1955, BN-1
Arch 93
I've received all kinds of info regarding the proper type and weight of oil to be used in my BN-1, ie, engine, transmission and differential. I have a reprint of the owner's manual, but the products listed either have new names or are no longer made. Would appreciate help on this one. Also, does anyone have opinions on the value of vinyl dressings? Particularly as it applies to tops and tonneau covers. I store the car with top up, during the winter, but I'm wondering if some treatment in the spring, before top down is advisable, or is it a waste of time and money?
Thanks in advance.
Thomas
Michael Oritt
[ QUOTE ]
I've received all kinds of info regarding the proper type and weight of oil to be used in my BN-1, ie, engine, transmission and differential. I have a reprint of the owner's manual, but the products listed either have new names or are no longer made. Would appreciate help on this one. Thomas
[/ QUOTE ]
Thomas--
You'll no doubt get lots of different opinions.
For engine oil I think that most everyone is now using a multigrade, probably either 10W40 or 20W50 depending on latitude and season. For many years I used Castrol but recently switched to a full synthetic and notice slightly higher OP at all speed and temperature ranges--plus I now feel better about myself and others.
For the transmission I have a 5-speed and use Redline MTL but when I had the stock transmission/OD I used Castrol 30 non-detergent. Some folks think that the detergent causes foaming and/or does not provide as good lubricity or whatever--I really don't know what is true here.
In the differential I use any 75-90 gear oil.
In the carbs I use SAE 20 (3-in-1 makes a 20-weight oil in a small squeeze dispenser that is handy to keep in the boot.
John Loftus
Thomas,
The best vinyl/rubber dressing I've found is Aerospace 303 Protectant. It will actually restore flexibility to vinyls and has sunblock properties. According to their website it is specified by AMCO, one of the largest vinyl top manufacturer. The website lists distributors all over the world and many Spa retailers carry it for using on vinyl covers.
303 info
Cheers,
John
Keoke
Hi Thomas, Most of the products on the market today except Armoral will do a creditable job on the vinyl tops. However, I would suggest that it be treated regularly during storage so that it is ready to be put away come spring.---Fwiw--Keoke
DerekJ
[/ QUOTE ]
Michael
Can you just clarify the above. Not sure I fully understand. - Just interested to know - thanks
Thomas
The 30W non detergent is recommended in the gearbox as the oil is also circulating in the overdrive. There is a belief that modern detergent oils, which will suspend any small metallic particles could be hazardous to the overdrive. The non- detergent oil doesn't collect anything and the small particles collect at the magnetised drain plug
Michael Oritt
[ QUOTE ]
[/ QUOTE ]
Michael
Thomas
Thomas--
Not sure which part you want me to clarify.
If it is the part about higher oil pressure it is my impiric observation that the indicated oil pressure is about 5 psi higher using the synthetic oil (Royal Purple) than was the case when using the mineral-based oil (Castrol), both being the same viscosity grade (15W40), both at start up and when the engine is up to temperature. Also the OP seems about 5 psi higher both at idle and cruising rpm's.
If it is the part about my feeling better about myself and others, that was simply an attempt at humor, albiet feeble, based on the many ads that we all see claiming all kinds of beneficial effects for various products and substances.
Your mileage, oil pressure and emotions may vary.
S For Sale 1955 Morris Minor touring car for sale. Other British Classifieds 5
G T-Series 1955 mgtf 1500 lites MG 5
PAUL161 T-Series Original 1955 MGTF Photos MG 6
D For Sale 1955 DAIMLER CONQUEST RUNS NEEDS RESTORATION. Other British Classifieds 1
S For Sale MGA Factory Workshop Manuals on CD/ROM - All Models 1955 - 1962 MG Classifieds 0
S For Sale MG TD & TF Factory Workshop Manual on CD/ROM. 1950 - 1955 Models. MG Classifieds 0
P 1955 Corvette V8 Other Cars 2
Z For Sale 1955 MG TD Original car, numbers matching, restored to immaculate condition MG Classifieds 10
Z For Sale 1955 Autsin Healey 100-4 BN1 and 1956 100-4 Race car Austin Healey Classifieds 0
E For Sale 1955 Austin Healey 100 /4 rust free project car Austin Healey Classifieds 3
T Rebuild kit for fuel pumps 1955 to 1964 Spridgets 1
A 1955 100/4 Flywheel Info Austin Healey 4
aeronca65t 1955 LeMans Austin Healey 10
A 1955 BN1 overdrive relay Austin Healey 3
AN5Sprite T-Series 1955 TF 1500 For Sale This Spring MG 3
Nunyas 1955 Porsche 356 video Other Cars 3
NutmegCT details details [1955 100/4] Austin Healey 7
1 Opinions on a butchered 1955 100 Austin Healey 8
L 1955 XK140 auto choke "otter" switch Jaguar 1
J T-Series 1955 MG TF 1500 Transmission MG 2
drambuie Old British car film..... The Fast and Furious 1955 full movie Austin Healey 17
G 1955 Austin-Healey BN1 H6 Carbs Austin Healey 1
T 1955 BN1 dash Austin Healey 3
T 1955 BN1 front shroud Austin Healey 3
Vineyarder 1955-56 Healey Lay Gear Austin Healey 2
F T-Series How much to pay? Photos of 1955 MG TF 1500 MG 17
F T-Series Looking at a 1955 MGTF today- what's important? MG 8
mgbmedic replica 1955 Triumph Lemans Triumph 14
J Looking at 1955 Hillman Minx Other British Cars 11
B Found: 1955 Austin Healey 100-4 Austin Healey 8
CZ_Dave 1955 Hillman Husky Other Cars 1
T 1955 Hillman Husky front end info needed. Other British Cars 2
J T-Series MG TF 1955 Grille Assembly MG 1
T 1955 100 Frame Austin Healey 1
dougie Original "Vinatge" Racing - Palm Springs 1955 Austin Healey 3
G TR2/3/3A 1955 TR2 Triumph 17
d_valentino 1955 BN2 Austin Healey 100 Questions Austin Healey 39
T 1955 100-4 Engine Paint Austin Healey 8
T Installing a New Top on a 1955 BN-1 Austin Healey 7
bugimike Sebring, 1955 Racing 4
Mark_Gibson Windshield Washer on a 1955 TR-2 Triumph 2
john_j 1955 Lemans Radio Prog Austin Healey 1
glenwilcox Lost Love - 1955 RHD 100-4 Ser. 219049 Austin Healey 1
