    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
TR2/3/3A Piston and Liner
wildtr3a
Does anyone know if the AE piston and liner kit, part number AESA1710KR, 87 mm, comes with three rings or four rings?
FYI, in my How to Restore a TR3/3A book, the author, Roger Williams, recommends against using the pistons with 4 rings since they are Vanguard pistons/rings, not meant for higher powered Triumphs. Sorry, I do not know about AE pistons.
Regards,
Bob
3 rings. Good set of Pistons and liners there.
AHS TR4/4A Looking for piston & liner recommendation Triumph 17
T General Tech How loose can a piston liner be? Triumph 2
M 87mm piston n liner Triumph 1
TomMull Piston and liner kits with steel FO8 gaskets Triumph 9
TomMull piston and liner kits Triumph 11
J Question on piston/liner sets Triumph 2
M Mahle piston and liner kit ?? Triumph 11
KVH TR4/4A Piston Liner Protrusion TR4 Triumph 19
B TR2/3/3A TR3 piston/liner advice Triumph 5
Number_6 TR2/3/3A 89 mm Piston and Liner Kit for TR3 Triumph 5
L TR4/4A Looking for a TR3-4a 87mm piston & Liner Triumph 0
K TR2/3/3A Piston slap? Triumph 3
T TR2/3/3A valve guides and piston clearance Triumph 6
Simmo TR2/3/3A Something is eating away at my Piston Liners Triumph 15
D Separating the piston from the connecting rod. Spridgets 9
J Piston Coating Austin Healey 3
KVH General Tech Grant Piston Rings--Can't Fit Them Triumph 15
KVH General Tech Removing Piston Wrist Pin Triumph 2
sail TR4/4A Piston Ring Question Triumph 6
M Wanted WANTED...New TR6 piston set. Triumph Classifieds 2
K TR2/3/3A Brake caliper piston install? Triumph 18
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
J TR2/3/3A 87mm piston ring gaps Triumph 15
Jayplum TR2/3/3A TR3 Piston Sleeves Triumph 36
M TR2/3/3A How many miles to seat piston rings? Triumph 4
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
BJ8Healeys Disc brake piston seals Spridgets 2
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
M TR2/3/3A Please Help ID This Piston Triumph 6
Got_All_4 TR6 Are these piston nitrated coaded Triumph 5
J TR2/3/3A 83 to 87mm Piston Considerations Triumph 7
Gerard 1275 piston ID Spridgets 2
HighAltitudeTR3 TR2/3/3A Piston Slap đź‘‹ Triumph 12
M TR2/3/3A Sleeve and Piston Sizes Triumph 6
Got_All_4 TR6 Depth of the metering needle in the air valve piston Triumph 12
steveg Piston options for Healey Austin Healey 12
T TR2/3/3A SU Piston Drop Test Triumph 4
C TR2/3/3A Piston gap orientation Triumph 2
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
T General Tech Brake caliper - piston stuck Triumph 4
2billydavies TR2/3/3A need an educational lesson about piston rings Triumph 14
KVH TR4/4A Piston Size Measurement on Rebuild Triumph 4
Jake OD unit operating piston rings? Austin Healey 1
JPSmit Brake piston removal - McGyvered some tools Restoration & Tools 0
tinman58 TR6 Piston clearance Triumph 4
T TR4/4A Overdrive piston is sticking Triumph 9
TomMull caliper piston tool Restoration & Tools 11
busybrit TR6 AE Piston supplier, when you only want one ! Triumph 2
