TR2/3/3A TR3 rear spring to axle joint
JPeter
Member
Is there suppose to be a spacer of some kind between the top of the rear spring and the axle flange?
My pins on the top of the springs are too tall and prevent the spring from seating corectly outo the axle flange.
The pin is clearly .090 inches too tall.
Have other folks just ground off the top of the pin until it just clears?
None of the usual suspects show any such spacers in their catalogs.
I realize that the pin keeps the axle and spring keyed together.
Any comments will be appreciated - thanks.
Tinkerman
Hi:
I finished my frame about a year ago. I'm going to try to attach a picture. There was no spacer. As I recall there was a hole in the axel flange and that is where the pin went. DO NOT grind down the top of the pin.
Regards, Tinkerman
Guess I can't attached a picture. If you send me a PM I will email the picture to you.
Alan_Myers
Hi,
I agree, that "pin" should fit into a corresponding hole on the axle pad. The pin is there to keep the axle from shifting any direction. If it doesn't line up or something got bent somehow, it might take a little fussing to get it to align and fit into place. On my TR4, the axle pad on one side was bent enough to keep the two from fitting together. I ended up heating the axle pad with a welding torch and bending the pad back into shape with various tools. It's now a good fit.
However, yes, at some point, spacers were used on only the RH (passenger) side of the cars (in the U.S., i.e. with LH drive cars). The spacer lowers that side a little bit so that the car is level when viewed from the rear, while the driver is in the car (without a passenger). In other words, the spacer was used to offset the slight settling of the suspension whenever the driver sits in the car. The spacer is roughly 1/4" thick.
I think the spacer was added sometime during TR3 production. It was continued on through TR4, at least until the rear suspension was revised around CT25xxx-something). Spacers are often incorrectly reinstalled on the wrong side, or left out completely.
Spacers were not used when heavy duty leaf springs were installed, only with the standard rate springs. There is some question if spacers were ever used on the passenger side of RH drive cars in England.
barneys56tr3
hi J,
I just finished installing new leaf springs on my tr3. The head of center bolt was definitely to long. I removed the bolt and hack sawed pins head to the proper length. Put everything back together and it works fine.
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
M TR2/3/3A When will the rear spring start to compress TR3 Triumph 16
K TR2/3/3A TR3 Rear Leaf Spring Shackle Bushes Upgrade Triumph 14
K TR2/3/3A TR3 Rear Leaf Spring Front Pin Removal Triumph 17
luke44 TR2/3/3A TR3 Rear Over rider Bolts to Support Spring Triumph 3
H TR2/3/3A TR3 Rear Spring Question Triumph 7
JPeter TR2/3/3A TR3 Rear Spring - front pivot - removal Triumph 18
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
Donald1107 TR2/3/3A TR3 Rear Shocks Triumph 11
B Wanted TR3 Hardtop Rear Stiffener Brackets Triumph Classifieds 0
J TR2/3/3A TR3 Rear seat Triumph 11
K For Sale TR3 rear rebound brackets Triumph Classifieds 0
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
Tinkerman TR2/3/3A TR3 A REAR WING BOLTS order of assembly? Triumph 3
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
J TR2/3/3A Tramp bar for rear of TR3 or?? Triumph 7
mgedit TR2/3/3A Steady Springs Rear Brakes 56 TR3 Triumph 0
jfarris TR2/3/3A Wanted - TR3 Monza Muffler - Rear Section Only Triumph 1
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
1937dodge TR2/3/3A Anyone have any photos of TR3's sporting rear finned aluminum brake drums? Triumph 8
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
mgedit TR2/3/3A Rear Drum Brakes 56 TR3 Triumph 2
rckuhlman TR2/3/3A TR3 Castle Nut on Right Rear Axle Triumph 3
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
S TR2/3/3A rear brakes tr3 Triumph 1
S TR2/3/3A tr3 rear main Triumph 24
M TR2/3/3A Topping off rear shocks on TR3 Triumph 11
Kleykamp TR2/3/3A TR3 rear fender bolts Triumph 2
RickAnderson TR2/3/3A Wanted: TR3 Rear Bumper Overrider - any condition. Triumph 2
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
S TR2/3/3A rear fender vinyl tr3 Triumph 6
mgedit TR2/3/3A Rear capping 56 TR3 Triumph 4
M TR2/3/3A Topping off rear shocks on TR3 Triumph 13
Kleykamp TR2/3/3A TR3 rear fender needed Triumph 18
K TR2/3/3A TR3 rear overider distance from body? Triumph 3
Tr3aguy TR2/3/3A Rear Lettering TR3 post 60000 Triumph 3
luke44 TR2/3/3A TR3 Rear Bumper Overriders - Upside Down? Triumph 12
T TR2/3/3A The light came on: my TR3 rear apron. Triumph 12
S TR2/3/3A tr3 rear interior panels Triumph 6
J TR2/3/3A TR3 Rear Apron Replacement Triumph 4
K TR2/3/3A TR3 Rear Overider Bracket "distance tube"? Triumph 10
O TR2/3/3A TR3 Rear Main Seal Triumph 5
