1966 BJ8 Steering Box Leak @ Wire Compression Nut
hmsevans
How do you Seal the Wires at the end of the Steering box to stop the gear oil from leaking thru the wires?
I just reinstalled my steering wheel assy and I can not seal the wires at the box end.
I installed a New Olive inside the Compression nut.
Please advise the correct parts and assembly steps.
Mark Evans
Keoke
:savewave:
That is what the olive and the nut do. If the wires get wet then the stator tube must be damaged in that area inside the steering box.--Fwiw --Keoke
Mark Evans
bighealeysource
Bronze
Hey Mark,
If your stator tube does not seem to be long enough to extend out the opening
at the steering box, the two pieces have probably been pushed together a bit
during taking in and out, etc. Simply pull the short end out from the long
end some - not too much - and you should have enough length to protrude out
of the end of the steering box. Then like Bob said, simply put the olive
over that end and tighten down. You also might use the Penrite steering box
heavy oil that is sold for that purpose.
Regards,
Mike
AUSMHLY
Re: 1966 BJ8 Steering Box Leak @ Wire Compression
Bob_Spidell said:
Yes. The olive should have a split to allow it to slip over the stator tube. The compression nut will clamp it down.
I just replaced the olive on my 64 BJ8 last Friday. The olive from Moss did not have a split. The olive slipped over the stator tube just fine.
AUSMHLY
Mark Evans
Olive, nut, steering box fluid, wrench and socket.
1. The tube should stick out enough to have the nut placed over it, with a little extra remaining. You should be able to pull the tube down by hand. Easier if the trafficator has been pulled up enough so that it's tube is out of the trator tube.
2. Push the olive up the tube.
3. Push the nut up the tube and start the treads.
4. Make sure the trafficator tab is centered on the steering wheel.
5. Tighten the nut, and make sure the trafficator tab did not move from center position. If so, have someone hold it in place as you tighten the nut. (Do not use anything to hold the tube (the end where the nut is) from turning that will crimp the tube. You will introduce a leak if you bend/crimp the tube.
6. Replace loss fluid from repair procedure.
7. Pat yourself on the back and those who may have helped you for a job well done.
8. Drive and enjoy. Or, move on to next project.
This is the short version assembly instruction. Add time for dropping tools, cussing, things not going on easily, interruptions, and knowing your working on British.
Cheers,
Roger
H
hmsevans
Thanks,Today is Start up after a 2 year Resto
Thanks to all for the detailed advise,
Today, I plan to Fire her up after a 2 year Beauty Sleep.
Would not have Happened without this Forum.
Mark
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
Keoke 1966 AH BJ8 on eBay Austin Healey 18
M 1966 BJ8 Top Austin Healey 1
L 1966 BJ8 frame rebuilding questions Austin Healey 1
L 1966 BJ8 rear trim panels Austin Healey 8
D distrubutor wiring for 1966 BJ8 Cap to plugs Austin Healey 3
H 1966 BJ8 Lucas Voltage Regualtor ,Correct Part No Austin Healey 9
H 1966 3000 BJ8 Heater Box Data Tag Data Info Austin Healey 1
H Need help with, 1966 3000 BJ8 WShield Post Install Austin Healey 2
C 1966 BJ8 "garage find" Austin Healey 9
VelodromeRacer Mix screws for 1966 BJ8 carbs... Austin Healey 7
S Cockpit of 1966 BJ8 is like an oven Austin Healey 28
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J MGB 1966 MGB won't start MG 1
J MGB Just bought a 1966 MGB MG 50
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
D Is it a 1965 or a 1966 MG Midget? Spridgets 2
S 1966 Austin cab British Motor Corp 2
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
K 1966 Austin 1100 carbs? British Motor Corp 1
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
C MGB 1966 MGB windshield glass MG 4
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
3798j General TR 1966 12 Hours of Sebring Triumph 0
1 MGB 1966 MGB hard shifting into 3rd MG 1
AHS Spitfire 1966 Spitfire with title for parts Lancaster PA NFI, $100 Triumph 3
Zimmycobra For Sale Misc. External Engine Parts - 1966 TR4A Triumph Classifieds 1
Zimmycobra For Sale Original 1966 TR4A Fuel Tank Triumph Classifieds 0
Zimmycobra For Sale Original 1966 TR4A Radiator Triumph Classifieds 0
Zimmycobra For Sale Original 1966 TR4A 60 Spoke painted wire wheels Triumph Classifieds 0
J For Sale For Sale-1966 MG Midget Disassembled Other British Classifieds 0
N TR4/4A 1966 Tr 4a, seats Triumph 7
W Sound 1966 Sprite rolling chassis Spridgets 0
O TR4/4A Will these tires/wheels work on my 1966 TR4a, IRS? Triumph 19
AH67 1E120049 1966 Jaguar XKE Roadster Jaguar 1
PHerder ? about the rear section of the cockpit on a 1966 Sprite MkIII Spridgets 9
tr6nitjulius What happened to Barn Find 1966 E-Type 4.2 Coupe? Jaguar 0
W 1966 Sprite seat belts Spridgets 7
S Floor Mats for 1966 Series 1 Coupe Jaguar 2
ekamm 1966 race start Triumph 14
R 1966 MG Midget MK11 Dash Spridgets 4
K 1966 Austin healey 3000 Austin Healey 10
AngliaGT 1966 Studebaker...... Spotted 2
Pythias Wanted.. Obscure Part[s] for 1966. Spridgets 12
R TR4/4A 1966 TR4a , outer tie rod question Triumph 7
K Curious about 1966 Jaguar S-Type Saloon Jaguar 5
