What's behind door number two....
mrv8q
Whilst starting to refresh the sad interior in my '6, I popped off the interior door panel. and was very surprised at what I found:
I've been behind many 70's era door panels, and I've never seen anything as elaborate as this, plastic sheeting around everything, and a sliding sheet of it under the window, traveling up and down with the window travel. Thankfully no rust, just dust. Really surprised me; I'm not looking forward to putting the new handles on. Anyway, thought I'd share my surprise....
One of my winter projects, was to cure an annoying rattle in my passenger side door. I glued a piece of fuzzy side velcro underneath the long rod at the top of the door. Rattle B. Gone
Mine before I restored both inner doors.
Click to enlarge photos:
Kevin,
That's in surprisingly good shape. Usually the plastic has all fallen down or been torn up. I re-did my doors last year: added sound deadening and new window channels the cheap way. You can see the steps here https://tr6.danielsonfamily.org/WindowChannel.htm including how easy it is to get those door handles and window cranks back on........well.....as long as you don't re-use the springs
Yeah, that's what I thought! Good to see you on this list too, Bob. Your website is a beautiful thing to behold, a constant source of good information, well executed !
So Kevin,
We've seen door #1, but what is inside door #2? Did they do both sides the same way?
Paul, right now the car's on jacks, and the driver's side is just barely accessible, stuck next to boxes of baby stuff .... at the rate I'm proceeding now, I'll have an answer for you in about 6 months!
BTW, your car's looking great!; I love all the updates!
Thanks. Hopefully it will be done very soon and I'll fade away and we can watch your project in process.
My Door #1 (drivers) goes "clank" and my Door #2 (passenger) goes "thunk". It's a '76 so I expect there were some sort of side impact beams but there's no evidence that either door has been replaced. Does anyone have a picture of an "early" and a "late" door so I can compare what should be there?
I can tell you that on the '74, there is some evidence of a side-impact beam.... don't know how stout it is, though...
Does this help? It's probably the lever rod going from the door handle to the latch that's hitting and making the noise that you speak of. Something is loose and it's rattling around in there.
The second picture is how I sealed mine with a vapor barrier after replacing the regulator and door latch rods, etc.
Direct from Home Depot! Heavy mill plastic, cut to form with scissors and a little spray adhesive on the door. Hit with a heavy duty heat gun set on high for a few minutes and it shrinks right down, drys the glue and the plastic is a sealed vapor barrier just like in the GM cars of the 60's-90's (less the good seal, of course!)
Protect those new door trim panels!!
T TR2/3/3A What is the purpose of the groove behind TR3A door ? Triumph 6
petnatcar Air Scoops Behind the Grille Austin Healey 0
M Getting behind the dash on BJ8 Austin Healey 4
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
AngliaGT What Goes Here? - Holes Behind Rear License Plate Mount Spridgets 3
M Rattles behind dash Austin Healey 4
Keoke Cars keft behind turned to rust by mother nature Austin Healey 8
RickB MGB Rain water getting inside behind dash MG 17
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
HealeyRick Behind the Ton Up Boys British Motorbikes 0
J TR5/TR250 Hey Pat, you are getting behind Triumph 0
pkmh BJ8 - Removal of existing Key Washer behind castellated nut Austin Healey 20
Jim_Gruber Looking for Pics of behind Grille/Bracing,Crossmembers for an early '58 BE Bonnet Spridgets 20
D Codes behind the dash Spridgets 5
E Interiors what is back behind Austin Healey 4
bighealeysource calling any BN2 owners- room for top behind seats? Austin Healey 14
T Does stock fuel pump fall behind consumption? Triumph 10
zedvictor1 Those fender holes behind the RB Spridgets 6
KVH TR4/4A TR4A--Padded Rear Interior Panel--Behind The Seats Triumph 5
Jim_Gruber Picture of Shut panel behind front wheel Spridgets 9
T Gasket behind servo aluminum spacer? Triumph 5
P Clean behind the Grill on a 100 Austin Healey 3
58Custom 1969 Heater air inlet behind grill- pix? Spridgets 37
TR6oldtimer What's lurking behind the wings Triumph 7
Jim_Gruber Need Light Bulb Socket / Turn Signal / Behind Dash Spridgets 1
B A little lever behind the carburetor?? Spridgets 7
Popeye What is this funny thing behind the rear wheel? Triumph 15
T The horrors behind nice primer - Pedro was here Triumph 4
timbn2 He looks natural behind the wheel... Austin Healey 6
pcanonge Seat Cushions for a big behind!!! Jaguar 3
6 waaaaaay behind plan Triumph 2
B Hidden cd player/radio behind blanking plate? Austin Healey 23
V Are all the Jag Posts a few days behind? Jaguar 1
MadRiver Great day spent behind the wheel Triumph 5
AUSMHLY Finally behind the wheel Austin Healey 3
jlaird Hole behind seat Spridgets 2
R Threaded holes behind cockpit. MG 9
KLUTZ Clunk Clunk from behind me over bumps?? Triumph 4
pan Door Shut Face Panels Austin Healey 0
D Door Lock Tumbler Austin Healey 4
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
