1955 BN1 overdrive relay
Alan W.
Member
A 1955 BN1 Healey, which I recently purchased, has only one overdrive relay (the new type) and the overdrive does not appear to be working. I am aware that the bn1 had two relays, but was curious if it is possible to wire for one relay.
Thanks
Healey 100
Alan:
Yes it is, I wired mine that way many years ago and it works fine. You can do it by carefully copying the BN2 circuit diagram in the shop manual. It appears to be functionally equivalent to the two-relay circuit system.
There are still many ways for the OD to malfunction, but usually the culprit is that tiny set of contacts inside the solenoid rather than the relays. You can bypass the relays entirely and just connect the solenoid directly to a 12V source to help diagnose the problem.
A
Alan W.
Member
Thanks Bill,
I thought the bn1 had a governor for the OD that required the two relays. Is this incorrect? I had met an AH restorer at an English Car Show that said he wires the throttle switch directly to the solenoid to by-pass the relays and says the current load was not a concern. What are your thoughts on that?
Thanks,
Alan
Healey 100
Alan:
The governor in the BN1 can still be incorporated with a single relay circuit. Just put the governor switch in series with the dash switch. Both switches would need to be closed to activate the relay and fire the solenoid and either switch opening would downshift.
I think the real purpose of the relays is to prevent the overdrive from disengaging without blipping the throttle which momentarily opens the throttle switch. The throttle switch should play no role in engaging the OD if it is set up properly. However, I have seen throttle switches rigged to serve as sort of a kick-down switch, to downshift if you give the car enough throttle. That is not the way it is supposed to work, according to the shop manual for either the BN1 or BN2.
I think connecting the OD solenoid directly to a 12V source controlled by any switches you want would work fine, though you would not get the throttle switch disengage feature of the relay system. The solenoid does draw a huge current but only for a few milliseconds, once it activates the it just takes a few amps to hold it in. I don't think it would damage wires or switch contacts as long as they are reasonably sized.
If you bypass all the bells and whistles of the relay system, beware of the following: if you stop your Healey with the OD engaged and back up, you can seriously damage the OD. This is not likely to happen, but I have seen it occur, just keep that in mind.
Good luck!
Bill.
Z For Sale 1955 Autsin Healey 100-4 BN1 and 1956 100-4 Race car Austin Healey Classifieds 0
G 1955 Austin-Healey BN1 H6 Carbs Austin Healey 1
T 1955 BN1 dash Austin Healey 3
T 1955 BN1 front shroud Austin Healey 3
S For Sale 1955 Morris Minor touring car for sale. Other British Classifieds 5
G T-Series 1955 mgtf 1500 lites MG 5
PAUL161 T-Series Original 1955 MGTF Photos MG 6
D For Sale 1955 DAIMLER CONQUEST RUNS NEEDS RESTORATION. Other British Classifieds 1
S For Sale MGA Factory Workshop Manuals on CD/ROM - All Models 1955 - 1962 MG Classifieds 0
S For Sale MG TD & TF Factory Workshop Manual on CD/ROM. 1950 - 1955 Models. MG Classifieds 0
P 1955 Corvette V8 Other Cars 2
Z For Sale 1955 MG TD Original car, numbers matching, restored to immaculate condition MG Classifieds 10
E For Sale 1955 Austin Healey 100 /4 rust free project car Austin Healey Classifieds 3
T Rebuild kit for fuel pumps 1955 to 1964 Spridgets 1
A 1955 100/4 Flywheel Info Austin Healey 4
aeronca65t 1955 LeMans Austin Healey 10
AN5Sprite T-Series 1955 TF 1500 For Sale This Spring MG 3
Nunyas 1955 Porsche 356 video Other Cars 3
NutmegCT details details [1955 100/4] Austin Healey 7
1 Opinions on a butchered 1955 100 Austin Healey 8
L 1955 XK140 auto choke "otter" switch Jaguar 1
J T-Series 1955 MG TF 1500 Transmission MG 2
drambuie Old British car film..... The Fast and Furious 1955 full movie Austin Healey 17
Vineyarder 1955-56 Healey Lay Gear Austin Healey 2
F T-Series How much to pay? Photos of 1955 MG TF 1500 MG 17
F T-Series Looking at a 1955 MGTF today- what's important? MG 8
mgbmedic replica 1955 Triumph Lemans Triumph 14
J Looking at 1955 Hillman Minx Other British Cars 11
B Found: 1955 Austin Healey 100-4 Austin Healey 8
CZ_Dave 1955 Hillman Husky Other Cars 1
T 1955 Hillman Husky front end info needed. Other British Cars 2
J T-Series MG TF 1955 Grille Assembly MG 1
T 1955 100 Frame Austin Healey 1
dougie Original "Vinatge" Racing - Palm Springs 1955 Austin Healey 3
G TR2/3/3A 1955 TR2 Triumph 17
d_valentino 1955 BN2 Austin Healey 100 Questions Austin Healey 39
T 1955 100-4 Engine Paint Austin Healey 8
T Installing a New Top on a 1955 BN-1 Austin Healey 7
bugimike Sebring, 1955 Racing 4
A 1955, BN-1 Austin Healey 7
Mark_Gibson Windshield Washer on a 1955 TR-2 Triumph 2
john_j 1955 Lemans Radio Prog Austin Healey 1
glenwilcox Lost Love - 1955 RHD 100-4 Ser. 219049 Austin Healey 1
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
W BN1 Steering Box Removal Austin Healey 11
W BN1 Steering Box Austin Healey 3
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
S BN1 Wheel-Tyre Combination Austin Healey 10
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
