Alternator wiring connector, Sources?
tweety
'79 midget.
Putting in a new Alternator.... While I'm at it, I would love to change out the plastic connector and terminals that connect the car to the alternator. The plastic connector is in kind of tough shape. The terminals are worse.
Can't seem to find it with the usual suspects.... Anyone have some tips?
You know.... that looks similar to many Bosch units. Try the local autoparts store.
tweety
tweety
That sure looks like it. Gonna order me up one now.
Thanks.
As I've said repeatedly, I could never keep this little machine running without the help of everyone on this board!
Gotta give Basil some more $ to show my appreciation
T TR6 Alternator wiring Triumph 6
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
apbos Positive Ground Alternator wiring. Spridgets 9
BoyRacer Wiring question for alternator conversion Austin Healey 3
G TR2/3/3A Wiring ammeter with the British Wiring alternator conversion. Triumph 13
D TR2/3/3A Alternator wiring diagram Triumph 7
M wiring of alternator Austin Healey 3
T TR2/3/3A Question on wiring Denso alternator through ammeter Triumph 4
K TR2/3/3A Triumph Rescue/British Wiring Alternator Kit Triumph 10
N Spitfire alternator wiring question Triumph 1
K TR2/3/3A Alternator from British Wiring Triumph 12
mgedit TR2/3/3A Alternator Wiring for TR3 Triumph 18
Lukens TR2/3/3A Help wiring convertion alternator Triumph 6
B TR6 Does a 75 amp alternator require a wiring upgrade of any kind? Triumph 3
bash Alternator wiring question Triumph 5
D MGB mgb 77 alternator wiring. MG 2
Patrick67BJ8 Alternator Conversion & Regulator Wiring Help Need Austin Healey 11
H TR4/4A tr4 alternator wiring Triumph 4
I Alternator wiring Austin Healey 5
E BE Alternator Wiring Question Spridgets 5
T TR4/4A TR4A alternator conversion wiring question Triumph 28
G MGB Alternator wiring "71 MGB MG 4
bill_powell Alternator Conversion / Wiring Spridgets 13
kodanja Alternator upgrade wiring? Triumph 30
kyreb1862 MGB 77 MGB Alternator Wiring MG 4
B TR6 71 TR6 Alternator Wiring Triumph 2
Webb Quick Alternator Wiring Question Triumph 3
Airfix TR6 TR6 alternator wiring? Triumph 5
D Alternator Wiring MG 7
C Wiring Check. Alternator wiring. MG 19
LastDeadLast Bosch Alternator Wiring Question Triumph 1
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
