What kind of thread is this???
Dadandson
I need to know the thread of stock valve adjusting screws on a 74 1275 OEM rocker arm. It appears to be a 9/32-26 British Standard Fine Thread. All of my handbooks show this thread is obsolete! Can anyone help? Could it be a M7 X 1.0? Thanks
Wow! I know the answer, but can not pull it from my brain. The answer came about as we were discussing the click-adjust tool.
Maybe it will spring back into my head in a minute.
OK, I made a call. Apparently, last time we discussed this we never found a proper answer and the person used a "work around".
I doubt it is a metric thread. Are you looking for a tap?
Dadandson
Dadandson
Yes. I can purchase a tap, if it is metric, but I would like to confirm thread size first. The .275" major diameter does work to 6.98MM and there is only one thread pitch, 1.0, for 7MM thread. I am engineering and manufacturing, what I hope to be, affordable roller rocker arms for A series motors. I am very close right now. The key to my product would be a "No machine" one for one swap with the stamped rocker arms. No extra parts to buy unless the OEM parts are worn. They even fit under a stock valve cover!
Well... right there it is (as you said) BSF 9/32-16.
BTW, if you are making custom rockers, what lift ratio are you "aiming" for?
Dadandson
Dadandson
My goal is to increase the ratio, maybe 1.2 or 1.3:1, but not to point of having to machine the head for push rod clearance. Remember, I want to install these rocker arms without removing the head. I think that would be the appeal of these.
Can't you get almost 1.3 with offset bushings?
Dadandson
Dadandson
Offset Bushings? Do you mean an out of concentric bushing in the rocker for the rocker shaft? Sounds like some machining involved.
No machining required, but they would need to be precisely placed when pressed into place.
Dadandson
Dadandson
I have never seen these before. Question: I have maintained the stock dimension from the center of the rocker shaft to the center or contact point of the roller on the valve. I have found that moving the adjusting screw .100" closer to the fulcrum increases the valve opening by .046". Do these bushings move the rocker .100"?
I dunno how much they move the rocker. Call David at APT and ask him. Or contact Hap, he might know.
equiprx BUG EYE SPRITE, One of a kind print, Signed by the photographer Austin Healey Classifieds 0
JPSmit Kind of an engine question Spridgets 11
Sarastro TR4/4A What kind of wood and finish for the dashboard? Triumph 20
P TR2/3/3A Wheel hop of the unconventional kind Triumph 6
S TR4/4A What kind of oil in overdrive gearbox? Triumph 5
A TR6 be kind Triumph 5
T TR4/4A Yeah, I kind of bought another TR4. I wasn't looking - honest. Triumph 43
C The 1956 Jaguar XKSS was one of a kind Jaguar 10
K TR4/4A What kind of restoration? Triumph 15
B TR6 Does a 75 amp alternator require a wiring upgrade of any kind? Triumph 3
S TR6 It's alive! [kind of] Triumph 2
D T-Series Let's play "What kind of transmission does this go in?" MG 1
D What kind of paint.... Spridgets 55
Patrick67BJ8 Spark Plugs for '67 3000....what kind? Austin Healey 23
TR4nut My od probs, kind of like Toms! Triumph 14
JPSmit My kind of Rat Rod Other Cars 4
PC my kind of shooting brake Spotted 13
I What kind of grease do I need for wiper motor? Spridgets 5
smaceng What kind of car is this? Other Cars 8
V What kind of battery? Spridgets 6
I What kind of glue to use for ribbed bugeye panels? Spridgets 7
drooartz sorta kind ish maybe looking for a RHD Bugeye Spridgets 8
HealeyRick My Kind of Gal! Austin Healey 12
58Custom What kind of wheel is this on this Midget? Spridgets 2
tr6nitjulius Resto..of another kind! Triumph 4
aeronca65t A "GT"--what kind? Spotted 3
bighealeysource steering effort kind of jerky on new restoration Austin Healey 5
Tr3aguy What kind of Media? Triumph 4
T a new kind of transmission? Austin Healey 3
T Can you tell what kind of car this is Triumph 9
V Datsun gearbox: what kind of oil do you use? Spridgets 10
regularman Its kind of cool when you google Spridgets 3
tomshobby TR4/4A TR4 help of a different kind. Triumph 9
O what kind of car is that?producer? Other British Cars 10
C Gorgeous and One-of-a-Kind AH100 [49 photos!] Austin Healey 2
B What Kind of Clutch Fluid? Spridgets 4
Baz What kind of sadist...... Spridgets 25
C What kind of roll bar is this? Spridgets 12
7 What kind of ignition system are you using? Triumph 39
J What kind of compound to use as wing2body sealing Triumph 6
Sherlock What kind of truck is this? Other Cars 10
toysrrus Hey; "Kind of Blue"!! Triumph 1
Luke_Healey How do I figure out what kind of brake fluid? Spridgets 24
spartan0199 What kind of cars do Healey owners drive? Austin Healey 63
H TR6 TR6 Up-date... she's running... kind of... Triumph 4
jlaird And now for a different kind of question Spridgets 14
roofman A new kind of Ebay scam? Triumph 18
J what kind of paint[s] should I use Triumph 7
jlaird Kind of cool but I am ready Spridgets 1
jlaird Here is a new kind of question Spridgets 7
