Wedge TR8 Header Install
I'm sure you can visualize it. It's an upright machine about 6 feet tall with a table and a drill mounted above it. Great for putting holes in things like wood, metal and header gasket material. Use the press to drill the holes for the bolts and at the four corners of the exhaust port cut out. Works better if you stack several together at a time.
Been a little side tracked with things here and need to get to the wrench turning part of this header change.
Anyway, should the mounting side of the headers look like this? The raised area around the port concerns me.
No, I had to have mine ground flat.
You would think that was taken care of by now.
I thought enough people have said something about it.
Take it to your favorite machine shop.
That's how mine looked, Randy, and I had the same concern. But when I thought about it, I realized the flange plate would have to be spot on to get a proper seal. This way there's less metal to have to mate to the head. Installed them with no issues.
Don: That's how I felt.
Mickey: I understand that concept, but I do not think it is proper. I am pretty sure it will work, but it might look a little "chop shopped".
Considering these came fully powder coated, they are either going in the car or going back.
Anyone have close up pictures of The Wedge Shop's headers actually installed?
I'll see if I can find pictures from mine - the one Brosky has now. If not, maybe he can shoot one to you.
Best I can do - can't really tell much from here:
One more:
Wouldn't be flush with the head. "member, gasket there.
Randy, just sent the only pic I think would help to
"tessfamily.com
I would say not much different.
It's not the look it's the chance of leaking eventually.
Hopefully the East Coast boys will chime it too.
I don't even think you could see that there was a difference by sight
That raised lip is the sealing area of the header against the head. It is suppose to be there. The thinking is greater pressure per square inch of sealing area will lead to a better seal. Remember, the header gasket is under tremendous heat and pressure. The smaller sealing area allows for thermal expansion, and concentrates the clamping force. Remove the raised area only if you like replacing gaskets often. They install easier if you cut the flange so that there is two flanges serving 2 ports apiece instead of one long flange.
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
philman Wedge TR8 Header fit Triumph 10
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
P Wedge Starting problems TR8 Triumph 3
tr6nitjulius Wedge Rare TR8 Triumph 0
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
Hamish Racing TR8 IMSA GTO around Spa Racing 0
MadMarx Wedge Dijon 2019 - Triumph TR8 IMSA GTO Triumph 0
MadMarx General TR Spa Summer Classic 2019 - TR8 IMSA GTO Triumph 1
MadMarx Brands Hatch - Triumph TR8 IMSA GTO Racing 0
MadMarx General TR Brands Hatch - Triumph TR8 IMSA GTO Triumph 0
MadMarx Wedge The IMSA TR8 is ready to go again Triumph 7
MadMarx Wedge IMSA TR8 video with some roar Triumph 0
MadMarx Triumph TR8 at Spa Racing 0
MadMarx Le Mans - YTCC - Triumph TR8 IMSA Racing 1
B Gold TR8 Waxhaw N.C. Spotted 2
MadMarx Wedge Canadian Group 44 TR8 at Hockenheim Triumph 2
MadMarx Wedge TR8 IMSA at Le Castellet Triumph 1
J Wedge TR8 research before purchase Triumph 16
S Wanted TR8 with blown motor or no motor Triumph Classifieds 0
T Wedge Triumph TR8 for Sale - 1,020 miles Triumph 3
S Wedge tr8 front end Triumph 0
S Wedge TR8 starter solenoid details? Triumph 3
S Wedge Tr8 manual Triumph 2
S Wedge Need help with TR8 no spark Triumph 7
MadMarx Wedge IMSA TR8 goes on Salzburgring Triumph 6
S Wedge TR8 Starter wiring help needed Triumph 18
Rut Wedge TR8 for sale Triumph 1
MadMarx Spa Summer Classic - IMSA TR8 Racing 0
MadMarx Wedge Spa Summer Classic - IMSA TR8 Triumph 7
B Wedge tr8 oil pressure switch number needed Triumph 3
G Wedge TR8 Classified? Triumph 0
G Wedge New to me TR8 Barn find Triumph 8
MadMarx Wedge IMSA TR8 - a recent photo Triumph 3
MadMarx Wedge IMSA TR8 - Spax on the rear axle Triumph 3
W TR8 brake aclipers on a Spridget Spridgets 38
MadMarx IMSA TR8 on the NĂĽrburgring Racing 3
MadMarx Wedge IMSA TR8 is racing Triumph 7
tr7andtvr Wedge TR8 Rotor Specs? Triumph 0
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
tr7andtvr Wedge TR8 calipers? Triumph 3
tr7andtvr Wedge Tr7, Tr8 or SD1 3.08 rear needed.... Triumph 25
Mickey Richaud General TR TR8 Folks Triumph 0
T Wedge TR8 parts car Triumph 3
philman Wedge Tr8 on local craigs list Triumph 11
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
Darrell_Walker Wedge Rimmer's front rally spoiler installed on my TR8 Triumph 22
JFS Wedge TR8 Hazard Flasher Triumph 15
