Weird Brake Issue
V
vanderbilly
I'm a new member so please go easy on me. I have a 1956 100 Le Mans and although my brakes work fine, as in stopping the car effectively, I have another strange issue. When the car is cold, it rolls perfectly so I can push it in my garage without any assistance. However after I've driven the car for just a few miles, when I let off the gas I can feel the brakes gripping almost like a regenerative braking system in a modern car. Then when I get back to my house and park the car in the garage, I can't push it at all in neutral. However when I come back in about an hour and the car has cooled off, it rolls freely again. None of the drum brakes seem excessively hot and I don't know what to do. I do have a jack so I should probably drive it a couple of miles, then jack it up and see which wheels are locked up, sorry I just thought of that in the middle of composing this. Regardless does anybody have any experience with a similar issue or any ideas on what might be causing this?
Best regards
Sounds to me like the brake hoses have swollen internally so that the pressure takes some time to bleed off after you have applied the brakes. This is a common problem with Healeys with old hoses.
I would try checking your brake shoe adjustment first, you may have one or more of your adjusters a bit to tight to the drum I.D... Also I would do a general check of the brake springs and fitmemts, wheel cylinders and so on for starters. As mentioned above, old soft brake hoses are known issues as well.
A common cause of this condition is an incorrectly adjusted brake pedal pushrod. The manual specifies 1/8" of pedal free play before the pushrod moves the piston in the master cylinder.
Well I found my favorite new forum and thanks for the quick replies, Honestly I wasn't planning on checking back until tomorrow but I am pleased to see that this forum is active and full of helpful people. The brake hoses sounds like the culprit to me because when it's cold, the car rolls freely. I'll do some more checking and report back once I have some answers. Thank you again.
A misadjusted brake push rod can also roll freely when cold. It will affect all 4 brakes. A restricted hose will affect either one wheel(front) or both rear wheels. It would be a little unlikely to have all 3 hoses causing a problem at the same time.
Back in the 70'S when I first started driving what was then my fathers 100M, I made the mistake of adjusting the pushrod in attempt to improve pedal height. The car initially rolled freely, but I could feel the brakes start dragging the more they were used. If I let the car sit overnight they would go back to normal, and then start dragging again. It took me a while to realize that my 'adjustment' was the cause of the problem.
That's exactly the issue I'm having. Before I try anything I should probably take it out tomorrow and get it up to temp, bring it back, jack it up and check all four wheels to see which ones are sticking. I'll do that, post the results and hopefully that will help narrow it down a bit more. Again thanks for the suggestions. I'm a noob with this car so everyday is a learning experience. I've read the service manual cover to cover, twice.. so at least I'm learning the terminology and how they approached things back in the day. Happy to report that aside from this issue the car runs like a champ and I love driving the **** out of it.
Just a quick update to the watchers that I took the car our to get the brakes warm and the she broke down. Now I have what appears to be either a fuel or ignition related issue so once I get that resolved, I will test the brakes again and repost the results. Didn't want to appear as though I forgot to post brake results.
ALWAYS think simple first.............had same problem..backed off the screw on the tight drum and works perfectly!!!!!!!! I think Drambuie NAILED it...
Pete
If it's a brake hose, just STANDING on the brake pedal (engine off, cold & while still in the garage) and then immediately attempting to roll the car, would be an easy enough test. While the heat may exacerbate the condition, if the hose(s) is/are breaking down internally, that should quickly prove/disprove the swollen theory. Oh, and it's a real thing, because my rear rubber hose__which wasn't really that old__was causing the same symptom (and it only takes 1 wheel/1 axle braking to keep a mere mortal from rolling the car).
Once the car is running again, if you have an infrared temperature gun, pointing it all four (4) brake drums after a spirited drive will indicate corners running significantly temperatures higher/lower than others.
I wonder what the recommended useful life of brake hoses is? Ten years, maybe, or more? Remember when we kept our tires forever as long as they had some tread?
My failed replacement hose was probably somewhere in the 8-12 year range (more likely the 10-12 timeframe); certainly replaced in Ohio not long after getting the car back from Paul Tsikuris/prior to being roadworthy (always a relative term with Healeys...).
