Vacuum Lines and Weber DGV's
arbs_53
My last couple of posts to this forum concerned questions I had as to why I would be getting a different color on spark plugs in the same motor. I'm still trying to sort things out with this engine but I may have found something that would have contributed to a rough idle and inconsistent color on the plugs.
Over the winter, I had a brief discussion with Dave Hagenbush of TRF concerning a comment a foreign car mechanic told me about me having to buy an aftermarket mechanical distributor because of the upgrades I was doing to the engine. Dave set me straight and said that the TR250 distributor, although vacuum assisted is a mechanical device and will work fine with the upgrades provided it had enough advance...maybe I would have to change out the weights and springs if I needed more. He said I should block off the retard vacuum line and to install the advance vacuum line to the Webers, as they have a built-in advance vacuum port.
So, these past couple of days I was thinking about what Dave said and looked through my Haynes Weber book and could not find a reference to the vacuum ports, only that they existed. I did an exhaustive search on the internet and could only find a couple of references to the vacuum ports but not a line as to where they were. So I took the carbs off yesterday and looked them over and found the only things that could possibly be what I was looking for and confirmed it by sucking air through them. And the light went off. All this time, for nearly ten years, these carbs have been leaning out the air/fuel mixture because the advance vacuum ports were open. I purchased some plastic fittings, plastic tubing and a length of 1/8" o.d. copper tubing at the local hardware store and re-routed my advance line to work off the carbs, instead of the intake manifold, a temporary set-up until I can fabricate something that looks better. It idles great now, which makes sense, because being connected to the intake manifold, the timing was being advanced at idle and on throttle up the Webers was sucking in fresh air through the advanced ports, leaning out the mixture, a sure recipe for uneven running. So I'm wondering how others have handled this vacuum problem or am I just waking up to the obvious.
On another, but related note, I have found a dyno shop in my area who is willing to bring my car in to sort through jetting the carbs and getting the timing set properly. I e-mailed them some questions I had and am waitiing for an assortment of jets to come in from the West coast before I make the appointment.
Glad to hear you have solved the problem, possibly others may benefit from your post.
I have a similar lean mixture problem with my 79 Spit with a 40mm DCOE but am not aware of any vacuum ports on that carb; so its likely I need a selection of air correction jets to fine tune it.
Simon.
Dave:
Can't wait to see the dyno results. I bet it stimulates a lot of interest and competition of who's really got the most hp and how to get it.
Dave, why not use the vacumns on your DGVs to suck a negative pressure on your valve cover to reduce the pressure in your crank and block off the vacumn port on your distributor bellow (just for looks) and advance your timing to about 8 degrees BFTDC at 1000rpm. This will also tend to burn off a little of the oil vapor coming out of the engine. ie, just run centrifugal advance. The vacumn advance in the dizzy is just a pollution thing anyway.
I run my TR6 (same engine) that way and have no problems. I suck from three ZS carbs through an oil separator (GoodParts) back to the pan to avoid too much oily vapor in my carbs.
Bill
Gerry M TR6 Vacuum Lines Triumph 8
S banjo type fuel lines--vacuum advance Triumph 0
R TR5/TR250 TR250 Vacuum Lines Triumph 7
J Dizzy vacuum line, manifold drain lines routing? Austin Healey 7
D TR6 73 TR6 vacuum lines Triumph 5
Sopwith_Camel MGA booster Vacuum MG 8
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
drooartz MGB Question on timing and vacuum MG 11
B Vacuum at Idle Austin Healey 9
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
B Vacuum Source Austin Healey 4
WHT Vacuum Advance Pipe Austin Healey 7
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
JPSmit Today's question - vacuum advance Spridgets 2
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
B Vacuum Advance Pipe Austin Healey 2
Twit TR4/4A TR4 AUC878 vacuum connections Triumph 7
J TR6 Vacuum Retard question Triumph 1
R TR6 Thermostatic vacuum switch Triumph 3
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
M Vacuum Line on a 948 Spridgets 4
S TR2/3/3A Vacuum leak Triumph 19
B Vacuum Servo Austin Healey 19
D TR2/3/3A Vacuum connection at Carb Triumph 23
G TR4/4A Distributor Vacuum Manifold Hard Line Triumph 11
6TTR3A TR2/3/3A Vacuum advance questions Triumph 2
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
D TR2/3/3A Vacuum advance tube Triumph 6
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
C Distributer with no vacuum advance Spridgets 15
Griz Testing Vacuum Advance Austin Healey 5
BJ8Healeys '72 Midget Vacuum Advance Line Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
B TR6 Timing using a vacuum gauge Triumph 13
T MGB Vacuum advance and Electronic ignition conversion MG 5
SherpaPilot TR6 Vacuum Gauge Timing Triumph 5
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
W BE vacuum advance line and fittings Spridgets 2
W Vacuum advance nipple Spridgets 0
GTP1960 TR2/3/3A SU, H6 carb vacuum line connector? Triumph 2
J TR2/3/3A Vacuum lin Triumph 13
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
M Vacuum Leaks Austin Healey 22
bigjones Vacuum advance on a 1500 Spridgets 13
