TR2/3/3A TR3 Fuel Pump Thread Type?
I think this is what you are looking for. Note that the outlet fitting is a special longer part. Here is discussion from thread:
"I talked to Albert at TRF. Here are the TRF p/n's. He said they buy the compression sleeves from a reliable source, not general hardware store, but did not know the length of them.
>5/16" tube nut is 60142, and 5/16" compression sleeve is TL8
>1/4" tube nut is 60176, and 1/4" compression sleeve is 102729
He said both the tube nut and compression sleeves are the same p/n's for TR3, TR4, TR250, and TR6.
Bob"
p.s. It is by far a good idea to get the tube nuts from TRF and NOT a local FLAPS. The FLAPS parts don't work for the 1/4 inch fitting.
Here is the full BCF thread. Best to go all the way through it to find the correct information:
Good luck!
Bob is right I have fixed a number a TR6's do to wrong nut to sleeve If the surface of the nut touches the pump then it is to short and does seal with sleeve. I have seen tape copper washers trying to fix a leak it is just a fire waiting to happen. This is on my GT6 but same on the TR6 and TR4
S TR2/3/3A old tr3 fuel pump Triumph 2
S TR2/3/3A TR3 fuel pump Triumph 16
M TR2/3/3A TR3 fuel pump Triumph 14
J TR2/3/3A Fuel pump for a Triumph TR3 or 4? Triumph 2
T TR2/3/3A TR3 weeping at fuel pump, again Triumph 11
J TR2/3/3A TR3 fuel pump question Triumph 7
RedTR3 TR2/3/3A TR3 Fuel Pump: Mechanical vs. Electric Triumph 14
M TR2/3/3A TR3 Fuel Pump rebuild Triumph 2
E TR2/3/3A tr3 fuel pump spacer Triumph 6
M_Pied_Lourd TR2/3/3A TR3 Mech/Elec Fuel Pump Question Triumph 9
M TR2/3/3A TR3 Fuel Pump Check Valves Triumph 7
RedTR3 TR2/3/3A TR3 Fuel Pump Removal Triumph 13
RedTR3 TR2/3/3A Rebuilding TR3 Fuel Pump question Triumph 5
martx-5 TR2/3/3A TR3 Fuel Pump...Rebuild or New Triumph 6
S TR2/3/3A TR3 fuel pump rebuild Triumph 10
jsneddon TR2/3/3A TR3 Fuel Pump Gasket Triumph 23
MGTF1250Dave TR2/3/3A TR3 or 4 Mechanical Fuel Pump Blanking Plate Triumph 4
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
D TR2/3/3A tr3 fuel line Triumph 9
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
scottdr TR2/3/3A TR3 Fuel Sending Unit Triumph 3
S TR2/3/3A Not all tr3 fuel pumps are built the same Triumph 5
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
mrv8q TR2/3/3A TR3 Fuel line rubbing Triumph 8
O TR2/3/3A TR3 Fuel Tanks Triumph 5
PatGalvin TR2/3/3A Late model TR3 Fuel Tank Straps available to a nice home Triumph 0
S TR2/3/3A Bad fuel perhaps water tr3 miss Triumph 0
S TR2/3/3A tr3 fuel delivery system Triumph 18
M TR2/3/3A TR3 fuel cap install question Triumph 9
S TR2/3/3A tr3 metal fuel lines Triumph 1
M TR2/3/3A TR3 fuel sending unit Triumph 25
Kleykamp TR2/3/3A TR3 fuel filter location and type Triumph 7
M TR2/3/3A TR3 fuel line part#104842 Triumph 5
M TR2/3/3A TR3 Fuel tank straps and pads Triumph 13
O TR2/3/3A TR3 Fuel Tank Filler Triumph 3
J TR2/3/3A TR3 Fuel line size Triumph 3
A TR4/4A TR4 FUEL GAUGE CONVERSION FOR A TR3 Triumph 4
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
mgedit TR2/3/3A Seal for TR3 Fuel Tap Triumph 10
B TR2/3/3A 57 TR3 fuel tank vent Triumph 3
S TR2/3/3A Tr3 Fuel line support clips Triumph 4
Gordon_Dedrick TR2/3/3A TR3 Banjo Fuel Fittings Triumph 1
M TR2/3/3A TR3 Fuel line routing Triumph 6
M TR2/3/3A Fuel line missing [ TR3] Triumph 13
PatGalvin TR2/3/3A TR3 Fuel Line - where to buy? Triumph 7
martx-5 TR2/3/3A TR3 Fuel Sender From Moss Triumph 8
mrv8q TR2/3/3A TR3 Fuel line Q Triumph 4
