AH 3000 BJ series driver's side mirror
davidb
Evening gents,
I'm trying to track down (with little success thus far) a driver's side mirror for my BJ8 that I can somehow attach without having to drill holes. The fender mirrors that I now have on the car were mounted (probably by the original dealer) halfway down the fenders and are pretty ineffective. I found a nice little unit for my BT7 which mounts on to the big screw that secures the windshield pillar, but that won't work on the BJ8, since the windshield uses a different system of attachment.
Anybody have any suggestions?
With thanks
Dave
Hi give XK's unlimited a call.They have quite an assortment of car mirrors--Fwiw--Keoke
Have a look-see at this thread: https://www.britishcarforum.com/bcforum/u...ques#Post697970
I'm planning on ordering the quarter light style for our BJ7 (Fran and I went camping for 5 days in ours last week; whenever I had to change lanes to the left, she did the 'shoulder check' for me)as there is one heck of a blind spot on the driver's left.
Doug
My thanks to Keoke, Roger, Randy and Doug for comments and suggestions on this one. I think the quarter light clip-on is the answer.
Doug - the previous thread on the subject was particularly helpful...
Cheers to all
Dave
I bought those quarter lite mirrors from Moss. They would not stay on the windwings. I also could not get them to the right angle without the edge of the mirror hitting the windwing. I am not sure if another supplier might have better quality, but mine are now sitting on a shelf of "mistakes".
Jerry
bj8
Jerry,
The clamp should have a small thin plate that goes between the screws and the glass. If screwed firmly, it should stay in place on the vent glass.
By the way, the mirror does not have to positioned horizontal as in this photo. It can be turned vertical. Maybe that will help with clearance with the window frame.
Or you could enlarge the bolt hole out farther on the post. I'm assuming you only need a millimeter or two. Place a stainless washer on each side to cover the enlarged hole you made, if it shows. If the bolt moves in the larger hole, press a shim in. Just an idea.
Hi Dave,
The factory put driver's side mirrors out on the wings.
https://www.britishcarforum.com/bcforum/ubbthreads.php/galleries/617887/A_couple_of_laps_around_VIR
I was also very nervous about the blind spot(s) with the top up.
I exchanged the factory mirror with a convex replacement that
looked the same as the original factory mirror. I also added
the same type of convex mirror on the passenger side in the same
location as the factory driver's side mirror.
Result... No more blind spots plus I didn't have to fill the hole in the wing where the factory mirror is. I guess it is a matter of preference.
Ed
I exchanged the factory mirrors with a convex replacement.
Well that can help some ED but it introduces a new problem:
What you see in the mirrors is not spaced correctly distance
wise from your car.--Keoke
Ed_K said:
Hi Dave,
Ed
I don't believe the factory installed wing mirrors.
I believe they were dealer installed.
Cheers,
Roger
Hi Roger,
My heritage certificate has the following listed after item #
11. Details of Factory Fitted Equipment ...
Wire wheels, Laminated windscreen, Adjustable steering column,
Overdrive, Heater, Wing mirror, Cigar lighter, Octagonal wheelnuts, Black tonneau cover, Roadspeed tyres.
My car was originally sold to a company in England that drove it around a few miles and then flew it into the U.S. for the original owner to pick up at the airport. All of this was to avoid the large duty ( tax ) on a new car. So maybe BMC didn't put mirrors on if they were going to ship the car via the normal means ( on a ship ) ? I don't know that, just guessing at the possible reason for mine having the factory installed wing mirror.
My heritage certificate also has this ..
9. Destination ( Dealer ) ... Personal Export Delivery to Philadelphia, USA
In the picture,
the original English license plate is on the front of my car. I had to repaint it but that plate has been on it since it was sold by BMC to this " import service company " working for U.S. G.I.s in England in the 60s.
I'll bet others on the forum have a similar car history.
Anyway, It appears to be a factory installed wing mirror per my certificate.
Ed
:savewave: Roger!!!
We now have at least two heritage certificates that say they did--KEOKE
AUSMHLY said:
Hi Ed,
Good thing I wrote, I believe...
Now I'll have to find what publication that was written in.
Ed, Keoke, and all others who read this post.
I agree, the heritage certificate has the last say as to what was available from the factory.
When I wrote, I believe, I was referencing what I read in a restoration guide and a restorer's guide.
