2500M Features and Stuff to Fix
hundredsixinsf
Looking for some info/advice on the following:
How do you turn and regulate the heater in a 2500M? The switch appears to control a blower, but don't see how to regulate the heat?
Horn doesn't work in my 2500M. I've run 12V to the horns directly and they work. I have the original Moto Lita wheel in my car. I popped the horn button off and looks pretty simple. What are the typical culprits with horn failure?
The gauges don't light up. Is there a separate switch for them or should they light up when the headlight switch is on?
At around 75 to 80mph, I hear a strange humming/thumping sound from the rear. Not too loud but it's there. I think I read a post stating this was a common issue on these cars. Anyone know the cause?
That's all for now, I'm sure I'll have more.
Steve
mrtvr
Steve,
As for the heater control in the 2500M, you should have a pull knob attached to the underside of your steering column. This is your heater control. You pull out on it in degrees to regulate the heat. The fan switch, as you indicated, simply turns on the blower motor.
Regarding your instruments lighting up, the earlier cars had a Panel Light Switch in that bank of switches on the dashboard. The later cars had a rheostat control on the dash that let you dial in the brightness of light on the gauges.
Abaout your humming/thumping sound from the rear of the car.....perhaps your universal joints are showing signs of wear?
Marshall
H
hundredsixinsf
Thanks Marshall. There is a rocker switch on my dash that is labeled "LIGHTS". I'm assume that this switch should turn on the headlights, tail lights, front parking lights, side marker lights and...instrument lights? So no separate switch just for the instrument lights alone. Don't see a rheostat control, so mine must be an earlier car. S/N 2677TM.
Thanks, I'll check the universal joints for wear.
I see the pull knob under the dash. What exactly is it connected to? How does the mechanism regulate the heat?
--Steve
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
C My 2500M progress/questions thread TVR 5
bravenrace WTB - TVR 2500M TVR 0
bravenrace For Sale 1974 TRV 2500M FOR SALE Other British Classifieds 2
A 1974 2500M Spring Rates TVR 6
J Looking for a 2500M TVR 0
S 2500M or Vixen wanted TVR 0
B 77 2500M Shocks TVR 0
O TVR 2500m weatherstrip source needed TVR 2
J 1973 2500M ignition issue TVR 8
Z Just Restored 1973 TVR 2500M, Barn Find TVR 25
T Tvr 2500m For Sale, Nice Original Solid Example. TVR 1
M TVR 2500M Triple Weber 40 DCOEs TVR 130
R 2500M Carb Conversion TVR 5
Jastx TVR 2500M tires - what are you running TVR 7
TRclassic3 2500M Heater cable TVR 1
TRclassic3 Flasher units 2500M TVR 3
Kirk_Fisher 74 2500M prices TVR 9
TRclassic3 2500M rear suspension TVR 5
TRclassic3 2500M sun visors TVR 11
R 2500M Overdrive options TVR 13
Kirk_Fisher 2500M V8 on Ebay TVR 2
R 2500M Vents TVR 3
TRclassic3 2500M carpet kit TVR 1
R Windshield for a 2500M TVR 3
TRclassic3 Tranny removal 2500M TVR 10
R A fan of 2500M's!!! TVR 3
B 2500M chassis tube question TVR 2
R 2500M Cooling TVR 1
B 2500M search TVR 5
R 2500M Battery TVR 0
M TVR 2500M Model TVR 4
R Ignition Circuit - 2500M TVR 0
G Parting out a 2500M - Should I do it? TVR 18
Mickey Richaud 2500M on Ebay TVR 4
J TVR 2500M Shop Manual TVR 9
G 2500M hood TVR 3
G Gas tank for a 2500M TVR 5
H How to Remove Sunroof on 2500M? TVR 0
H How to Remove Sunroof on 2500M? Restoration & Tools 5
H Door Panel Removal on 2500M? TVR 4
H Photos of My 2500M's Engine and Radiator TVR 9
H Steering Column Binding in 2500M TVR 5
H Owners Manual for 2500M? TVR 3
H 2500M Came Originally With Electric Cooling Fans? TVR 19
H Bad Tach in 2500M TVR 0
AngliaGT 2500M on craigslist TVR 4
bravenrace Ebay 2500M race car and TR-6 Engine TVR 9
bravenrace 2500M Header Info Needed TVR 1
bravenrace 2500M on Ebay TVR 5
