Another silly Carb Question [piston spring?!?!?!]
martyc
Hmmmm...When I rebuilt my '52 TD carbs recently, there were no "piston springs" in them. The carb rebuild video that I used as a reference said that some carbs do not have piston springs (didn't mention which), so I just figured that my '52 didn't use piston springs. /ubbthreads/images/graemlins/thumbsup.gif
Anyway, I was browsing my local MG club's tech tips site this evening and found that there is a piston spring number (AUC4587) listed for the 1952 carb. See:
https://www.keystonemg.com/tech/carbs-year.html
/ubbthreads/images/graemlins/eek.gif Does this mean that there should be piston springs in my carbs? I'd hate to leave out a critical component since I've gone through the trouble of rebuilding them. And I'd rather get the springs in now if they're needed (while the carbs are on the bench).
Thanks for any insight!
Marty
Some guys remove the springs to quicken throttle response.It also slightly effects the piston height, thus the airflow and mixture, during operation. You can do the rebuild without them, they are easy enough to put in later. Test drive it and if it seems to stumble on takeoff no matter how much you adjust the carbs then add the springs (and you can play with the weight of oil in the dashpots).
I bet there is a TD guy in here somewhere that can give you a better answer. this is more of a general SU thing.
Depends on the carb. Early SUs had heavy pistons and no springs. The large diameter of the piston on the early springless kind is solid. Later models are recessed - like a bowl.
[ QUOTE ]
[/ QUOTE ]
My pistons are solid, not recessed. Thanks!
timbn2 Another silly Noob question on British tools... Austin Healey 6
K TR2/3/3A Another odd break down story Triumph 1
waltesefalcon Another one followed me home Other Cars 4
mezy Another panther Lima Other British Cars 27
Y MGB Time for another puzzle piece.... MG 5
P Another beautiful Sunday Spotted 0
L T-Series Another brake prob. ? MG 12
T I added another TVR to the fleet. TVR 10
Rut MGB Another sad day! MG 10
T General TR Another trans popping out of 2nd Triumph 14
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
JPSmit you won't likely see another Spridgets 4
D TR2/3/3A Another mystery part(s) Triumph 2
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Another brake bleed question....... Triumph 17
Sarastro Another SoCal TR3 Spotted 1
7 Wedge Got another one! Triumph 3
Sarastro TR4/4A Another 50K TR4A Triumph 16
D TR2/3/3A Another mystery part Triumph 8
HealeyRick GT6 Another Satisfied Customer Triumph 3
nichola TR6 Another TR6 back on the road Triumph 1
Sherlock Another cruise night, more interesting British iron Spotted 2
D TR2/3/3A Another Carb question. Triumph 22
Healey Nut Another Use for J-B Weld Austin Healey 5
D TR2/3/3A Have exchanged one leak for another. Triumph 10
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
D TR2/3/3A Another mystery part..or two Triumph 14
John Turney Another Article to Criticize Austin Healey 5
tr6nitjulius TR6 TR6 made another list! Triumph 5
Lin Another Trafficator/Control Head Question Austin Healey 10
Rob Glasgow Can I find Another one as Good? Austin Healey 4
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Editor_Reid Bought Another One Austin Healey 14
tr6nitjulius General TR Triumphest 2019 another one bites the dust! Triumph 2
pkmh Yet Another Oil Question! Austin Healey 8
P TR2/3/3A Another Differential Question Triumph 22
Bob Claffie Spotted another AH Spotted 0
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
jackq Another building full of cars available. Other Cars 0
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
Lin Another trafficator issue Austin Healey 8
B Another OD question Austin Healey 32
Elva164 Finally did another onboard video! Racing 4
Sarastro TR4/4A Another milestone: first engine start Triumph 8
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
Y MGB Another question - this time on seatbelts.... MG 2
PC another one bites the dust... Restoration & Tools 0
