While searching for the reason the Gen light was on I discovered that the bottom hold down bracket
"ear" on the generator was broken off probably causing the generator to shift enough that the fanbelt was no longer tight.
I had a spare generator so I took it to a shop and they cleaned the carboned up armature and said the rest of the unit was good.
I took off the gauge cluster and tightened all the wire hold own screws and made sure the wiring from the ignition switch to the push button and Ign light were good. I polarized the generator.The car starts and runs fine but the Generator light stays on. I checked the wiring from Field to field from the voltage regulator to the Gen and tested good.
When I did the Moss Voltage Reg test from Youtube I got a spark when I touched the power from the Bat to the Field....apparently the generator is supposed to run when you do this ...correct?
Also with the engine running should I get 13.5 to 14 volts across the Battery Pos and Neg posts if the generator is charging? Any ideas why that darn light won't go out? Electrical is not my strongpoint.
