What does Inspector Lynley drive?
smcmanus
I watched a mystery on PBS last night called "The Inspector Lynley Mysteries." It was lame compared to Inspector Morse or any Agatha Christie stuff. Lynley is a real pretty boy with a huge coif. His car is a plain but attractivelooking british 2 door sedan with a very long hood. I've never seen another car like it. Does anyone know what it is?
Thanks
Steve
Its a Bristol 410, circa 1968/9.
General Info:
https://www.practicalclassics.co.uk/profiles/vehicle/picture.ehtml?i=486;p=326174655
Thanks for the info. I wonder if any of these were imported to the US? It is a "handsome" car; I guess that's how best to describe it. I wonder what is under that long hood?
Have a nice day
Steve
If I have the right car in mind, it should have
a Chrysler 318ci V8...
SteveL
/ubbthreads/images/graemlins/iagree.gif
I don't think these were exported to the USA.
That said I did see a mid-'50's Bristol 405 sportscar that was someone's project back in the mid-1970s. Don't know whatever happened to it, hope it survived.
In the first couple of series he drove something completely different, still a classic, but what it was has completely escaped me! In the books he drives a Bentley. The books, by the way are 500 times better than the TV show, they're much more in line with Inspector Morse and Prime Suspect, very gritty and realistic. The TV show went for soft viewers instead of true afficiandos.
RG /ubbthreads/images/graemlins/england.gif
[ QUOTE ]
[/ QUOTE ]
I believe that it was a Gilbern Invader, though I've not been able to find any reference to it....
[ QUOTE ]
I believe that it was a Gilbern Invader...
[/ QUOTE ]
Opps... that was wrong, I think. The Jensen list has had a few comments on its having been a Jensen Interceptor...
but I still thought it looked a lot like a Gilbern...
Perhaps Lynley's working his way through Classic saloons....
Thanks
Steve
First car in the series was a Jensen Interceptor - V8 Chrysler engine.
Probably worth mentioning the Internet Movie Car Data Base
L What does this column switch do? Spridgets 4
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
J MGB HELP, my horn does not work! MG 8
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
S TR2/3/3A overdrive does not function Triumph 45
Bayless How does '67 Sprite top attach to body? Spridgets 3
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
B General MG Does odometer record when flat towing. MG 5
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
T Does a car lift exist that could be placed against a wall, and the car rolled sideways onto it? Spridgets 16
TomMull TR2/3/3A rear mount does not line up Triumph 10
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
JPSmit Fuel tank sender - how does it work? Spridgets 4
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
NutmegCT Does this ad seem a bit peculiar? Other Cars 8
S TR2/3/3A What does a condenser do? Triumph 21
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
D Does this count as British car? Spotted 18
BN6_2197 How does the flasher unit work Austin Healey 4
J TR6 Does this sound ok to you? Triumph 5
BN6_2197 Analyzing Problem of Flasher Unit [warning lamp does not work] Austin Healey 10
B Does anyone still make or sell a quality condenser? Austin Healey 14
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
F How does overdrive Annulus effect speedometer Austin Healey 10
T General Tech Transmission Countershaft - What Car Does This Fit? Triumph 1
D Does a BJ 8 need a vented fuel cap? Austin Healey 4
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
B MGA What does this founder mark mean? MG 4
D TR2/3/3A Gas tank does not fit! Triumph 4
Got_All_4 TR6 How does this steering lock come off Triumph 9
Gerry M TR6 Overdrive does not engage Triumph 13
HighAltitudeTR3 TR2/3/3A How does this sound?! [Video] Triumph 8
C TR6 ZS 175 What does this screw do? Triumph 2
HealeyRick Who Knew Martin Jansen Does Bikes? Austin Healey 0
Rut How much does a 1275 weigh? Spridgets 8
JPSmit Fuek Tank Sender - does this seem right to you? Spridgets 3
HighAltitudeTR3 TR2/3/3A How does this sound?? Triumph 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
D TR4/4A how hot does the timimg chain cover get? Triumph 15
D TR4/4A Does a bolt legend exist? Triumph 3
Rut How does this happen? Spridgets 9
Michael Oritt Does anyone drive with bias-ply tires? Austin Healey 40
simon1966 Does anyone use 48 spoke wheels on a 100? Austin Healey 21
T TR2/3/3A Does your rotor wiggle Triumph 15
M TR2/3/3A Engine does not shut off right away. Why? Triumph 8
