TR2/3/3A TR3-4 Front suspension question
PeterK
I have a question about the lower fulcrum on the TR3-TR4 front suspension.
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=29136
The lower fulcrum shaft has a steel bush(# 118) that fits over the shaft, and a nylon bush(# 117) that is pressed into the lower wishbone. Does the nylon bush in the wishbone rotate around the steel bush or does the steel bush rotate around the fulcrum shaft, or both?
I'm confused on which to lubricate as I assemble.
On my car, the nylon is definitely worn and a couple of the steel bushes were pretty frozen to the shafts. So I thought I might use anti-sieze on the steel and poly-lube on the nylon.
Any btdt ideas? Looks like TR3 and TR4 share the same mounting arrangement.
I'm pretty sure that the steel sleeve gets captured by the tab and nut that goes over the end of the shaft. The real movement occours between the steel and nylon sleeves. the steel sleeve is there to provide a replaceable wearable surface to the perminant shaft.
I would still apply some anti-sieze to the shaft before sliding the steel sleeve over it in case you ever find yourself in there again.
Thanks Banjo. I thought the steel might be a wear item since the fulcrum shaft is soft steel and the sleeve is hardened. I've got one stuck sleeve (the one just under the gas line) and I torched it a bit but still stuck so I think I just might leave it.
Is the nylon lubricated normally? Maybe some poly bushing lube?
Well, I hope someone who knows pipes in, but it's been my opinion that nothing 'rotates'. All the parts move a little (rotate/turn).
One of my TR6 (urthane) trailing arm bushings (same type set-up) is constantly developing a squeak. I should have packed more greese in there while assembling, and maybe dirt wouldn't be able to get in.
The poly lube would be a good idea. I would try to get that sleeve off if you can. I know it's hardened, but maybe cut it with a dremel, Or what I usually do is carefully blow through it with the torch. (I know, It's the one by the fuel line)
But even if you put a small spot in the shaft, so what. the new sleeve covers it.
Still, it's not the end of the world. especially ir the old sleeve is still in good shape.
The hardened bushing should be hard to get on and most definitely should not have rotated on the fulcrum pin. If it has in the past use some epoxy to help hold it in place. If it's hard to remove use map gas or an acetylene torch. If you're good with drills and taps add a grease fitting to the A arm and nylon bushings and take a dremel tool and add a slot on the inside of the nylon from the grease hole all the way around the inside radius. I've had a setup like that for 20+ yrs and they have shown minimal wear.
Tom Lains
TS8651 & 58107
On my TR4, the steel bushings were also hard to get off - I think on both sides it was the front leading bush, maybe because they saw more road spray and had a little more corrosion.
I pulled them by grinding a flat on each side of the bushing, attaching vice grips, then with a little heat applied I rotated until I broke the rust bond. A little more rotation and coaxing after that and the bushings came off.
I did put grease on the lower fulcrum pins before adding the new bushings. The bushings went on easily, no persuasion required. The grease was more to reduce corrosion for the next owner than to help anything rotate.
Randy
I like to use liberal amouts of anti-seize just in case i still own the car when it's due for another rebuild...
Got_All_4 TR2/3/3A Tr3 front suspension re-bush, what's good out there Triumph 15
Tr3aguy TR2/3/3A TR3 Front suspension breakdown..Help Triumph 2
Kleykamp TR2/3/3A TR3 Front Suspension rebuild????? Triumph 12
R TR2/3/3A TR3 Front Suspension and Steering Triumph 12
ekamm TR2/3/3A Tr3 front suspension clarification Triumph 4
ekamm TR2/3/3A Tr3 front suspension Triumph 16
Moseso TR2/3/3A TR3 -->4 Front suspension upgrade questions Triumph 7
I TR2/3/3A TR3, front suspension rebuild qustions Triumph 13
I TR2/3/3A TR3, Front Suspension Triumph 7
S TR2/3/3A TR3 front suspension problem Triumph 17
K TR2/3/3A TR3 Front suspension rebuild question...... Triumph 5
K TR2/3/3A TR3 front suspension blow up pic? Triumph 6
K TR2/3/3A Another TR3 Front Suspension Rebuild Question Triumph 5
K TR2/3/3A TR3 Front Suspension Rebuild Pics....Lost the link Triumph 0
fad64b TR2/3/3A TR3 Front Suspension Triumph 17
prb51 TR2/3/3A TR3 front suspension report Triumph 6
T TR2/3/3A TR3 question - front suspension rebuild access Triumph 7
T TR2/3/3A Poly bushings for TR3 front suspension Triumph 7
K TR2/3/3A TR3 alloy wheels and Front suspension upgrades Triumph 14
martx-5 TR2/3/3A TR3 front suspension Triumph 2
G TR6 TR6 front suspension in a TR3 Triumph 3
K TR2/3/3A A TR3 plug check left to right 1234...do I lean out front carb a couple of flats?...turn down correct? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
T TR2/3/3A tr3 front carpet replacement Triumph 5
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
B TR2/3/3A 'A' type Front calipers, TR3 vendor??? Triumph 7
S TR2/3/3A tr3 front apron body work Triumph 9
jfarris TR2/3/3A Front Sway Bar on a 56 TR3 Triumph 13
F Wanted TR3 Front Float Bowl Lid SU H6 Triumph Classifieds 6
T TR2/3/3A Pictures of my TR3 with over riders on front Triumph 14
toysrrus TR2/3/3A "WANTED": TR3 Small Mouth Front Apron Medallian Triumph 14
S TR2/3/3A tr3 front fender Triumph 4
B TR2/3/3A TR3 Front Hub Felt Seal questions Triumph 2
sqbsprite TR6 Do the TR3-6 front spring pans interchange? Triumph 6
G TR2/3/3A Front Sway Bar Installation on Wide Mouth 61 TR3 Installation Problem? Triumph 9
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
T TR2/3/3A Vent hole in lower front valance of TR3? Triumph 7
luke44 TR2/3/3A TR3 Front Fender Washers? Triumph 19
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 2
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 7
T TR2/3/3A TR3 front license plate Triumph 4
