TR2/3/3A 1960 TR3A Radiator replacement recommendations
woodeye33
I'm told my radiator cant be repaired.
I'm hoping someone could share their experience with purchasing a new radiator.
Is aluminum the way to go.
With or without the crank hole.
I'm seeing prices from $170 for aluminum on EBAY to $750 from Rimmer Bros
Thanks Jeff
I bought a TR4A radiator direct from Wizard Cooling for about $450, within the last couple of years. I have heard bad things about the eBay ones--leakage, for example.
Are you sure it can't be repaired? Rarely do they need more than a recore.
Hi thanks for your quick response. I had heard similar things about eBay's radiators. I'll look into a wizard radiator. I only checked one radiator shop who I've used in the past. he said he couldn't get a new Core. I'll look to see if there's another shop in my area.
I like the crank hole for adjusting valves, finding the timing marks and setting points. I pull the plugs out to kill the compression and the motor turns easily with the crank. I find it difficult to turn the motor over by hand because the fan is on the crank plus there is little room in the front for anything to grab onto. The main bolt on the end is hidden by the fan. If you can, get the crank hole for working on the car not necessary for starting the car, but for turning the engine over.
steve
Were I to do this again, I would omit the crank hole. The cooling tubes blocked off by the hole might come in handy for cooling.
I had the Wizard installed, without the crank hole. The mechanic said it was a direct fit without complications. Much better cooling than the original, even in traffic in hot weather.
I think you wil continue to hear positive results from TR owners who have installed
a Wizard Aluminum Radiator. If still concerned.... add the Macy Fan in addition.
Gil. NoCal
My opinion - not always based in fact - is it is better to go with a trusted brand name for critical components such as a radiator.
Wizard comes up a lot as a “trusted” brand. As you mention, eBay prices are all over the map… suggesting both quality variance and profit variance.
(In my case I was lucky that a local radiator shop could repair mine - small leak repair, not new core. Rogers Radiators in Medford, FYI for anyone in the Boston area. Good old fashioned place where the guy greeting me had a cigarette hanging out of his mouth. My kinda guy - not specifically the cigarette, but in general.)
I bought local at Brice Thomas in Gadsden AL. They specialize in antique and classic cars, hotrods, and race cars. My early TR3 aluminum radiator without a crank hold looks like a work of art and has performed wonderfully for 5+ years. Unfortunately their current price of $632 is about $200 more than I paid.
I have a Macy's Garage fan and can turn the engine by hand, but you can always put the car in gear and push it. If you're doing valves, you might need a long driveway.
Good luck!
Seems a pity that they can't do an aluminum one with the crank hole. I did speak to someone at Wizard some time ago and was told there was no call for the crank hole and it would be difficult to do.
I like the ability to turn the engine by hand and is a neat thing at shows to start the TR3 with the handle. Most people have never seen it done these days.
David
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 17
W For Sale 1960 TR3A for sale Triumph Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
Tinkerman TR2/3/3A Hood stick assembly 1960 tr3a Triumph 7
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Tinkerman TR2/3/3A 1960 TR3A post 60000. WON"T START ???????????????? Triumph 8
Tinkerman TR2/3/3A 1960 TR3A Boot rubber seal installation? Triumph 7
Tinkerman TR2/3/3A 1960 tr3a sheet metal fitment Triumph 6
Tinkerman TR2/3/3A 1960 TR3A carpet installation Triumph 5
Tinkerman TR2/3/3A 1960 TR3A Tonneau Capping Installation Triumph 1
Tinkerman TR2/3/3A 1960 TR3A Tonneau Trim Mill board Triumph 10
M_Pied_Lourd TR2/3/3A 1960 Triumph TR3A Trunk Seal Orientation Triumph 6
Tinkerman TR2/3/3A Prepping the grill for installation for my 1960 TR3A Triumph 1
Tinkerman TR2/3/3A Sealing fender to body 1960 TR3A Triumph 15
Tinkerman TR2/3/3A Windscreen mounting tips 1960 TR3A Triumph 2
Tinkerman TR2/3/3A 1960 TR3A Bottom Rubber Seal on the Windscreen Triumph 3
Tinkerman TR2/3/3A Tunnel installation question 1960 TR3A Triumph 11
Tinkerman TR2/3/3A Another Freeby from the past. For a 1960 TR3A Gas Tank Triumph 4
Tinkerman TR2/3/3A 1960 TR3A Holes in the tranny tunnel Triumph 11
Tinkerman TR2/3/3A Carpet underlayment, TR3A 1960 Triumph 10
Tinkerman TR2/3/3A Major oil leak from original oil filter system 1960 TR3A post 600000 series Triumph 3
D TR2/3/3A 1960 TR3a front suspension Triumph 2
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
D TR2/3/3A fitting windshield/frame to 1960 Tr3a & Brooklands screen removal Triumph 2
Tinkerman TR2/3/3A TR3A 1960 Gas on three out of four plugs ? Triumph 6
Tinkerman TR2/3/3A 1960 TR3A post 60,000 series seat pan covering Triumph 3
Tinkerman TR2/3/3A 1960 TR3A seat tack strips Triumph 1
Got_All_4 TR2/3/3A Finish on a 1960 TR3A Fluid reservoir? Triumph 6
60TR3A TR2/3/3A 1960 TR3A Small Mouth [Huh?] on eBay Triumph 63
M_Pied_Lourd TR2/3/3A 1960 TR3A Mystery G Triumph 24
Tinkerman TR2/3/3A 1960 TR3A Instrument Cluster Ground Post Screw Triumph 9
M_Pied_Lourd TR2/3/3A Restoration of TS 69891LO 1960 TR3A Triumph 36
T TR2/3/3A 1960 TR3A oil leak issue [imagine that!] Triumph 5
T TR2/3/3A 1960 TR3A engine compartment color Triumph 8
PAUL161 TR2/3/3A Colonal Tom Parkers 1960 TR3a For Sale! Triumph 3
T TR2/3/3A 1960 TR3A now with rack and pinion Triumph 22
Tinkerman TR2/3/3A Bulkhead Sealer Plate TR3A 1960 Triumph 3
D TR2/3/3A 1960 TR3A Paint Question Triumph 24
gubba TR4/4A 1960 TR3A with tr4 motor and tranny? Triumph 22
D TR2/3/3A 1960 TR3A Flasher Triumph 7
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 2
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
