridgets 0
DanLewis MG Midget doors, hood and trunk $150 [NFI] Spridgets 2
B TR2/3/3A I'm going to try some lead repair. Can I do this to my doors? Triumph 9
B WOO HOO! Doors are finished! Finally got the panels on, door pulls, handles & cranks Spridgets 9
drooartz MGB Making some progress with the doors MG 5
J New wood pieces for the doors Triumph 9
N BN1 Rockers and Doors Austin Healey 11
Bremer TR2/3/3A TR3 half doors Triumph 11
A TR2/3/3A TR-3A rubber trim on doors Triumph 7
T TR2/3/3A TR3B doors Triumph 3
A Adjusting BJ8 Doors Austin Healey 5
R 100-4 doors Austin Healey 3
A TR2/3/3A 60 TR3A doors latch parts Triumph 2
W any tips on removing doors on 100-6 Austin Healey 11
L Doors slam shut Austin Healey 16
hondo402000 Painting, doors done! Triumph 7
C What rattles your doors? Triumph 5
hondo402000 TR6 REskinning TR6 Doors Triumph 31
K MK I / II doors vs MK III Triumph 7
S RUST INSIDE DOORS ON 1970 E-TYPE OTS Jaguar 2
S Rust inside doors Jaguar 4
QuickSilver Midget Doors Spridgets 10
chicken Are BJ7 doors the same as BJ8 Austin Healey 8
JPSmit Progress - doors Spridgets 12
JPSmit Doors are on but... Spridgets 5
toysrrus `87 Alfa Romeo Milano Doors For Sale: Other Cars 2
1 doors and door and frames MG 4
1 Is there a cure for rubbing doors? Spridgets 4
T Wedge Anyone have a set of TR7 doors? Triumph 4
C Will older doors/sliders work with MkIII Tub/Top? Spridgets 23
