TR2/3/3A Condenser Quality?
karls59tr
Bronze
Has anyone tried the Distributor Doctor condensers? They are supposed to be a better quality condenser than what is normally available. Anyone have any good "My car died at the side of the road...bad condenser stories."? :coffee:
Yes, I've had my DD condenser for a few years.
While we are looking at the picture....if that "black wire" that is grounded to the plate is frayed and needs replacing how difficult is it to replace? Dosnt look like a regular hold down screw there?:cautious:
With a properly flexible ground wire such as this you can use the condenser screw for the connection to the points plate
I believe I got the wire from Advanced Distributors...It has to have that flexibility.
Distributor Doctor is THE go to man for ignition parts etc. He came up with the red rotor arm without the short out rivet
He runs a TR too
He will also build your distributor to your engine spec if you have upgraded it.
but with my engine rebuild they went for a competition external condenser
B Does anyone still make or sell a quality condenser? Austin Healey 14
nevets Condenser Securing Screw Austin Healey 14
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
S TR2/3/3A What does a condenser do? Triumph 21
2wrench TR6 Help with points and condenser on '74 TR6 -- or better, choices to get rid of 'em. Triumph 25
charleyf TR4/4A Symptoms with bad condenser Triumph 14
T TR2/3/3A tr3 points& condenser#'s Triumph 6
Geo Hahn General Tech Temporary Condenser Install Triumph 7
NutmegCT General Tech Condenser test? Triumph 38
angelfj1 LUCAS CONDENSER FAILURES Triumph 19
Brosky Wedge TR8 A/C Hose Fitting thread sizes at Condenser? Triumph 24
tahoe healey condenser problem Austin Healey 2
Sarastro Continuing with the capacitor/condenser issue Spridgets 15
Sarastro Ignition condenser/capacitor post mortem Spridgets 39
regularman 2nd condenser in a short time. Spridgets 13
TimK Condenser [capacitor] mounted to firewall??? Austin Healey 4
B Condenser retaining screw Spridgets 5
S Wedge Distributor ID issues -- TR7 points/Condenser??? Triumph 8
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
71TR6 TR2/3/3A New Windscreen Glass quality Triumph 6
B Poor quality BE replacement spring boxes Spridgets 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
Got_All_4 TR6 Newly purchased poor quality timing gear Triumph 5
S General Tech Electronic store for quality connectors. Triumph 9
Got_All_4 TR6 Quantum Mechanics John Esposito Quality overdrive parts Triumph 15
steveg High quality hose clamps Austin Healey 3
Jim_Gruber A Quality Piece of Kit for Bugsy IV - Creative Spridget Rear Disk Brackets Spridgets 8
T TR2/3/3A Replacement Floor and Trunk Panel Quality Triumph 14
Bob_Spidell Release Bearing Quality Austin Healey 8
GTP1960 TR2/3/3A Bonnet hinge issue/quality? Triumph 8
B TR2/3/3A Anyone have quality problems with TRF's TR2-4 ball joints? Triumph 10
R Waterpump quality Austin Healey 8
K Ignition parts quality Austin Healey 31
M TR4/4A Chromed parts quality? Triumph 1
Mink TR4/4A Dash/Crash pads - differences in quality between vendors? Triumph 8
M Door Seals: Best Quality and look Spridgets 4
HealeyRick B.M.C. Quality Austin Healey 8
N Spitfire Part quality??? Triumph 6
nevets Question about original Healey paint quality Austin Healey 20
T TR2/3/3A Moss TR3 radiator quality?? Triumph 5
I General TR Help on quality paint brand for steering wheel? Triumph 2
A TR2/3/3A TR-3A Interior Quality Triumph 7
bighealeysource Dayton Wire Wheel quality issues Austin Healey 0
T TR2/3/3A Are Classic2Current TR3 floor pans good quality? Triumph 14
5 Exhaust mount quality Austin Healey 6
I Reproduction tachometer drive quality? Spridgets 4
Mychael Where to buy quality pedal rubbers. Spridgets 2
Scott_Hower TR6 TR6 crank/timing gear quality issue? Triumph 2
T fender quality ??? Triumph 6
