Cockpit heat discovery
sjuengst
Notwithstanding the 3000's reputation for heat in the cockpit, I thought mine was unusually bad. Driving two miles would result in a uncomfortably hot cockpit. It felt like hot air was blowing directly on my legs! Well, I finally found some time to poke around under the hood and discovered that the fresh air hose had disintegrated directly over the exhaust manifold. It was sucking the hot air right off the manifold and blowing it straight onto me! That explains it. :yesnod:
A new hose is scheduled to arrive today, so I hope my next drive is more comfortable. :driving:
stu
PS: I also have some EZ-Cool insulation to install, but that'll be a rainy-weekend project sometime in the future.
Johnny
Well Stu, looks like you discovered your problem. Another common source of heat in AH's is from around the transmission tunnel to firewall seal. If not aligned properly it'll melt your socks.
richberman
Talking about the transmission seal, I have one where the rubber is separating from the metal frame. What's the best way to reconnect it?
rich
Keoke
rich
Contact cement-----Keoke
Jerry
Also check the door seal. there is a force of air that comes through there if the seal is not good.
Jerry
BN4
BJ8
Rob Glasgow
A great way to check the entry points for heat is to remove the carpets from the driver and passenger floor and the carpet on the transmission tunnel. Then take a drive. You will be able to feel the hot air coming in through any holes or gaps. An assistant would be helpful.
When I did this several years ago, I was amazed at how much hot air came through a small gap between the transmission cover and the floor boards. A couple of small cubes of foam insulation stuffed in these gaps made all the difference.
Patrick67BJ8
A new hose is scheduled to arrive today, so I hope my next drive is more comfortable. :driving: A long, long time ago when original "foil" lined hoses were nowhere to be found we installed dryer vent hose. Dryer vent hose was paper thin white plastic crap woven with wire. We went from bad to worse and were none the wiser for doing so.
Patrick
stu
Galen
Member
I used a lazer temp gun with digital readout to take temp readings after my car was good and warm. With bare metal I read 132 degrees at the foot well, drivers side. I installed the insulating product that Patrick refers to above and it reduced the heat by 15 degrees. That product also did wonders for reducing engine and road sound as well.
Galen 62 tri carb
NutmegCT TR2/3/3A TR3 cockpit - summer heat! Triumph 12
TexasSprite Heat proofing the bugeye cockpit Spridgets 10
M TR2/3/3A Heat in the TR3A cockpit Triumph 9
mjobrien Cockpit Floor Heat Shield Austin Healey 4
Stewart Heat proofing the cockpit MG 23
R Wanted Cockpit surround Spridgets Classified 1
bugedd Wanted: Bugeye cockpit surrounds Spridgets Classified 7
maxwedge5281 Cockpit Surround Molding Austin Healey 4
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
K For Sale TR3 Cockpit Trim ...N/A at The Big 3 Triumph Classifieds 0
L 100 ID plate inside cockpit Austin Healey 10
K TR2/3/3A Gluing vinyl to cockpit capping? Triumph 5
B Prince of darkness conquered in the cockpit Austin Healey 17
K TR2/3/3A Cockpit quarter rails? Triumph 11
trotti Aluminum cockpit trim Austin Healey 0
C TR2/3/3A Gas tank cover in cockpit area Triumph 3
Rob Glasgow Re-anodizing cockpit surrounds Austin Healey 3
A TR2/3/3A Cockpit capping Triumph 7
Tinkerman TR2/3/3A Cockpit capping Triumph 11
D Door Cockpit Trim Austin Healey 11
J Aluminum molding in cockpit Austin Healey 9
T TR4/4A Fabricating a metal panel in between the fuel tank and cockpit Triumph 6
PHerder ? about the rear section of the cockpit on a 1966 Sprite MkIII Spridgets 9
S Mk III Sprite cockpit surround - trying to recover Spridgets 9
Griz Cockpit Insulation Austin Healey 13
R Interior cockpit coatings and insulation Triumph 12
Lukens TR2/3/3A TR3 fumes in cockpit. Triumph 4
S TR2/3/3A tr3 leather cockpit capping dog leg Triumph 4
S TR2/3/3A leather cockpit tr3 Triumph 2
O TR2/3/3A TR3 Cockpit Cappings Triumph 1
bighealeysource Looking for specific # cockpit surrounds for BN2 Austin Healey 5
R cockpit/underbody paint Spridgets 5
I TR6 TR6 most common source of leaks into cockpit? Triumph 7
Michael Oritt Sheet metal for cockpit Racing 4
60Bugeye Polishing Cockpit Surround and Window Pillars Spridgets 41
bigjones Exhaust stink in cockpit Spridgets 56
ekamm Securing the cockpit side fuel tank closeout Triumph 2
jvandyke vinyl trim on cockpit surround Spridgets 5
G Cheap, quick cockpit cover Spridgets 1
T Rear Cockpit Surround Molding 1973 Spridgets 2
6 Cockpit Trim Q's Austin Healey 3
S Installing 3 pc. cockpit chrome. [b]I need help[/. Triumph 5
RickB Cockpit surround? Spridgets 26
W Polished cockpit trim Spridgets 18
B New Canvas Cockpit / Cage Cover Spridgets 13
CraigLandrum TR2/3/3A TR3A Fiberglass cockpit capping woes Triumph 3
TR6oldtimer Slowly getting there,cockpit painting nearly done Triumph 11
