Wedge tr8 starter swap with a 2000 discovery starter
sabot
hi guys, long tome no post. sorry.
ok, i know there have been posts about doing this swap, but my quick question is, on the tr8 starter there are 3 small wires. 2 are conected together on one side of the soliniod, and 1 wire by itself on the other side.
the discovery starter only has one spade connector on the solinoid.
can i connect all 3 wires to the one spade?
thanks tom
tr8todd
You should have 4 wires all together. One big brown one from the battery to the stud, one small brown one from the stud to the alternator, a white and red wire that goes from the starter relay to a spade terminal, and a white and yellow that goes from a spade terminal to the ballast resistor. This wire supplies 12 volts to the distributor during starting only. The rest of the time it gets something like 9 volts. You could splice the two small wires together since they are only receiving power when the key is in the crank position. I just looked at my stash of small Rover starters, and I noticed that one from a 97 has two spades. First time I noticed one like that, so I'll have to do a little research to figure out why.
S
sabot
on the tr8 starter solinoid itself, there were two small screws, on one side
are the letters, IGN. (ignition?) on the other side no letters. i think the single wire came off the ignition side and the 2 wires that were connected together came off the other side, i think these go to the ballast resistor?
and yes on my rover starter with the single spade, can i connect them all together?
tom
tr8todd
Without knowing what wires you have or where they go, I'm not comfortable telling you what to do. My post above tells you what is suppose to be there and where they go. Good luck.
DNK
Some pics of mine
S
sabot
here's a picture of the starter from my 8, and the starter from the discovery i want to use.
the starter off my 1980, carb. a/c car, had 2 small screws on the solinoid, on one side it had a single wire that was marked IGN. for the ignition. On the other side it had 2 wires on it, that go up to the ballast, that silver box thing in front of the car by the fans.
on the discivery starter all it has is a single tab, can i hook all 3 small wires to that tab? i'll try a picture.
thanks tom
S Wedge TR8 starter solenoid details? Triumph 3
S Wedge TR8 Starter wiring help needed Triumph 18
S Wedge TR8 starter dead spot? Triumph 26
V Wedge tr8 starter installation question Triumph 11
JFS Wedge TR8 Starter Wiring Triumph 4
T Wedge TR8 Gear reduction starter Triumph 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
P Wedge Starting problems TR8 Triumph 3
tr6nitjulius Wedge Rare TR8 Triumph 0
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
Hamish Racing TR8 IMSA GTO around Spa Racing 0
MadMarx Wedge Dijon 2019 - Triumph TR8 IMSA GTO Triumph 0
MadMarx General TR Spa Summer Classic 2019 - TR8 IMSA GTO Triumph 1
MadMarx Brands Hatch - Triumph TR8 IMSA GTO Racing 0
MadMarx General TR Brands Hatch - Triumph TR8 IMSA GTO Triumph 0
MadMarx Wedge The IMSA TR8 is ready to go again Triumph 7
MadMarx Wedge IMSA TR8 video with some roar Triumph 0
MadMarx Triumph TR8 at Spa Racing 0
MadMarx Le Mans - YTCC - Triumph TR8 IMSA Racing 1
B Gold TR8 Waxhaw N.C. Spotted 2
MadMarx Wedge Canadian Group 44 TR8 at Hockenheim Triumph 2
MadMarx Wedge TR8 IMSA at Le Castellet Triumph 1
J Wedge TR8 research before purchase Triumph 16
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
S Wanted TR8 with blown motor or no motor Triumph Classifieds 0
T Wedge Triumph TR8 for Sale - 1,020 miles Triumph 3
S Wedge tr8 front end Triumph 0
S Wedge Tr8 manual Triumph 2
S Wedge Need help with TR8 no spark Triumph 7
MadMarx Wedge IMSA TR8 goes on Salzburgring Triumph 6
Rut Wedge TR8 for sale Triumph 1
MadMarx Spa Summer Classic - IMSA TR8 Racing 0
MadMarx Wedge Spa Summer Classic - IMSA TR8 Triumph 7
B Wedge tr8 oil pressure switch number needed Triumph 3
G Wedge TR8 Classified? Triumph 0
G Wedge New to me TR8 Barn find Triumph 8
MadMarx Wedge IMSA TR8 - a recent photo Triumph 3
MadMarx Wedge IMSA TR8 - Spax on the rear axle Triumph 3
W TR8 brake aclipers on a Spridget Spridgets 38
MadMarx IMSA TR8 on the NĂĽrburgring Racing 3
MadMarx Wedge IMSA TR8 is racing Triumph 7
tr7andtvr Wedge TR8 Rotor Specs? Triumph 0
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
tr7andtvr Wedge TR8 calipers? Triumph 3
tr7andtvr Wedge Tr7, Tr8 or SD1 3.08 rear needed.... Triumph 25
Mickey Richaud General TR TR8 Folks Triumph 0
T Wedge TR8 parts car Triumph 3
philman Wedge Tr8 on local craigs list Triumph 11
