MGB Weird Brake issue finally solved.
EricJNewman
I've had this 79 MGB for a couple of years now. Previous Owner had replaced almost all the brake components, and the brakes were still terrible. Good hard pedal, but poor stopping power. Unable to lock brakes at any speed. Dangerous to drive, so they sold it. I checked everything, and it all seemed to be good components, bled properly, but no stopping power. Over several months, I slowly replaced everything even remotely suspect. New booster, Master Cylinder, upgraded calipers and rotors, brake cable, drums and all internal parts at the rear. No improvement. I even replaced nearly all the lines. Finally, I decided to measure the push-rod length to master cylinder play. It was over 1/2" with all new parts. Apparently the new boosters ship with the push rod screwed all the way in. I matched my new length to what I took out, but apparently that was also incorrect. With the little $20 tool for eBay, I was able to measure the endplay between the Booster and MC, and lengthen the rod to where there's just a fraction of an inch gap... Once I reassembled, I was able to lock the brakes for the first time. I did notice that the new booster didn't seem to affect anything, and a pumped up pedal didn't move when I started the car. I found the Vacuum check valve nearly blocked, but leaking in both directions. So with a new check valve, I now have AMAZINGLY GOOD brakes for a change. Don't take anything for granted -- but hope this helps someone else. The Push-rod length is adjustable for a reason, and should be checked after either the MC or Booster are replaced or rebuilt. Safety Fast!
Great tip - thanks for posting, and glad you found the issue!
V Weird Brake Issue Austin Healey 18
Raymond weird brake light problem MG 4
JPSmit Vauxhall question - I know, weird eh?! Lotus 6
Rob Glasgow Weird Lucas Headlight Austin Healey 7
H weird things painted by hand with a brush Austin Healey 6
Jim_Gruber Something weird electrically with Bugsy Spridgets 7
roscoe Distributor problem [a bit weird] Austin Healey 15
Rut MGB OK, I must attract weird MG 5
Rut MGB Weird oil question MG 3
P TR6 Another weird problem Triumph 6
T TR4/4A Weird starting issue with my TR-4 Triumph 15
D Weird motor mount?? Spridgets 7
aeronca65t Weird things spotted......not cars Spotted 3
aeronca65t Weird Whatzit Spotted 2
Jim_Newman MSD Ignition and weird run-on Austin Healey 4
GBRandy Spot Free! - am I weird??? Triumph 10
rlich8 What was your weird problem today? Triumph 21
RickB Weird DPO wires heating up really hot Spridgets 16
Robert560 Weird "rough" idle problem after ignition changes. Austin Healey 18
Moseso Weird Hydraulic Failure Triumph 8
eschneider Weird oil leak? Triumph 12
I Weird indicators on BN1 Austin Healey 4
M Weird Happenings w/My Speedo Spridgets 2
bighealeysource engine running weird on my BN6 Austin Healey 6
AngliaGT Isn't it Weird ........ Other Cars 12
T weird oil leak - BJ7 - a question Austin Healey 4
P weird thing with midget clutch pedal Spridgets 3
bcbennett Weird idling problem Triumph 3
jvandyke weird half top, soft targa? Spridgets 10
healeyboz another weird request Spridgets 1
Got_All_4 Weird R&R the turn signal switch and horn blows Triumph 8
G This may sound weird but.... Triumph 15
aeronca65t Tons of weird cars Other Cars 3
rlandrum Weird block holes Triumph 6
John Moore Weird Lug Nut Question Spridgets 9
Morris Weird Cooling Problems Spridgets 15
tony barnhill Today's Weird Question MG 57
Morris Weird paint question Spridgets 14
T Weird realization MG 2
aeronca65t Weird Brit Stuff Other British Cars 20
Mickey Richaud Well, This is Weird... Triumph 16
vping Weird fuel pump MG 13
B Weird Fuel Pump Issue MG 1
ronzet Hot Throttle Linkage [I've got a weird one...] Austin Healey 15
GregW Weird timing light readings Austin Healey 8
77MidgetMkIV Rough running at weird intervals-any thoughts? Spridgets 22
D Something weird with the idle/throttle Spridgets 23
Sherlock Weird Mini fastback in Australia [Mini Monaco?] British Motor Corp 22
tony barnhill Weird Little bug eye Spridgets 8
A How weird is this... MG 6
