Transmission oil dilemma
G
Hey guys,
I have finally gotten an overdrive installed on my 4-speed for my TR6 (J-type) and am awaiting its arrival from snowbound Connecticut. The problem is, I have always run Hypoy Gear Oil, GL-4, SAE80W90 in my transmission. Quantum Mechanics, who rebuilt the overdrive and installed it for me, insists that I only run 30WT non detergent oil in the unit now. This is contrary to what Triumph has said (my guru @ TRF, Dave). Of course the oil from the tranny and the overdrive are one and the same. What to do? Surely don't want to void any warranty on the new unit. Has anyone every heard of such contrary information before? Imput???
Bill
You may want to get the warranty for your transmission from the builder. Also, it might be worth asking them about using 85W90 instead of 30W non-detergent. I have a D type o/d behind my 4 speed GT6 and I am using 85W90 with no issues.
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Bob Buxbaum:
...asking them about using 85W90 instead of 30W non-detergent...<hr></blockquote>
I'll bite -- is there much difference between the two?
I think the viscosity of transmission oil is measured differently than engine oil. 30 wt might be almost the same as 75/80 transmission oil.
Phil, Yes;
Gear oil viscosity is measured at 150 F vs. 210 F for motor oil. Therefore, 40 W motor oil is the same as 95 W gear oil, etc.
[ 02-02-2004: Message edited by: Dave Russell ]</p>
I also have a Quantummechanics Jtype in my GT6. Your warranty indicates 30 weight, non-detergent oil. John Esposito at Quantum recommended Wolf's Head. Two excellent reasons to use the ND oil.
The most postive part about this is that the ND Wolf's Head is cheap as dirt, about $1.10 per quart.
I think it's the first cheap thing I've encountered in my restoration.
Cheers!
Bill--I have a bit over 12,000 miles on my John Esposito A-type O/D using ND 30W motor oil. No problems, and I think John knows what he's recommending. Since there is no filtration system in the O/Ds, you don't want detergency; quite the opposite, you want the junk to settle out. Also, detergents would create a foaming issue within the system at the hydraulic pressures used.
Stick with the motor oil!
Rick O.
72 TR6
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
EWD TR6 Transmission Oil Seal Triumph 13
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
TomMull TR2/3/3A Transmission oil leak Triumph 17
G Transmission with Overdrive - Which Oil to Use Austin Healey 30
vette Transmission Oil Austin Healey 5
M What is the proper oil for Bugeye engne and transmission Spridgets 6
PAUL161 MGB MGB Transmission Oil Capacity ? MG 2
T Transmission Oil Austin Healey 7
R transmission and rear end oil Austin Healey 2
P TR2/3/3A TR3 Transmission oil Triumph 13
bobh Changing Transmission Oil in 10 minutes Triumph 8
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
T 1275 transmission oil leak Spridgets 2
M Transmission oil Spridgets 2
Jim_Gruber Transmission Oil and Differential Spridgets 3
J location of transmission oil filler on a BN-2 Austin Healey 5
PAUL161 Transmission oil Type MG 3
ekamm TR2/3/3A tr3a transmission oil preferences? Triumph 4
TRnorwegian Easiest way to check refill oil in transmission? Triumph 20
AUSMHLY Another transmission oil question Austin Healey 19
66healey oil for transmission Austin Healey 2
dklawson Transmission Gear Oil - Synthetic? Triumph 7
Stewart Leaky transmission oil drain plug MG 3
R Best gear oil for transmission in midget[snail] Spridgets 3
R 1500 with OD transmission oil recommendations Triumph 15
martyc MGB MGB Transmission Oil -- with Tasty Metal Shavings MG 2
ronzet Transmission Oil Recommendations Austin Healey 8
M Transmission Oil Spridgets 13
R Spitfire spitfire transmission and j type O/D oil question Triumph 29
davidk TR6 Transmission Oil Capacity on a non OD TR-6 Triumph 5
B TR2/3/3A tr3 transmission oil fill plug Triumph 18
G Changing front oil seal on transmission. Triumph 14
White79MGB TR2/3/3A TR3 Transmission Oil Triumph 18
ronzet Oil Viscosity Transmission Austin Healey 17
nevets transmission/OD oil question Austin Healey 17
PAUL161 Thanks Doc & Tony -OD & transmission oil change MG 0
T How full to refill transmission oil? Spridgets 4
gbtr6 Transmission Oil/Lube Triumph 4
cdsmith Transmission oil? Rear end oil? Spridgets 15
jsneddon TR2/3/3A TR3 Transmission Oil Capacity Triumph 3
B transmission oil?? MG 10
S TR2/3/3A Tr3 transmission oil Triumph 4
Johnny Transmission oil seals Austin Healey 8
Michael Oritt Transmission oil specification--Toyota box Austin Healey 10
S Transmission oil filler where is it? MG 5
R transmission oil Austin Healey 4
D Transmission oil pump question MG 2
7 Transmission Oil Refil MG 3
