Leaking HD6 Rear Carb
Skip & Lynne
The rear carb on my BT7 is leaking fuel and it looks like it is coming from around the choke rod. Could I have a cracked diaphragm, and if so does anyone have any idea where I can get my hands on one before next weekend 10-13?
Rob Glasgow
The rear carb on my BT7 started leaking and it was the diaphragm. I would think any of the normal suppliers could get you a replacement in your time frame. It’s not a difficult job once you’ve gotten the carb out of the car.
Rob Glasgow
Patience is the key to removing the rear carb. Take off the air cleaner and top of the float bowl first. It will give you more room to remove those pesky nuts that hold the card to the manifold.
S
Skip & Lynne
I already have the air cleaner and choke cable done I did a frame off on this car about 6 years ago so I guess its about time for things to wear out
Healey Nut
Make sure the new parts are ethanol compatible , that’s what destroys carb diaphrams .
S
Skip & Lynne
Well I think my diaphragm is bad what do you folks think
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
S TR2/3/3A rear main seal is leaking Triumph 13
R TR2/3/3A Leaking O.D. section of Transmission Triumph 43
E Oil leaking from the Tachometer cable Austin Healey 5
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
drooartz Leaking 5-speed drain plug Spridgets 26
S TR2/3/3A and the radiator was leaking. Triumph 7
H TR4/4A Leaking ft hub seals Triumph 5
D BT7 rear wheel leaking Austin Healey 25
N Leaking Carburettor Austin Healey 11
B MGB Hif’s Rear leaking gas MG 11
J TR4/4A Head leaking water Triumph 14
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
C TR6 Brake servo leaking Triumph 3
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
R soft plug leaking Austin Healey 45
George Zeck Master Cyl Leaking .... Spridgets 5
M TR2/3/3A O/D brass cap leaking Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
rjc157 Leaking steering box Austin Healey 4
B mysterious leaking of SU HD8 Jaguar 9
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
B Rear Engine Side Cover Leaking Austin Healey 9
D Overdrive Leaking Oil Austin Healey 4
KVH TR4/4A Oil Pressure Banjo Nut is Leaking Triumph 6
H TR2/3/3A Leaking Fuel Pump Sediment Bowl Triumph 5
PatGalvin TR2/3/3A Leaking SUs. Advice badly needed Triumph 15
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Michael Oritt Leaking oil pan Racing 8
T TR6 leaking carb TR6 Triumph 17
TRMark TR4/4A Leaking Drain Tap before I could even get the radiator full Triumph 1
Rob Glasgow Leaking tapered plug on head Austin Healey 8
Scotsman TR2/3/3A leaking front engine plate Triumph 4
bigbadbluetr6 TR6 Carb leaking Triumph 12
M TR2/3/3A Head gasket leaking in two places Triumph 13
Boggsy64 MGB Stormberg leaking like a sieve MG 4
