A Timely Discovery
dougie
In a promise to myself to drive my '65 BJ8 more this year, I decided to inspect the brakes and R & R the fluid. Starting with drivers right rear, I began to loosen the bleed screw and it literally feel to the garage floor. Not just the screw, but the entire cast aluminum portion of the brake wheel cylinder it threads into. After catching all the fluid that started to pouring all over the floor, I removed the brake cylinder and inspect it closer. From the attached picture you can see corrosion in the crack which indicates it was there for a while and may have let go at anytime......Yikes!
There's my question. Moss sells 2 types of replacements, an original Girling at $116.95 or an "aftermarket" version for $32.95. Any suggestions or experience with these? Or even an other vender you'd suggest.
Many Thanks,
Over-tightened bleed screw; I've come across that before__even on BMWs.
Not saying that you had anything to do with it, but some people don't realize that 1.) it doesn't take much torque to seat the tapers to seal; 2.) it doesn't take much more torque to fracture (if not completely break) the aluminum casting.
If a little twist of the wrist isn't enough to keep a bleeder from weeping, it's time to replace the cylinder.
Good catch Dougie; is a twin circuit master cylinder looming in the back of your mind...? I've been considering it, but haven't acted upon it yet.
Frankenhealey
IMHO if you use your Healey in anger then this is a no-brainer safety upgrade. However it's just as valid for cruising down Main Street. Catastrophic brake failure is bad under any circumstances and as Dougie has shown it can be lurking there just waiting to happen.
3798j
Bronze
dougie said:
Thanks Jay, placed my order tonight and hopefully should be ready for a drive next weekend.
My fingers are crossed that there's no disappointments.
BigGreen
Could it be that the bleed screw puts (to much) tension on the cylinder
Not sure, but maybe a screw like these will prevent that ...
https://www.speedbleeder.com/
I think your daughter is worth the effort of making the car safe
Hans
dougie
dougie
Thanks Hans, I use speed bleeders on my race Healey and was thinking of doing the same on my BJ8. The replacement wheel cylinder arrived today from Rockauto LLC., NY and the Italian made part looks like good quality.
PeterK General TR Timely memory of a time capsule left in my 3A Triumph 19
J For Sale Land Rover Discovery workshop manual 1995-1999 models, 4.0, 4.6 V8 & BMW diesel Other British Classifieds 0
J Who are the customers of Discovery?? Rover / Land Rover 0
sparkydave Odd discovery, but still ran OK Spridgets 1
R 2003 Discovery restoration story Rover / Land Rover 11
M BN1 Overdrive discovery Austin Healey 12
pkmh Interesting little jack stand discovery, "Drednaut" Austin Healey 0
S Wedge tr8 starter swap with a 2000 discovery starter Triumph 7
Rut Weekend discovery Spridgets 6
B Heater discovery Spridgets 16
H Shocking Discovery and Conclave Bound Austin Healey 0
R Important Discovery MG 6
T Interesting discovery on the carbs today Spridgets 15
sjuengst Cockpit heat discovery Austin Healey 7
mrsprite Bugeye on Discovery HD Theater show 'Wreck Rescue' Spridgets 3
5 Discovery alarm issue... Rover / Land Rover 3
pjsmetana TR4/4A TR4 on TV - Discovery HD Theater Triumph 3
M TR2/3/3A TR3 camahaft discovery [Kas Kastner D Grind] Triumph 13
jaegzie Rather disgusting discovery Spridgets 3
jhorton3 Thinking Of A Discovery SE7 Rover / Land Rover 5
Tim Tucker TR4/4A TR4 on Discovery HD Theater Triumph 0
E 2004 Discovery Oil Pump Faailure Rover / Land Rover 3
kennypinkerton Problems with Discovery? Rover / Land Rover 5
J Bugeye on Discovery Channel Spridgets 14
W An interesting discovery Spridgets 39
texas_bugeye Dizzy vac question [NEW DISCOVERY] Spridgets 2
G Ralph Lauren's car collection on Discovery Triumph 0
BritCarFan 1998-2002 Land Rover Discovery Rover / Land Rover 1
martx-5 TR2/3/3A TR3 Project Discovery Triumph 9
W 1995 4.0 SE/2002 Discovery II Trailer Hitch Rover / Land Rover 1
S Another Alpine race car discovery Sunbeam (Rootes) 2
Mwalsh Top Gear on Discovery! Other Cars 16
JPSmit Very Cool Discovery Spridgets 7
