TR2/3/3A Wet liner issues
Stratty
Cheers everyone.
I recently encountered a blown head gasket in my 1956 TR3 to find out the #4 wet liner protrudes above the block well past the specs causing the head to leak. Now that it's apart and I'm sure that's the issues. I can't seem to make it sit low enough (within spec) Can anyone shine some light as to how you remedied this problem?
Thanks
Chris
TR3driver
Great Pumpkin - R.I.P
How high is it?
Have you tried clamping it back down? I've never had a liner come up when pulling the head, but I suppose it's possible. (I've also never had just one be too high.)
If its only a thousandth or two, you can try laying a sheet of fine sandpaper on a flat surface (like a sheet of glass) and rubbing the top of the liner on it. Keep turning the liner as you work, so you remove metal evenly.
But more than that probably calls for either a machine shop to cut it down or a replacement liner.
Another option might be to contact Mordy Dunst and see if he can make a "split" fig 8 gasket with different heights.
https://www.headgasket.com/
Or here's a way to make your own
https://www.tonydrews.com/uncle_jacks_engine_building_tips.htm#Fig8
TomMull
I assume you've checked for corrosion or debris on the liner seat in the block. I'd look with a strong light and a wire brush on a die grinder. Tom
DavidApp
Hello Chris
I presume the engine is all apart not just the head is off. With calipers you could check that the liner matches the others. Also make sure the faces that meet at the Figer of 8 gasket are totally clean.
If it is just the head that is off do not turn the engine with out clamping the liners down. It is possible to move them.
David
CJD
Do you have the history on the last rebuild?
The F08 works for a pair of cylinders, so the #3 would also be high if the F08 gasket was double up. I would suspect that at some time the block was decked to true it, and the associated sleeves were turned down to match. Later, if a sleeve were replaced without knowing it needed turning, it would cause your issue.
That’s the complicated guess.
The simple guess is that some debris is caught under the #4 liner and the block. A bad seal at the base of the sleeve could give similar symptoms to a blown head gasket.
charleyf
I will second Tom's comment about dirt or corrosion built up on the seat. I was amazed at how much "stuff" was on that seat when I cleaned the last block. If that seat was not cleaned it could easily have some build up where the figure 8 gasket is sitting on it to raise the whole liner. Clean it and make sure it is clean all of the way to the vertical wall. Some of that corrosion could be parts of the old figure 8 gasket.
sp53
I would guess the 2 problems are not totally related yet anyway, and when you pulled the head-- the gasket and liner came up with it. You will probably need to drop the pan and undue the rods and push the pistons up through the top. I would do it that way and leave the crank in and put some new rings on the pistons, unless you want to dive in and replace most everything as needed which is usually an expensive and time consuming job.
I have done just the rings and head gasket a few times leaving the crank and cam in with good results. It just depends what you plans are for the car because if you do a total job, the apron comes off and engine and trans should come out together. Moreover, I would try to see if there was a reason for the head gasket. Perhaps the heat of the weather combined with the age of the car and radiator cooling.
steve
K Figure of 8 Gaskets for Wet Liner Engine? Triumph 5
TR4nut Wet Liner Engines & Valve Interference Triumph 18
D TR2/3/3A Trailering when wet. Triumph 11
Hamish Racing General TR 3 sisters sprint (uk) the wet one Triumph 2
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
J TR2/3/3A Head Torque - Wet or Dry Triumph 6
DerekJ How to drive a Healey in the wet! Austin Healey 6
D TR2/3/3A Sealing Fo8's and Wet Liners Triumph 6
S TR2/3/3A wet sanding and amonut of paint Triumph 13
RickB MGB Crane Cams XR700 Fireball - wet conditions? MG 7
NutmegCT wet insulation Restoration & Tools 9
J Wet carpet Austin Healey 16
2billydavies TR2/3/3A Replacing the pistons and wet sleeves Triumph 15
Frankenhealey Goodwood Spring Sprint - It was WET Austin Healey 11
G Tires for wet conditions Spridgets 4
jsfbond Wet snow conditions Triumph 3
M Wet Carpet MG 13
PatGalvin TR2/3/3A Wet Sleeve to Engine Block Deck Clearance, TR3A Triumph 4
T Think this explains my wet foot? Triumph 24
K Wet trunk Jaguar 1
livinginthepast Bugeye gets wet and wild ... Spridgets 5
Tabcon Thread Sealer on Wet Liners? Triumph 5
Tabcon Thread sealer on wet liners? Racing 0
equiprx I keep gettting a wet dizzy. Jaguar 1
T Click and Clack are all wet.... MG 2
C Wet left foot? Triumph 8
AltaKnight A wet weekend Triumph 1
RickB MGB-GT 70 BGT floor gets wet when it rains MG 23
beaulieu Wet sandblasting - anyone done it ? Restoration & Tools 1
7 Wet Sanding Austin Healey 22
G Wet & Wild Ride... Triumph 3
AUSMHLY wet rugs Austin Healey 21
Z Tire wet look Restoration & Tools 2
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
Rob Glasgow Boot Liner Edge Finish Austin Healey 11
S Boot Liner - BJ8 Austin Healey 19
L TR2/3/3A Liner spigot fit? Triumph 13
aero3113 100-4 trunk liner kit Austin Healey 4
G Fixings for liner assembly hood comparment -BJ7 Austin Healey 7
TEM666666 Sprite MK1 Door liner rubber mat installation.. Need tips and recommendations. Spridgets 22
Rob Glasgow Armacord Trunk Liner Austin Healey 8
maxwedge5281 bn6 armacord trunk liner kit Austin Healey 4
AHS TR4/4A Looking for piston & liner recommendation Triumph 17
W TR2/3/3A Piston and Liner Triumph 2
T General Tech How loose can a piston liner be? Triumph 2
S Scuttle Liner/ Footwell Cards Austin Healey 10
Gray_Cat Bed Liner As Undercoating Spridgets 2
Tinkerman TR2/3/3A TR 3A Battery Box Liner. Drain Holes? Triumph 3
Tinkerman TR2/3/3A Battery Box Liner TR3A Tip for the Day Triumph 5
