B
BobHorvath
I am in the process of installing a rear crank seal mod. Seems straight forward but I am looking for any tips as to recommended procedures. In particular I am seeking install techniques & other parts to consider replacing in addition to trans seals. I was thinking of installing the overdrive after the trans is installed. I also noticed oil comming from the camshaft and I am hopeful the gasket supplied will trap any oil against the block. I bought a modified plate to accomodate the new seal housing and it appears the gasket just touches the expanded opening.
