TR2/3/3A Tr3 front suspension clarification
ekamm
I hope that I am not at the point of wearing everyone out, but at the risk of that I have a few clarification questions.
1. Installing a new trunnion reaming (1/2" dia.) the new bushing is essential.
What tolerance am I looking for?
Also how tight or how far to tighten the trunnion onto the vertical link?
2. lubrication or anti-seize is a good idea on parts
Where do I use grease and where do I use anti-seize?
[I assume silicone grease (is spray OK?) inside and out on any thing nylon, poly, etc.]
[I also assume anti-seize on non-moving parts like threads. castlated or nylock nuts?]
3. Torque values on non-moving parts are standard to bolt size?
On nylock nuts, am I'm looking for movement of moving parts with little or no play, without binding?
The shop manual isn't terribly clear on these points, and it is clear that there are many of you that have been through this. I'm sure that your knowledge is the best that I can hope for to get everything installed correctly.
Thanks in advance.
Hi Eric, what shop manuals are you using? I found the Haynes manual has more torque specs than the original manual. I rebuilt my entire suspension last winter and had no problems over the summer driving so things worked out between having the Haynes and original manual.
I had a pro shop ream the trunnion bushings for me.
I seem to remember a manual stating to fully screw the vertical link in and then reverse a certain amount. I can try to find that info.
I used the same grease in my grease gun for any area that would serviced by the grease zerks. I think anti-seize is best for nuts and bolt threads, I tend to use grease on the bushings, etc.
Hope this helps...
Ream to the exact nominal size (which as I recall is 5/8", not 1/2"). The clearance is built into the pin. In fact, I strongly suggest using a fixed reamer rather than an adjustable one. A suitable fixed reamer can be had for under $25, so is a reasonable tool to buy just for this one purpose.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Also how tight or how far to tighten the trunnion onto the vertical link?[/QUOTE]All the way, then back off one turn so it can turn from stop to stop.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]2. lubrication or anti-seize is a good idea on parts
[/QUOTE]AS is only for joints that do not move in service, grease is for anything that does move in service. Nyloc nuts are probably best installed dry, as the AS may interfere with the locking action. One exception is the sleeves that go over the lower inner trunnion pins. Although they do not turn in normal service (being clamped against moving by the end plates), I would suggest smearing grease on the pins and inside the sleeves, rather than anti-seize, as grease gives better coverage. Silicone grease is probably fine, but I use lithium-based on my cars.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]3. Torque values on non-moving parts are standard to bolt size?[/QUOTE]Yes, unless a particular torque is given in the shop manual, or special instructions supplied.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] On nylock nuts, am I'm looking for movement of moving parts with little or no play, without binding?[/QUOTE]Not unless there are instructions to that effect in the manual. In most cases they get torqued to spec or standard torque. The only exception I can think of offhand is the outer trunnion pins (if you have the aftermarket trunnions without holes for cotter pins), and there are explicit directions for installing those as the joint has to have a certain amount of clearance.
BTW, I advocate drilling out the pins and using castellated nuts plus cotter pins. I just don't trust nyloc nuts any more, had too many of them back off. When I got around to stipping my wrecked TR3A, one of the nylocs was simply missing, but the threads were undamaged. And those were brand-new nylocs when I put it together (they should also be replaced every time they are removed, which is a PITA).
Thanks a lot guys I am using the original workshop manual.
Got_All_4 TR2/3/3A Tr3 front suspension re-bush, what's good out there Triumph 15
Tr3aguy TR2/3/3A TR3 Front suspension breakdown..Help Triumph 2
Kleykamp TR2/3/3A TR3 Front Suspension rebuild????? Triumph 12
R TR2/3/3A TR3 Front Suspension and Steering Triumph 12
ekamm TR2/3/3A Tr3 front suspension Triumph 16
Moseso TR2/3/3A TR3 -->4 Front suspension upgrade questions Triumph 7
I TR2/3/3A TR3, front suspension rebuild qustions Triumph 13
I TR2/3/3A TR3, Front Suspension Triumph 7
S TR2/3/3A TR3 front suspension problem Triumph 17
K TR2/3/3A TR3 Front suspension rebuild question...... Triumph 5
K TR2/3/3A TR3 front suspension blow up pic? Triumph 6
K TR2/3/3A Another TR3 Front Suspension Rebuild Question Triumph 5
K TR2/3/3A TR3 Front Suspension Rebuild Pics....Lost the link Triumph 0
fad64b TR2/3/3A TR3 Front Suspension Triumph 17
prb51 TR2/3/3A TR3 front suspension report Triumph 6
T TR2/3/3A TR3 question - front suspension rebuild access Triumph 7
T TR2/3/3A Poly bushings for TR3 front suspension Triumph 7
PeterK TR2/3/3A TR3-4 Front suspension question Triumph 7
K TR2/3/3A TR3 alloy wheels and Front suspension upgrades Triumph 14
martx-5 TR2/3/3A TR3 front suspension Triumph 2
G TR6 TR6 front suspension in a TR3 Triumph 3
K TR2/3/3A A TR3 plug check left to right 1234...do I lean out front carb a couple of flats?...turn down correct? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
T TR2/3/3A tr3 front carpet replacement Triumph 5
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
B TR2/3/3A 'A' type Front calipers, TR3 vendor??? Triumph 7
S TR2/3/3A tr3 front apron body work Triumph 9
jfarris TR2/3/3A Front Sway Bar on a 56 TR3 Triumph 13
F Wanted TR3 Front Float Bowl Lid SU H6 Triumph Classifieds 6
T TR2/3/3A Pictures of my TR3 with over riders on front Triumph 14
toysrrus TR2/3/3A "WANTED": TR3 Small Mouth Front Apron Medallian Triumph 14
S TR2/3/3A tr3 front fender Triumph 4
B TR2/3/3A TR3 Front Hub Felt Seal questions Triumph 2
sqbsprite TR6 Do the TR3-6 front spring pans interchange? Triumph 6
G TR2/3/3A Front Sway Bar Installation on Wide Mouth 61 TR3 Installation Problem? Triumph 9
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
T TR2/3/3A Vent hole in lower front valance of TR3? Triumph 7
luke44 TR2/3/3A TR3 Front Fender Washers? Triumph 19
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 2
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 7
T TR2/3/3A TR3 front license plate Triumph 4
