TR6 1973 TR6 - broken choke cable
MartyN
1973 tr6 - I have a broken choke cable already bought a replacement and looking for some wisdom (advise) prior to replacing. Thanks in advance!
What part is broken knob or split to two ?? When installing choke cable one or two there is an adjustment as not to go past full off and if that happens you have some amount of choke and if just one carb is set correct the other my be running richer. The sleeves can be tricky at the clamp you may also try to lube before install. it can be a fine line.
Mine broke on my 1973 TR6 so I just cut off one cable and choke one carb to start maybe ten years ago
The sleeve is worn out and whoever owned it prior to us used electrical tape but that just keeps coming off.
Hey Marty, you posted your question in our "FORUM Help forum" which is a forum for asking questions about...wait for it....the forum! (i.e., how to navigate this site).
Since your question is related to a Triumph TR6 I am moving this topic to our Triumph forum. If you're reading this you are now in the Triumph forum (I will leave a "pointer" to this post in the original "Forum Help" forum.
Cheers.
Hopefully you ordered and receive the correct cable for the 73 thru 76 carbs.
Along the lines of what "Madflyer" described...you may not get it right the first time...where both carbs choke is full off when you push the dash knob to OFF...keep at it until completely OFF looks like in the top picture where SRZ is in firm contact with AB. And in the lower picture at FULL choke SRZ in contact with the brass STOP.
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
M TR6 1973 TR6 Coolant Type? Triumph 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
M Wanted Tr6 1973 Triumph Classifieds 2
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
sundown TR6 1973 Tr6 alternator Triumph 6
B For Sale 1973 tr6 Triumph Classifieds 0
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
W TR6 1972 or 1973 TR6 Triumph 9
sundown TR6 1973 TR6 plugs Triumph 4
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
sundown TR6 1973 TR6 blow by or leak? Triumph 6
sundown TR6 1973 TR6 flasher question Triumph 6
sundown TR6 1973 tr6 Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
sundown TR6 1973 TR6 seats Triumph 1
sundown TR6 1973 TR6 vacuum reading Triumph 2
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 bypass valve Triumph 1
sundown TR6 1973 TR6 fuel pump Triumph 4
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 1973 TR6 hydraulics Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
sundown TR6 1973 TR6 timing light Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
sundown TR6 1973 TR6 brake booster hose Triumph 7
sundown TR6 1973 TR6 charcoal canister Triumph 6
B TR6 1973 tr6 water pump Triumph 4
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 1973 tr6 Triumph 8
sundown TR6 1973 tr6 Triumph 5
sundown TR6 1973 tr6 Triumph 0
sundown TR6 1973 tr6 oil pressure light Triumph 3
sundown TR6 1973 TR6 flasher unit Triumph 1
sundown TR6 1973 tr6 wiring Triumph 21
jerrybny TR6 1973 TR6 Seat Covers Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
JoeC TR6 1973 TR6 parts car Triumph 2
jerrybny TR6 1973 TR6 Front License Plate Bracket Triumph 1
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
S Stag 1973 Triumph Stag Triumph 2
R TR6 1973 Final drive issues Triumph 5
