1969 Sprite. Month: 8
AvionicsTech
Member
Been away from home since this past summer, just thought I'd share with you all what I've gotten done since I've been back. It seems like every time I make progress I find 10 new things to work on. Hopefully, now that I'm back home, I'll be posting these videos more often.
Jim_Gruber
Ben,
I'd take bearing out just to lube and clean. Really simple, just take note of the way they are oriented when they come out. New rotors are fairly cheap or just get them turned. If you go that far make sure you test condition of front end, wishbones, etc. Take a look in the back of the MOSS Catalog on detecting wear and tear on Sridget Front ends. Also you need to carefully inspect the wishbones for cracking. Lack of grease causes these parts to lock up and end result is cracked wishbones underneath all of the grease. Lots of PB Blaster on Bleeder screws multipole times before you try to do anything. Leard there is a treick using I believe a 1/8" drill bit inserted into bleeder screw before you attempt to loosen. 1/8" drill fits into bleeder and prevents bleeder from collapsing or breaking off. Sometimes heat helps as well. Be sure to replace both front and rear hoses. Limit is 10 years max, Spridget BMC Manual calls for 2 years or 24k miles. These hoses collapse internally and there are no apparent signs of collapse. Had issues with Front Brakes on my '68 pulling and not braking properly. Discovered issues with front hoses that were 12 y.o. and < 10k miles. Back hose collapse also affects rear brakes, found that first time around, no fluid getting to rear wheel cylinders due to collapsed hose. Slow and steady and your '69 wil lbe back on hte road.
BTW - Nice Wheels!!!
A
AvionicsTech
Member
I didn't mention it in the video, but I had attempted to bleed the brakes a while back and found that I could get nothing out of the rear bleed nipples. Had no issue getting them to open, but as with so many things on this car, I had my PB blaster at the ready anyway. Suspect a collapsed hose to the rear, but I've already been planning on replacing the brake lines when I reach that stage. Brakes will be the next system I attack, once I get the carbs installed. Thanks for your advice on the suspension, I'll give the wishbones a thorough inspection too when I take apart the hubs.
L For Sale 1961-1969 AH Sprite, MG Midget Chrome bumpers & hardware Spridgets Classified 0
jmayzer 1969 sprite - good deal?? Spridgets 17
K clutch 1969 sprite Austin Healey 4
D 1969 Austin Healey Sprite Rebuild Spridgets 16
I 1969 Sprite Spridgets 5
vping 1969 AH Sprite Steel Wheel value Spridgets 3
Tullamore Stock 1969 Sprite Dyno Test Spridgets 0
Charlypm For Sale 1969 Austin America Other British Classifieds 3
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
CJRams For Sale 1969 Jaguar XKE Jaguar Classifieds 0
AngliaGT 1969 Ford Galaxie Spotted 3
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
Quackedo TR6 1969 Triumph TR6 Differences Triumph 18
V 1969 Sunbeam Alpine coupe glovebox lock removal Sunbeam (Rootes) 0
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
S For Sale Triumph TR6 Workshop Manual on CD/ROM - 1969 - 1976 Triumph Classifieds 0
S For Sale MGC Factory Workshop Manual on CD/ROM - 1967 - 1969 Models MG Classifieds 0
oldbagpipe For Sale Early 1969 TR6 'Stalled Project' $4500 Triumph Classifieds 0
AngliaGT 1969 Impala Convertible Spotted 0
oldbagpipe For Sale Early 1969 TR6 Project for sale Triumph Classifieds 10
M Wanted MGB grill 1963 to 1969 MG Classifieds 2
Got_All_4 TR6 What is a 1969 TR6 seat worth? Triumph 5
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
Raymond MGB 1969 oil filter MG 4
C TR6 Need help with a 1969 triumph tr6 Triumph 21
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
June TR6 1969 tr6 Triumph 17
B MGB Normal oil pressure at all tempratures for 1969 MG-B MG 12
S MGB 1969 MGB No spark to plugs MG 5
W What motor will fit my 1969 Austin Healey Mark IV Spridgets 29
W What motor will fit my 1969 Austin Healey Mark IV Austin Healey 5
RickB As seen on Craigslist [Seattle area] 1969 Austin Hensley [SIC] Spridgets 0
J Confusing Seat choices for 1969 Mini British Motor Corp 8
H 1969 Jaguar XKE - Oil Jaguar 7
aeronca65t 1969 Watkins Glen F1 Racing 9
S MGB-GT FS: 1969 MGB GT 64k miles, overdrive, a lot fresh. MG 18
T Difference between 1969-74 and later exhausts Triumph 7
AngliaGT 1969 LeGrand FF - Anyone Have Info? Racing 2
S Spitfire For Sale: 1969 Spit Fire MK3 Triumph 1
T TR6 WTB - 1969 TR6 fan Triumph 7
JRC Spitfire SF Chronicle - 1969 Spit Triumph 2
Z MGB MGB 1969 Trim query MG 6
abarth69 MGB-GT 1969 MGB GT with automatic MG 2
d_valentino 1969 Mini w/ automatic gearbox and air bags British Motor Corp 12
