Torque Setting for Lugs?
mytvtmini
I just bought a set of Superlite 13x5.5s and was wondering what setting I should use to torque the lugs?
Thanks
mccalebr
I just did a quick Google and came up with:
Wheel Nut/Bolt Torque Setting
3/8”UNF. = 35 ft. pounds 7/16”UNF. = 50 ft. pounds 1/2”UNF = 60 ft. pounds
10x1.25mm. = 35 ft. pounds 10x1.5mm. = 35 ft. pounds 12x1.25mm. = 60 ft. pounds
12x1.5mm. = 60 ft. pounds 14x1.5mm. = 75 ft. pounds 16x1.5mm. = 90 ft. pounds
The site is:
https://www.superlite-wheels.com/technical.html
Ray
regularman
Use a 3/8 drive ratchet and tighten them up tight. Don't use a 1/2 drive ratchet or you will snap them off :wink: I'm not a torque wrench person when it comes to wheels. There is a reason that original lug wrench was so short. I used to warn people about this on the minis and they would still snap them off. Most lugs are 1/2 inch or 7/16, these are 3/8 and easy to snap off and hard to find locally.
Yea that was a two click google, we need a better challenge that that!
mark
M
mytvtmini
Thanks everyone. Really appreciate the help.
twas_brillig
twas_brillig
The original BMC Workshop Manual advises 37 to 39 lb. ft. at the end of Section N.3. Doug
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
S Torque setting for U-Bolt nuts Austin Healey 12
T Torque setting on brake rotor Triumph 4
M TR2/3/3A Torque setting question for TR3 Triumph 12
T TR2/3/3A tr3 steering box drop arm nut torque setting? Triumph 2
livinginthepast Is there a torque setting for this? Spridgets 2
H Crankshaft nut torque setting Austin Healey 16
letemglow Torque setting of rear hub nut Austin Healey 24
Michael Oritt Winner's Circle hub-nut torque setting Spridgets 17
G TR6 Crank Bolt Torque Setting on Aluminum Flywheel-TR6 Triumph 17
A TR6 Need a torque setting for rear axle?? [TR6] Triumph 1
I Torque setting for BN1 Cylinder head Austin Healey 2
O MGB-GT MGB/GT Front Sway Bar Torque Setting MG 20
W TR5/TR250 Torque setting for TC2500 head Triumph 3
Carlbanan56 MGB Rear axel torque? MG 4
C Steering Arm Castle Nut Torque Austin Healey 5
P TR2/3/3A British High Torque starter Triumph 6
B Head Re-Torque Austin Healey 8
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
W TR2/3/3A Differential cover torque Triumph 4
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
M High-Torque Starter Austin Healey 10
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
B High-Torque Starter Rattling Noise Austin Healey 3
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
Lin Oil sump torque value? Spridgets 3
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
D Torque Sticks Restoration & Tools 6
J TR2/3/3A Head Torque - Wet or Dry Triumph 6
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
R Our J-H plan - torque specs needed! Other British Cars 2
S Locknut - rear wire wheel - torque spec? Austin Healey 15
S TR2/3/3A Torque specification on large pitman arm nut Triumph 1
Michael Oritt Torque values needed for 100 Austin Healey 5
R General Tech Crank bearing cap broke...Torque?? Triumph 37
G Torque for Front Pinion Nut Austin Healey 3
D torque values Austin Healey 2
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
Jim_Stevens TR2/3/3A Axle to leaf spring torque Triumph 2
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
G TR4/4A ARP Bolt Torque Specs Triumph 10
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