1. Authentic Restoration Guide, Austin-Healey 100/100-6/3000 by Gary Anderson and Roger moment.
Page 166, "Fender mirrors were never fitted from the factory on big Healeys. A driver-side door mounted external mirror could be ordered as a separate option, and was generally mounted when the owner specified a factory-luggage rack. However, emulating the Jaguars, many Healeys were fitted by the dealer or owners with fender mirrors mounted on the front fenders. There was no standard location for mounting these mirrors."
2. Original Austin-Healey 100,100-Six and 3000 The Restorer's guide by Anders Ditlev Clausager.
Page 86, "Wing mirrors (one or two) became available, originally either round or the trapezoidal-shape 'boomerang' Type. An external luggage rack could be fitted, and if this was supplied factory-fitted a wing mirror on the driver's side was also always added. The luggage rack and wing mirrors may also have been available for the 100-six models. A cigar lighter and a locking petrol filler cap were offered on the 3000 models from the start."
Cheers,
Roger
Well. I think the only sensible and rationale way to settle this discussion is with pistols at 20 paces at dawn.
Cheers
Dave
"I love the smell of WD-40 in the morning"
This thread also has more information.
https://www.britishcarforum.com/bcforum/ubbthreads.php/topics/500153/1
The fact that heritage certificates and the parts manuals agree, should show that the mirrors were available from the factory.
The restoration guide and a restorer's guide as references are excellent, but they should not been seen as definitive.
The concours guides are updated every year as new information is obtained, to take care of just these issues.
Duane
’58 BN6
Well. I think the only sensible and rationale way to settle this discussion is with pistols at 20 paces at dawn. :shocked:
:savewave:
Well Dave, since this is a classic issue I think it should be settled with swords or the Heritage certificates.-Keoke- :laugh:
:savewave:ROGER!!
The restoration and restorer's guide you referenced are excellent, but they should not be seen as definitive. :iagree:
The concours guides are updated every year as new information is obtained. These updates are usually derived from the car owner's Heritage certificate to take care of just these issues. :yesnod:
Thanks to Duane-----------Keoke- :driving:
:savewave:ROGER!!
Keoke- :driving:
I agree guys. As I stated in my prior post... :rolleyes:
"Ed, Keoke, and all others who read this post.
I agree, the heritage certificate has the last say as to what was available from the factory."
I was just sharing what's out here in print, in case this come up in another post.
Wadjathink, clear enough this time Keoke... :savewave:
You seem to have me in your crosshairs :square:
Cheers my friend :thirsty:
Roger
Bruce Bowker Book -Austin-Healey 100 & 3000 Series Austin Healey 0
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R 3000 Heater Valve Austin Healey 4
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Bruce 3000 Rally Grille Installation Austin Healey 5
J 3000 Rear Seats Austin Healey 6
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
M Engine Stand for 3000 Motor Austin Healey 7
D Healey 3000 BT7 rear panels Austin Healey 0
BoyRacer Mystery 3000 Engine Block Austin Healey 2
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
AUSMHLY For Sale - 1990 Big Healey, 3000 MK3, HMC Mk4 Austin Healey 2
Zitch For Sale AH 3000 Engine For Sale: $2500 Denver, CO area Austin Healey Classifieds 0
C Rough-Running 3000 Austin Healey 29
E 3000 Healey Door Checks Austin Healey 1
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Editor_Reid In Search Of: AH 3000 BT7L 8921 Austin Healey 0
Z 3000 Front Wheel Bearings Austin Healey 3
Guido36 Custom-Bodied Austin-Healey 3000 Coupe Austin Healey 17
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
Guido36 Healey 3000 cutaway display engine Austin Healey 12
pbraun For Sale Healey 3000 transmission Austin Healey Classifieds 8
O HD8 carb on Healey 3000 Austin Healey 62
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
G 1960 3000 BN7 Top Help Austin Healey 0
C Austin Healey 3000 in Modsports Austin Healey 4
C 1962 Healey 3000 Mark II Steering Box Austin Healey 9
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
maxwedge5281 Front Shroud Differences: 3000 vs. BJ8 Austin Healey 5
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
M 3000 BJ8 Door Seals Austin Healey 9
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
A AH 3000 rear disc brake conversion Austin Healey 28
