Wanted.. Obscure Part[s] for 1966.
Pythias
I need a bunch of those funny "T" bolts with nuts that slide into the channel to hold on the surround on a '66 Spridget. The ones from McMaster Carr aren't quite the right size....I only have 4 of which two are stripped from a total of about 15 needed.... ...
Pythias
Pythias
I don't have a picture... It's the vinyl covered rear cockpit surround. You have at least one of the cars, but I don't know if you have spares. They look a lot like this..(https://www.mcmaster.com/#t-bolts/=cx46lk). The nut size is 5/16", and I THINK the bolt is a 10/32, but I can't remember.
HAN8L1965
VB has them, part 12-2842, the screw is 12-2263 and the nut is 12-922t number
Mark
Pythias
Pythias
Nope, those are for a BE and go in from the front. The "T-bolt" is one piece. The T slides into a channel and has no head. The channel keeps it from turning. I've not seen them for sale anywhere. I'm hoping someone has parted out a car and has a few, but it's not something people normally take off at all.
HAN8L1965
My 65 had this set up, what they call a spring rests side ways in the channel to pull in the screw and nut, I would say it is the same idea, mine works
Mark
nomad
Glad you found them, Bill. I've got a bunch but have a car that is still going to need a bunch!
Kurt.
19Sprite65
Bill L.- I believe they are called "stud plates". You might want to check the ones that hold your door mouldings onto the door- they may be the same size. If so, Moss has them as part no. 326-075. I can dig mine out out of its storage box this weekend if you'd like. I'm almost in the same time frame; I'll be putting the rear cockpit trim on in about 2 weeks.
Pythias
Pythias
Thanx for that. It sure looks like it, but I see Moss shows two different ones,326-075 and 326-075. Let me know when you put on your rear trim if they're the ones. Colin in Australia told me the name is stud plates, but when you do a search at Moss for that name you turn up nothing. He's air mailing me a dozen even as I type.
RickB
Remember that in England our top is their hood and our hood is their bonnet and our trunk is their boot and etc.
Australia is much the same with the naming of things, that is to say: not the same as us.
It's hard to say what "stud plate" translates into here.
19Sprite65
Bill- I finally got around to installing my rear cowl trim today. The stud plates from the door caps will work, however, the screw is a tad shorter than what is made for the cowl trim.
Pythias
Pythias
I need at least FOUR long ones... Here's the situation. I have a plexiglass windblocker. The mounting kit for it get installed "up and under" and uses those "stud plates" to hold it in place. The windblocker goes onto those (You'll see at the 50th.) So the studs need to be at least 1/4" longer just to accomodate the extra thickness. It's easy to overtighten and thus strip those little studs, so I'm after some spares. I got some from Colin in Australia, but wouldn't mind having a few more, as I've only installed seven of the twelve for which there are holes.
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
CARSINC WANTED: 1275 Engine Spridgets 0
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 2
K TR6 TR6 late rims wanted Triumph 0
B Stainless Steel Exhaust System Wanted Austin Healey 5
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
T Wanted Wanted : MGA rear deck cover MG Classifieds 0
T Wanted: Early BN1 Sidescreens Austin Healey 2
M Wanted WANTED...New TR6 piston set. Triumph Classifieds 2
M TR6 WANTED....Nural pistons for TR6 Triumph 1
volunteer Wanted: Brake Master Cyl. Repair Kit for Daimler DS420 Other British Cars 18
M Wanted Wanted: Inoperative J Type OD Solenoid! Triumph Classifieds 2
T TR6 Opinions wanted Triumph 29
S Wanted: AH Concours Registry Guide Austin Healey 2
H Wanted Wanted TR6 Hardtop Triumph Classifieds 3
shadowfever MGB MGB intake wanted MG 2
D Wanted Wanted Triumph Classifieds 0
Joel Lester Wanted Wanted - TR6 steel wheels Triumph Classifieds 6
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
M MGA RHD rack and pinion wanted MG 19
T TR2/3/3A Wanted - Picture of TR3A original firewall layout Triumph 5
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
J Wanted Help Wanted -SE WI Other British Classifieds 1
J Help Wanted - SE WI Racing 2
D Wanted: Austin Healey Classifieds 5
D Wanted: Austin Healey Classifieds 0
35 Siddeley MGB MGB Armstrong shock dimensions wanted MG 0
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
Pythias MKIII Springs WANTED Spridgets 8
J Bugeye seats wanted... Spridgets Classified 0
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
