What kind of blast media?
bash
I just picked up a cheap siphon type sandblaster at Sears, after finally getting fed up of my rusty wheels. Can anyone give me some idea what is the best way to go with the media I use? The wheels are standard TR6 steel rims, with surface rust bad enough to make them feel a bit rough. I tried wire wheeling one, and it got rid of the rust, but left a slightly dimpled surface. I was just going to go to the builder's yard and buy a bag of sand, but after reading some articles online I am not sure if that is a good idea. Should I go with glass beads? Aluminium oxide? Black beauty? Or just some sand and a face mask?
As always, any advice is much appreciated.
Alistair
AL. Oxide would seem best, its cheaper than the glass beads.
While you could use sand, that has both health consequences due to the possibility of silicosis and the salt residue may promote rust.
May I ask how much it was? I've outsourced a lot of blasting this year (calipers, wheels etc) and think it may have been cheaper to buy my own?
Thanks.
I've heard good things about Black Beauty, though I'm unable to source it locally. Aluminum Oxide is the next best choice. Regular sand I would only use outside with a good face mask only as a last resort.
Black Beauty, Black Magic, Black Blast, et al are all a form of silicon carbide. The stuff is great. I am using it to blasst the body and frame of my spitfire. I get mine at Menard's are about $6 a bag. So far I have used about 300# for the entire project. A siphon blaster is going to be slow going however. I tried one for all of about an hour before deciding to pop for the pressurized type. Much faster.
Baz, I picked up my pressurized unit for $108. It is a 10 gallon unit and a load of media will last about 20-30 minutes. Longer if you use less pressure and a smaller tip.
Thanks for the input guys - now the next question seems to be what sort of place sells the various types of media locally? I just hate paying shipping, especially for heavy bags of sand-like powders! I asked at Home Depot and Lowes and got only blank stares...
Okay, never mind - just asked at the local independent hardware store and they had 100lb bags of black beauty for $10. Can't be bad!
Cheers
Alistair
[ QUOTE ]
...100lb bags of black beauty for $10. Can't be bad!
[/ QUOTE ]
/ubbthreads/images/graemlins/iagree.gif
Here in the UK I paid 4 times as much for less than half that quantity.... almost as bad as the petrol prices here.... /ubbthreads/images/graemlins/frown.gif /ubbthreads/images/graemlins/crazy.gif
bash,
Be careful when using the media blaster. Keep the tip moving all the time. Don't try and clean all the way to bare metal by sitting in one spot. take it off in layers. There was a great thread here on BCF about media blasting. I'll try and find it and edit in a link for you.
Bash, can't find the link but here is the text of the post. Credit given to original poster. Not my work.
Only three months late coming into this thread, but I thought I'd throw in my few years (over twenty) experience at sandblasting..
I avoided the word "media blasting" because I have not used anything that would cut rust like sand does.. Word of note, one must use the finest sand available (I use #4 when I can get it, #3 the rest of the time.. It is available at professional builder supply stores --not Home Improvement stores)
I use two "types" of methods.. the first is a 100lb capasity pressure blaster (requires a minumum of a "real" Five HP Compressor (not a 5hp motor with three capasitors fitted to it). Plus, my compressor is a twin cylinder, Two Stage with an 80 gal tank and my pressure blaster will "work" that compressor.. but the compresor "stays ahead" of it.. That's the key to getting finished with your car and parts.
I blast the "hard parts" (frame, suspension parts, etc.) with the fresh, sharp sand.. as the sand wears into a finer grit, I start blasting the sheet-metal. I use 60lbs psi max input to the pressure blaster and ALWAYS use a "low angle" and NEVER hold the nozzle on one spot or area more that a few seconds as this is what causes panel warp! I "wave" the nozzle back and forth, allowing it to remove one layer of paint at a pass.. for stubborn paints or rust, keep "waving", eventually it will come off. Don't "rush" the job as that WILL warp a panel.
As that sand continues to be beaten down finer, I then move to the nuts, bolts, washers (yeah, I sandblast those as well! Especially the hard to get Whitworth) interior trim and garnish mouldings.. The sand is almost a powder by this time, it is a very dusty environment. but the powder produces a satin-like finish on the pieces, enough to give "tooth" for the paint to stick, but no scratches or pits are produced.
In order to "preserve" the sand for multiple uses, I simply bought some rolls (20'x100') of clear plastic sheeting and cordoned off a corner on my shop. I used 1x2's to tack the plastic to the ceiling and the two corner walls. The "open" area is attached at the ceiling.. Try to use one continous sheet for the perimeter walls then weight down the sheeting at the floor.. I found that "to be blasted" parts work rather well.. This way, the sand can be scooped up, strained, and reused about 3-4 times. Overlap the "opening" by at least ten feet. This helps reduce the dust "seeping" out into your garage or shop.. It isn't 100% effective, but better than nothing.
