2500M rear suspension
TRclassic3
Need some advice on this, The right rear of the car sits a bit lower than the left. Noticeable when viewing from the rear. I have also noticed that the tire will rub occassionally. Most likely over heavy bump or right hand turn at speed. I cannot see anything broken or bent. Is the most likely culprit the spring and/or shock? anything else I should inspect?
TIA
Ed
Grantura_MKI
Sound to me like you have a rear spring that has packed up. Are your shockers adjustable base? If so, put a few turns on the spring. If you are going to replace, try to purchase adjustable shocks and springs. I would check your bushings while you are at it. Super-flex makes replacement bushes.
Let us know what you find.
TRclassic3
TRclassic3
Thanks for the info. That confirms my thoughts that it must be the spring. The current shocks are not adjustable. As this looks like a replacement project, any suggestions for sourcing the shocks and springs?
ralph_s
Ed,
Keep me posted on what you discover as I'm sure I'll have the same iisues in the future.
ps I'm ready for a warm sunday car show in Gettysburg, but think I've got to wait for some time........lol
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
C My 2500M progress/questions thread TVR 5
bravenrace WTB - TVR 2500M TVR 0
bravenrace For Sale 1974 TRV 2500M FOR SALE Other British Classifieds 2
A 1974 2500M Spring Rates TVR 6
J Looking for a 2500M TVR 0
S 2500M or Vixen wanted TVR 0
B 77 2500M Shocks TVR 0
O TVR 2500m weatherstrip source needed TVR 2
J 1973 2500M ignition issue TVR 8
Z Just Restored 1973 TVR 2500M, Barn Find TVR 25
T Tvr 2500m For Sale, Nice Original Solid Example. TVR 1
M TVR 2500M Triple Weber 40 DCOEs TVR 130
R 2500M Carb Conversion TVR 5
Jastx TVR 2500M tires - what are you running TVR 7
TRclassic3 2500M Heater cable TVR 1
TRclassic3 Flasher units 2500M TVR 3
Kirk_Fisher 74 2500M prices TVR 9
TRclassic3 2500M sun visors TVR 11
R 2500M Overdrive options TVR 13
Kirk_Fisher 2500M V8 on Ebay TVR 2
R 2500M Vents TVR 3
TRclassic3 2500M carpet kit TVR 1
R Windshield for a 2500M TVR 3
TRclassic3 Tranny removal 2500M TVR 10
R A fan of 2500M's!!! TVR 3
B 2500M chassis tube question TVR 2
R 2500M Cooling TVR 1
B 2500M search TVR 5
R 2500M Battery TVR 0
M TVR 2500M Model TVR 4
R Ignition Circuit - 2500M TVR 0
G Parting out a 2500M - Should I do it? TVR 18
Mickey Richaud 2500M on Ebay TVR 4
J TVR 2500M Shop Manual TVR 9
G 2500M hood TVR 3
G Gas tank for a 2500M TVR 5
H How to Remove Sunroof on 2500M? TVR 0
H How to Remove Sunroof on 2500M? Restoration & Tools 5
H Door Panel Removal on 2500M? TVR 4
H Photos of My 2500M's Engine and Radiator TVR 9
H Steering Column Binding in 2500M TVR 5
H 2500M Features and Stuff to Fix TVR 2
H Owners Manual for 2500M? TVR 3
H 2500M Came Originally With Electric Cooling Fans? TVR 19
H Bad Tach in 2500M TVR 0
AngliaGT 2500M on craigslist TVR 4
bravenrace Ebay 2500M race car and TR-6 Engine TVR 9
bravenrace 2500M Header Info Needed TVR 1
bravenrace 2500M on Ebay TVR 5
