1975 XJ6C dashpot stromberg oil???
bmurphy7369
Hello all,
I have received my beautifully rebuilt Stromberg 175cd-2 carbs and am need to know the proper oil to use when filling the damper/dashpots... I have benn told to use SAE30 grade, 20/50w, and SAE20 electric motor oil............ if anyone has a good suggestion, please reply to this post.
I am lost in Stromberg heck.
Thanks,
Brian
piman
Hello Brian,
I have always used multigrade engine oil, i.e. normally 20-50. I don't think that you would notice any difference in performance if you use a straight 20 or 30 SAE grade either. Engine oil is usually to hand so is convenient.
The function of the oil and the little piston on the cap is to stop the (main) piston from opening too quickly when you stand on the accelerator which would give a flat spot due to momentary weakening of the mixture.
Alec
bmurphy7369
bmurphy7369
Piman,
Thanks for your help. I went with 20/50 on my TR3 SU's and never had a problem. Tomorrow I will be installing the new fuel lines and the carbs. I can't wait to drive the car as I have only driven it once since I bought it last July. The second time I started it the rear carb burst into flames destroying all hoses, wires and the battery on that side of the engine. Needless to say I am trying to be extra cautious with every detail to avoid another disaster. Thanks again,
Brian
Michael J.
Castrol used to make a motorcycle fork oil in 20w. I always used 20w fork oil in the dashpots for my TR-3A, TR-4 and MGB. If not still available, I recommend 20w non detergent oil. I do not suggest using a multiviscosity oil because of the way it acts at different temperatures.
bmurphy7369 1975 XJ6C Stromberg water choke, now engine tuning Jaguar 1
bmurphy7369 1975 XJ6/XJ6C Fuel Vacuum Attachments Jaguar 3
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
D MGB 1975 MGB 20 Years Resurrection MG 1
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
F TR6 1975 TR6 runs lean Triumph 11
M TR6 Early vs newer pdwa for Tr6 1975. Triumph 3
P For Sale 1975 Spitfire for sale Triumph Classifieds 0
R For Sale 1975 Spitfire engine Triumph Classifieds 1
D For Sale 1975 Tr6 for Sale Triumph Classifieds 0
D Spitfire 1975 Spit resurrection Triumph 4
David Townsend MGB 1975-80 MGB Roadster Fine Art Prints MG 0
O MGB 1975 MGB No Fuel to the filter MG 2
M TR6 1975 TR6 Backfire from Carbs, running Lean - Help! Triumph 9
DrEntropy Dated as 1975 Racing 2
RJS TR4/4A 1975 Triumph British Racing Green Paint Code Triumph 4
D 1975 bricklin in tonawanda, ny Spotted 5
Tinkerman 1975 MOSS price sheet Triumph 9
AngliaGT OT - 1975 Suzuki T500 Titan British Motorbikes 1
M TR6 1975 TR6 wheel alternates Triumph 1
S TR6 1975 TR6 won't start Triumph 3
S MGB-GT need help on an mgb gt 1975 MG 3
T Wedge 1975 TR7 DHC in SoCal Triumph 3
roofman Spitfire 1975 Spitfire overdrive question Triumph 6
T Wedge Cheap 1975 TR7 coupe Triumph 1
D MGB 1975 MGB Won't Crank MG 7
B MG Expansion Tank Thermostat Housing 1975 Spridgets 3
shemp4 water pump on 1975 midget Spridgets 3
bmurphy7369 The basic Lucas/OPUS 1975 xj6 era principles??? Jaguar 9
6773 fuel tank 1975 midget Spridgets 3
Steve 1975 Midget on Craigslist Spridgets 0
bmurphy7369 Wiring help needed badly... 1975 XJ6 Crane setup.. Jaguar 8
bmurphy7369 XJ6 SII 1975 with Crane Ignition dies when warm Jaguar 10
B Any Body Have 1975 wiper arms? Spridgets 1
RocknTommy Will the 1500 & Trans work in a pre 1975 Midget? Spridgets 11
M MGB 1975 MGB MG 4
S MGB-GT 1975 Engine in '71 mgb gt MG 2
Monark192 MGB 1974.5 MGB vs. 1975 model. Which to keep? MG 19
F TR6 Carburetors 1975 TR6 Triumph 33
S TR6 1975 TR6 no horn Triumph 5
S MGB 1975 MGB Overdrive rear seal MG 2
S 1975 with an interesting leak MG 10
A TR6 1975 TR6 Ventilated Rotors Triumph 12
1 MGB 1975 MGB MG 15
Thor Can the 1976 plus radiator fit 1975 midget & Spridgets 7