I'm hopeful that the Teflon/braided SS hoses aren't subject to deterioration... (they were not yet available__or at least listed**__ for 2-seaters when I last replaced the rubber hoses.
** I believe the rear hose is longer on the 2-seater; obviously the fronts are the same as 4-seaters.
Update to those who are interested. Adjusted the brake push rod and bingo.. brake problem disappeared. Thanks for the help! Now I'm off to install a new gas tank as my 60 year old tank is full of sludge.
Best regards
G'day vanderbilly, and welcome to this forum. We promise to go easy on you! I believe Steve Byers has given very sound advice. The rubber brake hoses can collapse internally so from the outside they look fine. I once had this happen to the clutch on a mini. The clutch was reluctant to take up and gave the impression of a worn out plate. After I replaced the clutch & pressure plate there was no improvement. It was then that I discovered that the hydraulic hose needed replacement. The pressure of your foot is enough to force the fluid through the hose but there isn't enough force from the brake shoe return springs to overcome the blockage. If one hose is suspect, best to replace all three to be sure.
Cheers,
Alwyn
Seein' as how Vanderbilly's post is over seven years old and he's no longer a BCF member ...
Whenever I step on the brakes hard the engine dies...any ideas?
I'm thinking your 1980 MGB has a major problem with the power brake booster!
EricJNewman MGB Weird Brake issue finally solved. MG 1
Raymond weird brake light problem MG 4
JPSmit Vauxhall question - I know, weird eh?! Lotus 6
Rob Glasgow Weird Lucas Headlight Austin Healey 7
H weird things painted by hand with a brush Austin Healey 6
Jim_Gruber Something weird electrically with Bugsy Spridgets 7
roscoe Distributor problem [a bit weird] Austin Healey 15
Rut MGB OK, I must attract weird MG 5
Rut MGB Weird oil question MG 3
P TR6 Another weird problem Triumph 6
T TR4/4A Weird starting issue with my TR-4 Triumph 15
D Weird motor mount?? Spridgets 7
aeronca65t Weird things spotted......not cars Spotted 3
aeronca65t Weird Whatzit Spotted 2
Jim_Newman MSD Ignition and weird run-on Austin Healey 4
GBRandy Spot Free! - am I weird??? Triumph 10
rlich8 What was your weird problem today? Triumph 21
RickB Weird DPO wires heating up really hot Spridgets 16
Robert560 Weird "rough" idle problem after ignition changes. Austin Healey 18
Moseso Weird Hydraulic Failure Triumph 8
eschneider Weird oil leak? Triumph 12
I Weird indicators on BN1 Austin Healey 4
M Weird Happenings w/My Speedo Spridgets 2
bighealeysource engine running weird on my BN6 Austin Healey 6
AngliaGT Isn't it Weird ........ Other Cars 12
T weird oil leak - BJ7 - a question Austin Healey 4
P weird thing with midget clutch pedal Spridgets 3
bcbennett Weird idling problem Triumph 3
jvandyke weird half top, soft targa? Spridgets 10
healeyboz another weird request Spridgets 1
Got_All_4 Weird R&R the turn signal switch and horn blows Triumph 8
G This may sound weird but.... Triumph 15
aeronca65t Tons of weird cars Other Cars 3
rlandrum Weird block holes Triumph 6
John Moore Weird Lug Nut Question Spridgets 9
Morris Weird Cooling Problems Spridgets 15
tony barnhill Today's Weird Question MG 57
Morris Weird paint question Spridgets 14
T Weird realization MG 2
aeronca65t Weird Brit Stuff Other British Cars 20
Mickey Richaud Well, This is Weird... Triumph 16
vping Weird fuel pump MG 13
B Weird Fuel Pump Issue MG 1
ronzet Hot Throttle Linkage [I've got a weird one...] Austin Healey 15
GregW Weird timing light readings Austin Healey 8
77MidgetMkIV Rough running at weird intervals-any thoughts? Spridgets 22
D Something weird with the idle/throttle Spridgets 23
Sherlock Weird Mini fastback in Australia [Mini Monaco?] British Motor Corp 22
tony barnhill Weird Little bug eye Spridgets 8
A How weird is this... MG 6