While some "dust" does escape, it is minimal (don't be doing any painting while sandblasting!!)
I usually buy ten 100lb sacks of sand at a time.. When doing the "hard parts" I only use "new" sand.. I scoop it up and place it into a 55 gal steel barrel that has a removable top. This allows me to then use the "beaten down" sand during the "next phase" of blasting.
It also goes without saying that proper protection be worn at all times, hood, resperator, rubber gloves and I order the full Tyvek suits, If I'm careful about taking the suits off, I can reuse them about a half-dozen times, at least... they help keep your clothes cleaner and the wife happier.. Sand isn't good for washing machines, either.
On the Cabinet Blaster, all come with a suction feed type blasting gun.. It's totally useless as it takes forever.. I simply cut a hole in the side of my cheepie plastic cabinet (bought new for less than $100 at Harbor Freight) and, after removing the nozzle and on/off valve from the end of the blast hose, I fed the hose from my pressure blaster into the cabinet, then replaced the nozzle and valve.
I also use my H-D Shop Vac.. it's about 80% effective except when using the "powder" sand.. then it's about 30% and requires more frequent cleanings of the filter.
Speaking of which, the most important thing about using your shop vac on your blast cabinet is to get a couple of (not cheap) optional paper filters that go over the vac's suction intake to the motor.. Failing to do this WILL result in sand eating your motor in short order. Plus, the paper filter MUST be cleaned frequently, least it clog up, losing it's suction, resulting in a contained dust cloud in the blast cabinet.
The replacable PVC (PCV?) "covers" that tape to the inside of the viewing window are a MUST as well. I don't trust the double-sided tape that comes with some covers, I add a strip of masking tape, overlapping at the corners, completely around the permiter of the "cover".. failing to do this will allow sand and dust between cover and window, resulting in poor visibility and additional scratches on the window... the pressure blaster will frost a "cover" in no time.. cheaper than replacing the viewing window.. not by much, but easier.
A resperator is a MUST even while using the blast cabinet as they aren't as "tight" as they are suppose to be.. and Silicosis is a permanent death..
Something you all should know, but, like me, probably forget.. Once your part is sandblaster, NEVER touch it with your sweaty, greasy hands, unless you like rust growing out from under your fresh paint. Go to your local pharmacy and buy a box of "Exam Gloves".. these aren't Latex.. Plus, get the "Unpowdered" type.. A little harder to put on your sweaty hands,but less residue to remove from your, now, "in-the-white" metal.. Blow off the parts with double filtered air (I rigged up a "clear type in-line" paint gun filter to a "Quick Disconnect".. works great..just keep an eye on the dessicant, once it turns color, dispose and replace). After the dust is blown off, wipe down the part with a product like PPG's "Cleaner/degreaser". I've tried the Eastwood "Pre-Prep" stuff with mixed results.. go with what works and doesn't cause you extra work.
Tack-off the part just prior to priming.. which needs to be done within 24 hours of sandblasting. Now, having said that, I have left parts "raw" for up to four months (in north central Texas) in the enclosed sand-blast area.. the sand acts as a dessicant and helps holds the humidity down.. The plastic walled enclosure helps keep the moist air out. Each regional area will vary.. best to prime the part quickly.
Sorry to be so windy, but, to be done correctly, one must look at sandblasting as an art like body-work, painting and quality mechanical repairs... all require careful attention to the details to "get it right"..
I hope this is a help and a benefit to those so interested.
Particularly with the suggestions for having a sufficiently large compressor and tank, and for the amount of dust and mess the process creates.
Reusing the grit too- starting with the big things to blast and moving on to the finer stuff. But I still use beads for things I need to be careful with. When alls said and done the cost of the media is still relatively cheap....
I don't agree with using plain sand- you can do it, but the health warnings are clear.
Resurrecting an old thread -- We're now 12 years down the road and there seems to be a lot more choices for blasting media such as soda and walnut shells. What are everyone's thoughts? I found the walnut shells interesting as I imagine they would be environmentally friendly and I'm operating my blaster in an open environment.
Media blasting as opposed to sand blasting.
I have been using Clean Bite from Northern tool. It is crushed glass and you gdo not get as dirty as the Black Diamond makes you. Works well. I do reuse it when I can.
