Vacuum Surprise and Then Some
RAC68
When taking a vacuum profile for the selection of a PCV, as a means of reducing crankcase pressure and rear slinger oil seepage, I was surprised to find a rapid flutter vacuum reading between 7 and 15 inches Hg at idle (900RPM). When increasing RPMs, the flutter diminished slightly, however, did not approach a steady reading. Since the engine preformed well and without any indication of any problems, I was very surprised to see this condition.
A friend suggested the condition could be the result of tight valves, and since I had re-bushed and adjusted the rockers 3 months earlier, this seemed to have a high possibility. When extracting the plugs in preparation for the adjustment, I found all plugs but cylinders 2 and 3 to be a perfect color. While I’m waiting for a friend to return my compression gauge, I would appreciate any suggestions.
All the best,
Ray 64BJ8P1
Johnny
Hi Ray, sounds like cylinders 2 and 3 are getting oil in them either from the valve guides or cylinders and fouling the plugs. Doing a valve adjustment won't help this scenario. A compression check might reveal the culprit.
Good luck
RAC68
RAC68
Thanks Johnny,
It seems odd that only these 2 cylinders have worn valve guides or rings but it fits. I was thinking blown head gasket, but if that were the case, why the black plugs? The kicker is that I have not experienced a miss fire or any difficulties pulling to past 5K RPMs. In fact, the engine seemed to be running very well. I should have followed my father’s saying “if the car runs good, don’t lift the hood”.
Thanks again and all the best,
Ray
RAC68
RAC68
Hi Johnny,
You are probably right.
Yesterday, after re-adjusting the valves, I installed the plugs with the black exchanged with light brown ones. After a nice aggressive drive of about 2 hours, I extracted the plugs from the problem adjacent cylinders and found they had not turned black but maintained a nice light brown. Another vacuum reading showed the same vibrating needle between 7 and 14 Inches of Hg.
A friend will be helping me do a leak-down-test to determine the problem a few weeks from now. I will post the results.
All the best,
Ray
why
your father was right, "a difference that makes no difference is no difference." I assume the point of the car is to take it for drives and if it does that just fine.......
RAC68 said:
The picture above was only a test of placing an image in a post.
Ray
Please post larger pictures (640 x 480 pixels is an ideal web size), other wise, good job!
This is 640 x 480:
Sopwith_Camel MGA booster Vacuum MG 8
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
drooartz MGB Question on timing and vacuum MG 11
B Vacuum at Idle Austin Healey 9
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
B Vacuum Source Austin Healey 4
WHT Vacuum Advance Pipe Austin Healey 7
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
JPSmit Today's question - vacuum advance Spridgets 2
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
B Vacuum Advance Pipe Austin Healey 2
Twit TR4/4A TR4 AUC878 vacuum connections Triumph 7
J TR6 Vacuum Retard question Triumph 1
R TR6 Thermostatic vacuum switch Triumph 3
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
M Vacuum Line on a 948 Spridgets 4
S TR2/3/3A Vacuum leak Triumph 19
B Vacuum Servo Austin Healey 19
D TR2/3/3A Vacuum connection at Carb Triumph 23
G TR4/4A Distributor Vacuum Manifold Hard Line Triumph 11
6TTR3A TR2/3/3A Vacuum advance questions Triumph 2
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
D TR2/3/3A Vacuum advance tube Triumph 6
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
C Distributer with no vacuum advance Spridgets 15
Griz Testing Vacuum Advance Austin Healey 5
BJ8Healeys '72 Midget Vacuum Advance Line Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
B TR6 Timing using a vacuum gauge Triumph 13
T MGB Vacuum advance and Electronic ignition conversion MG 5
SherpaPilot TR6 Vacuum Gauge Timing Triumph 5
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
W BE vacuum advance line and fittings Spridgets 2
W Vacuum advance nipple Spridgets 0
Gerry M TR6 Vacuum Lines Triumph 8
GTP1960 TR2/3/3A SU, H6 carb vacuum line connector? Triumph 2
J TR2/3/3A Vacuum lin Triumph 13
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
M Vacuum Leaks Austin Healey 22
bigjones Vacuum advance on a 1500 Spridgets 13
sundown TR6 1973 TR6 vacuum reading Triumph 2
jfarris TR2/3/3A Early 56 TR3 H6 Carbs, distributor vacuum advance/retard Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
