4.2 Liter XJ6 Intake Manifold Removal
Michael J.
I have a leaking Head Gasket on an 87 XJ6. After removal of the nuts from the six studs for each double cylinder intake and water jacket mount, is there an easy way to get the gasket to come loose so that the intake can be removed?
No... Take a large soft hammer and knock the manifold up and down, and eventually it will break loose. Unless you have a compelling reason to remove it, just pull the head with the manifold attached.It gives you something to grab on to as you weasel the head up the studs.
Excellent advice!!!
I ended up loostening the manifold by placing a short length of 2 X 4 against the manifold and stiking it with a sledge hammer. It took three blows to loosten the gasket, after which I was able to work it up and down as described by jessebogan. It would not come loose even with a 2 ton bottle jack pushing up on the manifold from underneath until after I struck it with the 2 X 4 and hammer. The gasket was brittle with age, but remained in one piece after the manifold was removed. I did not see any reason for it to have been stuck so well.
On the fuel injected cars, the manifold extends out about 12 inches and hangs down about 6 inches. It was too bulky to leave in place.
M 4.2 Liter Engine Serial Number in a Series III XJ6 Jaguar 2
M Overflowing R/H Gas Tank 87 XJ6 4.2 Liter Fuel Inj Jaguar 6
Boink 1924 Bentley 3 liter "Speed" model Other British Cars 12
aeronca65t Darracq 25.5 liter Other Cars 5
J Another pic of 2 liter Chevron Other British Cars 1
PAUL161 2 liter MG engine? MG 19
Editor_Reid Replacement Gearbox for 3.5 liter V8 Triumph 6
T Wedge 4.9 liter in the TR8 finally Triumph 7
M Series III XJ-6 4.2 Liter Cylinder Head removal Jaguar 7
Mickey Richaud 3.5 Liter Fuel Options Rover / Land Rover 11
P A pair of Van Den Plas 4 liter cars. Other British Cars 3
R For Sale For Sale 1990 Jaguar XJ6 Jaguar Classifieds 0
E 1996 XJ6 Jaguar 1
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
W XJ6 Series I bumper swap to Series II Jaguar 0
V 89 XJ6, How to adjust front camber? Jaguar 2
A For Sale 1986 jaguar xj6 Jaguar Classifieds 0
S XJ6 Mk1 clutch slave question Jaguar 0
SherpaPilot Wiring Harness for XJ6 Jaguar 1
JPSmit So we are in the England portionXJ6 Spotted 14
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
C tachometer for XJ6 Jaguar 0
Marvin Gruber XJ6 engine swap into XK 150 Jaguar 4
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
krswen Question about XJ6 cam covers Jaguar 6
J Question about Series III XJ6 Motor in E Type? Jaguar 2
smaceng Help with a XJ6 [sort of] Clutch Jaguar 3
D Posi-Rear end in a series 3 Jaguar xj6 Jaguar 12
W Removing wiper arm on 74 XJ6? Jaguar 0
B '72 XJ6 Door Seal Installation Jaguar 2
D XJ6 series III front end rattle Jaguar 5
D XJ6 SIII, idle adjustment Jaguar 7
T 10000k HIDs for 96 XJ6 Jaguar 4
D 85 XJ6 brake fluid reservoir leak Jaguar 4
D 85 XJ6 Heater Core Replacement Advice Wanted Jaguar 19
D XJ6 Seat Removal Q. Jaguar 5
D 85 XJ6 No start, coil problem. Please Help Jaguar 11
K 72 Jaguar XJ6 4.2 litre motor reliability? Jaguar 4
CZ_Dave A Redneck Jaguar XJ6 Spotted 9
CZ_Dave A Redneck Jaguar XJ6 Jaguar 2
C Remove/Install New '93 XJ6 Door Lock Actuator Jaguar 0
C 1999 xk8 steering wheel swap out '93 xj6 Jaguar 3
W Removing windows in 74 Jaguar XJ6 Jaguar 1
R Jaguar XJ6 Door Locks Jaguar 8
B 85 jag XJ6 improve it's performance ? Jaguar 4
eschneider xj6 purge valve / air bleed valve Jaguar 4
dklawson Early '80s XJ6 Speedometer Transducer? Jaguar 0
M 87 Series III XJ6 Rough Running Jaguar 16
B Lead on xj6 series 1 / Chevrolet 350 Jaguar 0
M 1985 XJ6 Drivers door lock Jaguar 5
