Tuning SU H6 Carbs
af3683
I'm taking a shot at adjusting my SU H6 carbs. I have a copy of the original TR3 manual as well as various instructions I obtained from the web. My problem is that I find the manual a bit confusing and instructions found on the web often use language that differs from the manual. For example:
Web: Loosen "throttle linkage" nuts
Manual: Refers to "throttle spindle connecting rod"
Web: Back out "throttle stop screws"
Manual: Refers to "slow running stop screws" and "throttle adjusting screw on each carb"
Web: Back our fast idle screw(s)
Manual: Refers to "adjustable screw which abuts lever"
Can anyone tell me if these terms are the same. I actually may only need to adjust my idle a bit, but I'm not even certain which screw is the idle adjusting screw. Thanks.
Art
I'll try. My usual sequence is to adjust valves, adjust points gap, set timing, (start engine) sync carbs, (engine now warm) adjust mixture.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Web: Loosen "throttle linkage" nuts
Manual: Refers to "throttle spindle connecting rod"[/QUOTE]
These are the nuts and bolts that tighten the accordian-like clamps that connect the shafts of the 2 carbs. You want them loose so the carbs can be adjusted independently (sync'ed).
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Web: Back out "throttle stop screws"
Manual: Refers to "slow running stop screws" and "throttle adjusting screw on each carb"[/QUOTE]
These are the set screws that hold the carbs partially open. I don't know that you want to back them off completely, they are the screws you will adjust to get the same air flow in the carbs front and rear.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Web: Back our fast idle screw(s)
Manual: Refers to "adjustable screw which abuts lever"[/QUOTE]
Similar to the above-mentioned set-screws, but this one rests on a cam that operates as part of the choke mechanism. This one should be backed off completely so it does not interfere with the sync'ing.
The problem with using 2 sources of information is that rather that making things clearer they can give you too much information and (in this case) be hard to reconcile.
Almost any manual will have an exploded view of a carb that will identify the parts to be adjusted/loosened (such as the idle adjusting screw). Even the Moss catalog illustration may prove helpful:
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=29127
The couplers you loosen are item 66. The idle adjustments (3 incl 'choke') are items 17.
George, thank you very much for your informative reply. I may try to pick up a Haynes manual which may be more helpful than the original TR3 service manual.
Regarding loosening the throttle linkage nuts and bolts, I assume that you only need to loosen 1 of the 2 sets ? Also, I noticed that #71 of the Moss diagram shows a "throttle disc" which I either can't see or don't seem to have. Not sure why. Thanks again.
Art
In order to see the throttle disc, you must remove the air cleaner #162, lift up the piston #5 and look inside the body of the carb. The disc (or butterfly) is what the linkage and/or screws open/close to increase/decrease engine RPM.
Art
All those terms appear to be the same. If you just need to adjust the idle, there are three adjustment screws involved. One is the "fast idle screw", which is the one that is moved when the chokes are pulled. There is a cam that that moves and hits that screw. That's for adjusting the high idle when the choke is in use. The other two are for adjusting the idle on each carb. They have to be adjusted separately (yet together), which is why the you have to loosen the coupler shaft between the carbs. The "yet together part refers to the fact that you have to go back and forth between each carb, using a Uni-Syn type tool of even a section of heater hose to listen (tuning by ear) to get each carb pulling the same at the proper idle rpm.
Not sure what your symptoms are, but:
I know you probably know this but it's best to make sure everything else is in order before you touch carbs. Adjust valves, set timing, make sure vac advance is working, then leave the carbs for dead last.
Many people think ignition problems are "carb" problems when they are not.
KVH General Tech Tuning the SU carbs Triumph 18
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
Martinld123 Tuning H6 100 M carbs Austin Healey 10
M Help with Tuning Stromberg 175CD Carbs in Houston Triumph 37
W Tuning SU carbs? Triumph 7
TR4 Tuning Stromberg Carbs ???? Triumph 7
C TR4/4A New TR4 tuning Triumph 21
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
F TR6 tuning webbers Triumph 3
jehuie Tuning up a 1275 Spridgets 17
HealeyPassion EFI AH testing/tuning remotely Austin Healey 2
L 100/6 tuning and suspension ugrades advice Austin Healey 7
Patrick67BJ8 Special Tuning using AF Equipment by Innovative Motorsports Austin Healey 27
D 62 tri-carb tuning question Austin Healey 8
M Carb Tuning Austin Healey 40
M Carb tuning [again] Austin Healey 2
CJD TR2/3/3A SU Carb Tuning Triumph 17
E TR6 Crankcase venting and general tuning advice? Triumph 29
AN6-TX Tuning/Tweaking for Altitude Spridgets 11
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
R General Tech TR3/4 Tuning Triumph 27
HealeyRick Sprite Tuning Information Memos Spridgets 0
HealeyRick Big Healey Tuning Information Memos Austin Healey 0
drooartz Leaning out/tuning a Weber on a 1275 Spridgets 20
KVH General Tech Timing and Valve Tuning--with a plastic fan Triumph 4
M wire wheel spokes "tuning" Austin Healey 8
S Procedure for setting and tuning HD8s? Austin Healey 10
C BMC Special Tuning Data Austin Healey 9
KVH TR4/4A Tuning the TR4A Triumph 16
S Tuning the Sprite Spridgets 3
L 100 BN1 Tuning instructions ebay Austin Healey 3
7 General Tech Engine vacuum, tuning question Triumph 7
7 General Tech Tuning an engine with a vacuum gauge Triumph 5
Coyote1 TR6 TR6-tuning new motor with mods Triumph 6
Boink "Tuning" or dialing-in the pancake-style PCV valve Spridgets 9
T SU HS6 tuning - lifting pin question Triumph 11
M TR4/4A 67 TR4A, any tuning mods with Redline/MMO in gas? Triumph 3
HealeyRick "Tuning BMC Sports Cars" Spridgets 11
Westfield_XI Weber tuning breakthrough Spridgets 14
M Carburetor tuning - setting mixture Triumph 6
Nunyas Saw this at a "tuning shop" Other Cars 0
hondo402000 weber ntuning saga continues Triumph 25
hondo402000 Tuning my Webers now Triumph 13
drooartz MGB MGB tuning conundrum MG 25
T tuning carb timing Austin Healey 17
Stewart Tuning experts MG 4
PAUL161 Tuning the 1800 engine. MG 5
W Carburetor tuning Triumph 18
eschneider TR4/4A TR4 Zenith-Stromberg CD175 tuning question Triumph 4
drooartz Tuning help Spridgets 16