David
I use glass media from Tractor Supply. I do not have a blast cabinet. I normally only blast small projects at home, the locals would not blast these wheels with the tires on.
I posted the following reply to another thread last month:
I use my own form of "dustless" blasting. I use a pressure tank blaster and glass media. I hold a water nozzle set to mist in front of the blast nozzle. I spread some cheap tarps on the driveway. I have a fenced concrete apron area in front of my shop. The water seems to drop the spent glass and paint onto the tarp. I wait a few days for the water to evaporate then sweep the tarps. After blasting I blow off the piece with compressed air and apply Eastwood After Blast. I don't know of any method besides blasting to clean some projects. Manure spreader wheels were my last blast project.
I ended up choosing glass bead from Harbor Freight. Tried my hand at it this evening: Very messy, but very effective. I need a better blast hood for myself. The one I have has on open slot, so you have to wear goggles and a mask underneath the hood. Needless to say, the goggles fogged up and basically made it so I couldn't see anymore.
I am using the hood from HF (the red one)and I replaced the lense with some thin Lexan from a Big Box store when it got so pitted I had a hard time seeing. TYou still need a mask.
Lexan does not shatter like perspex.
David
David
My HF mask came with the lens missing :mad:. Of course, I didn't realize that until after I had used it. I do have some plexi in the garage and was going to put a new lens in. I also ordered a more upscale blasting hood, since I'm going to be doing an awful lot of it.
equiprx BUG EYE SPRITE, One of a kind print, Signed by the photographer Austin Healey Classifieds 0
JPSmit Kind of an engine question Spridgets 11
Sarastro TR4/4A What kind of wood and finish for the dashboard? Triumph 20
P TR2/3/3A Wheel hop of the unconventional kind Triumph 6
S TR4/4A What kind of oil in overdrive gearbox? Triumph 5
A TR6 be kind Triumph 5
T TR4/4A Yeah, I kind of bought another TR4. I wasn't looking - honest. Triumph 43
C The 1956 Jaguar XKSS was one of a kind Jaguar 10
K TR4/4A What kind of restoration? Triumph 15
B TR6 Does a 75 amp alternator require a wiring upgrade of any kind? Triumph 3
S TR6 It's alive! [kind of] Triumph 2
D T-Series Let's play "What kind of transmission does this go in?" MG 1
D What kind of paint.... Spridgets 55
Patrick67BJ8 Spark Plugs for '67 3000....what kind? Austin Healey 23
TR4nut My od probs, kind of like Toms! Triumph 14
JPSmit My kind of Rat Rod Other Cars 4
PC my kind of shooting brake Spotted 13
I What kind of grease do I need for wiper motor? Spridgets 5
smaceng What kind of car is this? Other Cars 8
V What kind of battery? Spridgets 6
I What kind of glue to use for ribbed bugeye panels? Spridgets 7
drooartz sorta kind ish maybe looking for a RHD Bugeye Spridgets 8
HealeyRick My Kind of Gal! Austin Healey 12
58Custom What kind of wheel is this on this Midget? Spridgets 2
tr6nitjulius Resto..of another kind! Triumph 4
aeronca65t A "GT"--what kind? Spotted 3
bighealeysource steering effort kind of jerky on new restoration Austin Healey 5
Tr3aguy What kind of Media? Triumph 4
T a new kind of transmission? Austin Healey 3
T Can you tell what kind of car this is Triumph 9
V Datsun gearbox: what kind of oil do you use? Spridgets 10
Dadandson What kind of thread is this??? Spridgets 13
regularman Its kind of cool when you google Spridgets 3
tomshobby TR4/4A TR4 help of a different kind. Triumph 9
O what kind of car is that?producer? Other British Cars 10
C Gorgeous and One-of-a-Kind AH100 [49 photos!] Austin Healey 2
B What Kind of Clutch Fluid? Spridgets 4
Baz What kind of sadist...... Spridgets 25
C What kind of roll bar is this? Spridgets 12
7 What kind of ignition system are you using? Triumph 39
J What kind of compound to use as wing2body sealing Triumph 6
Sherlock What kind of truck is this? Other Cars 10
toysrrus Hey; "Kind of Blue"!! Triumph 1
Luke_Healey How do I figure out what kind of brake fluid? Spridgets 24
spartan0199 What kind of cars do Healey owners drive? Austin Healey 63
H TR6 TR6 Up-date... she's running... kind of... Triumph 4
jlaird And now for a different kind of question Spridgets 14
roofman A new kind of Ebay scam? Triumph 18
J what kind of paint[s] should I use Triumph 7
jlaird Kind of cool but I am ready Spridgets 1
