TR2/3/3A TR3 head is off -- awaiting head gasket
sammyb
Rope trick, shmrope trick! Nothing like a little head wrastling :wink:. Just had to use a little pry bar under the water outlet area and the part that extends on the back (no I didn't pry in the actual head-to-block area!) It took a good 15 minutes of rocking back and forth, but it's off.
The funny thing was that I was looking at shop manual, and it made no mention of taking off the exhaust manifold. I kept looking at it and saying to myself "THIS HAS TO COME OFF!!!!"
I opened the other shop manual, and the instructions start "assuming the engine is OUT OF THE CAR, To remove head...."
Interestingly, it's pretty easy to remove the carbs and exhaust manifold. Good design. We'll see how hard it is to put back on.
But a few of the head bolts seemed tighter than others. Wonder if I warped the head, or if the bolts were just not retorqued after installation 15 years ago. The head looks quite nice.
Congradulations........Any pictures? We all would like a peek inside the cylinders and a look at the valves. Especially those of us who have never taken their head off.
Try removing the cylinder head in-chassis on a 4.6 litre late model Ford pick up! Woo! Hoo!
sammyb said:
...Interestingly, it's pretty easy to remove the carbs and exhaust manifold. Good design. We'll see how hard it is to put back on...
Too late I guess, but FWIW I do not remove the manifolds, just undo them from their studs and pull them back away from the head. Plenty of flex in the exhaust system to allow this thought you may need to undo the choke linkage from the front jet (I have to) to keep it from hitting the inner wing. Once back a 2x4 jammed between the block and header holds the manifolds out of the way.
Uggh...I just flipped the head over to check for warpage...and while it looks flat, there's a big ole crack in there. It actually looks like it's been there for a while.
I'm taking it to the machine shop tomorrow to get an expert opinion. A little welding here -- a little surfacing there and hopefully I'm back in business. I'd hate to have to get my hands on a new cylinder head!!!
Geo,
I actually did exactly what you said. The manifolds are still in the car.
Bill,
I probably will keep the same bolts and studs, because they aren't that old. They actually look pretty decent.
But since the head is going down to the machine shop, I'll ask their opinion.
Sam
If it makes you feel any better, I drove my TR3 for several years with a weld-repaired cracked head. Still ran well after I sold it.
I dropped off the head at the machine shop today. Turns out the owner of the shop used to own a TR3B. (Always nice to find out that the guy who is working on your stuff knows all about it.)
He said the crack was entirely between two water passages, so no worries. I still left it down there to have him give it the once-over, because there was a little light abrasion that he wanted to at least check out, if not polish.
So hopefully I'll have the head back on Monday before I leave to go to Pebble Beach/Monterey.
T TR2/3/3A tr3 head gasket Triumph 38
Marvin Gruber TR4/4A TR3/4 head thickness Triumph 7
M TR2/3/3A Tr3 Head Rebuild Triumph 3
Got_All_4 TR2/3/3A The bolt on the back of the tr3 head Triumph 4
DornTRoriginal TR2/3/3A TR3 Head Gasket Questions Con't Triumph 3
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
Kleykamp TR2/3/3A 1961 TR3 control head. Triumph 5
K TR2/3/3A Can porting a TR3 Cylinder head be a DIY job? Triumph 6
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
Scotsman TR2/3/3A Signal switch on TR3 Horn Control Head not canceling Triumph 20
C TR2/3/3A TR3 Low Port vs High Port Head Triumph 10
Lukens TR2/3/3A TR3 blown head gasket? Triumph 39
RedTR3 TR2/3/3A TR3 Head Gasket [Again] Triumph 4
RedTR3 TR2/3/3A TR3 Head Gasket Triumph 6
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
O TR2/3/3A TR3 Control Head Install Triumph 10
H TR2/3/3A TR3 head /cam Triumph 4
K TR3/4 Cylinder head temperatures? Racing 1
O TR2/3/3A TR3 Control Head Stator Tube Install Triumph 5
tinman58 TR2/3/3A Removing head studs TR3 Triumph 15
K TR2/3/3A The Aluminum Plug in the Cylinder Head ?[Again]TR3 Triumph 2
S TR2/3/3A tr3 head light switch Triumph 3
K TR2/3/3A Head bolt torque TR3 Triumph 3
H TR2/3/3A TR3 -- Pull the head "while I'm in there . . ." Triumph 9
K TR2/3/3A Internal view of a tr3 control head Triumph 7
mountainman TR2/3/3A TR3 Bright Head Lights Triumph 3
mountainman TR2/3/3A TR3 Control Head Wiring Triumph 11
Marvin Gruber TR2/3/3A TR3/4 cylinder head differences Triumph 3
newmexTR3 TR2/3/3A tr3 head rear oil leak Triumph 9
T TR2/3/3A TR3 head core plug [freeze plug] Triumph 6
S TR2/3/3A TR3 Copper Head Gasket -- quick questions Triumph 8
A TR2/3/3A TR3 head welding Triumph 4
S TR2/3/3A Uggh! TR3 head gasket leak!!! Triumph 9
Got_All_4 TR2/3/3A Blown head gasket TR3 what to do next? Triumph 16
Tinkerman TR2/3/3A TR3 Oil filter head, long stud? Triumph 2
martx-5 TR2/3/3A TR3 Head Gasket Triumph 16
TR4nut TR4/4A Aluminum plug in TR3-4A cylinder head? Triumph 4
F TR2/3/3A TR3 Turn Signal/Horn control head Triumph 4
A TR2/3/3A TR3/4 head crack, can it be welded Triumph 11
K TR2/3/3A Torqing the head again?....rebuilt motor... TR3 Triumph 4
A TR4/4A TR3 / TR4 head crack repair Triumph 3
J TR2/3/3A TR3 control head internal pictures? Triumph 11
C TR2/3/3A TR3 Head Work Triumph 2
C TR2/3/3A TR3 Head Triumph 3
S TR2/3/3A head bolts on a tr3 Triumph 5
MGTF1250Dave TR2/3/3A TR3 Control Head Triumph 4
D TR2/3/3A Control Head [TR3] Rebuild Triumph 2
bluemiata90 TR2/3/3A TR3 Horn,control head and stator tube removel Triumph 9
MGTF1250Dave TR2/3/3A TR3 Control Head Help Triumph 9
E TR2/3/3A TR3 Cylinder Head Lubrication Triumph 11
