TR6 TR6 Rocker Shaft Assembly
TR6BobNF
Love this forum. Was out in the garage today trying to reassemble the rocker shaft and attendant bits. Having gone this far on a 9-year driving resto and with the new engine/trans swap being basically the end of the road except for upholstery I was really bummed to find that the old rocker pedestals were first, a bitch to get off the old rocker arm and worse, just as hard to get onto the new TRF stock arm. Having already purchased the GP2 cam and new tappets and after inspecting the push rods and rockers I decided to replace those too including the solid spacers instead of the stock rocker springs. So all I had left of the original setup was the rocker pedestals and I had a helluva job getting them off and I was surprised when they would not fit the new rocker shaft, thinking that years of wear would make them an easy fit. The old rocker shaft was chewed up like beavers had been at it so I'm glad I bought the new stuff. In fact, the rockers, rods and pedestals from my original 130,000 mile engine were in better shape than those parts from my 45,000 mile replacement, completely rebuilt engine but I digress. I have not spared any other expense in getting this 45,000 mile engine reconditioned. Turning to this forum at 10:00 pm tonight I found a post that suggested heating the pedestals gently with a propane torch, using an old rocker as a persuader to tap the pedestal and then trying the install again. Worked like a charm and it's all now fully assembled. The # 3 pedestal on the replacement engine was so badly scored that I used #3 from the old, hi-mileage engine as all of those pedestals were in perfect condition. It was really a bummer to find the pedestals stuck and with plans for tomorrow to drop in the new engine seeming to be doomed but what a relief to find just what I needed in 10 minutes of searching this forum. Gotta love that. I guess Basil is listening now and looking for a donation. Great bunch here - thanks for the assist. :applause:
Cheers,
I don't know if this would apply to the TR6, but on the TR8, the holes in the pedestals are flattened a bit. I don't know if they are made this way, or if it is from the bolt pressing down (the bolt goes through the center of the shaft). Light pressure in a vise is enough to get the hole round again (it goes back and grips the shaft when you take it out, so I suspect the shape is intended).
M TR6 rocker shaft install tr6 Triumph 2
S GT6 GT6/TR6 rocker shaft oil problems. Triumph 5
Y TR6 TR6 - Secondary oil feed to rocker shaft Triumph 12
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
Scot1966 TR6 TR6 rocker panel fit Triumph 6
S TR6 Help! Need help from TR experts with this frustrating TR6 pushrod/rocker/valve issue Triumph 23
sundown TR6 TR6 rocker panels Triumph 2
O TR6 TR6 Outer Rocker Panels WTB Triumph 0
I TR6 TR6 rocker assembly questions Triumph 45
TR6oldtimer TR6 Junk TR6 rocker panels Triumph 7
TR6oldtimer TR6 TR6 Rocker panel quality Triumph 7
P TR6 TR6 sills/rocker color Triumph 5
TR6oldtimer TR6 Rocker arms for a TR6 Triumph 3
J TR6 tr6 rocker and floor replacement --?s and pictures Triumph 12
B TR6 TR6 Rocker Paint Triumph 5
J TR6 Replacing TR6 Outer Rocker Panels Help Triumph 1
wingsandwheels TR6 Alloy rocker cover, late TR6 Triumph 2
S GT6 GT6/TR6 rocker arm identification and questions. Triumph 0
tr6web TR6 TR6 - Replacing rocker panels Triumph 12
J TR6 1975 TR6 Convertible Top Replacement. Triumph 1
mctriumph For Sale Tr6 rear bumper assembly/with over ride bar Triumph Classifieds 0
E TR6 TR6 Front fenders Triumph 5
EWD TR6 74 TR6 headscratcher Triumph 38
jfarris For Sale TR6 Yellow Fan - New Triumph Classifieds 0
tr6nitjulius TR6 TR6 review Triumph 3
K TR2/3/3A First gear ratio on the TR6 gearbox? Triumph 11
D Wanted TR6 Lamp/Bezel Assembly - Heater Controls - 219139 Triumph Classifieds 1
mctriumph Wanted Tr 3/Tr6 transmission kit interest Triumph Classifieds 2
tr6nitjulius For Sale SOLD! 8/29/24: 4$ale NEW! TR6 radiator support brackets Triumph Classifieds 0
T TR6 TR6 distributor issue Triumph 6
tr6nitjulius TR6 TR6 N IT That SOUND FEEL LOOK! Triumph 0
K For Sale 1974 TR6 For Sale Triumph Classifieds 0
B For Sale TR6 parts for sale Triumph Classifieds 0
T TR6 TR6 blower motor and fuel gauge won't work Triumph 10
B For Sale Lifting & Bracing Frame Kit TR4-TR6 Triumph Classifieds 0
Number_6 TR6 Paul’s TR6 Triumph 9
tr6web TR6 TR6 Manifold gasket help Triumph 1
mctriumph TR2/3/3A R&D completed on Tr6 fan conversion Triumph 2
Hawk813 TR6 TR6 Brakes Triumph 8
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 5
