Cain
As stated in my other post "Hatching Cylinder Walls," I have decided to pull the cylinder block and send it to the machinist to be bored out.
Any tips on pulling the block out? I've already got a cherry picker and truck lined up for this weekend.
All that is left of the engine in the car right now is the block, crank shaft, cam shaft, timing chain, and timing chain cover. I plan on leaving these items intact and let the machinist/mechanic worry about removing and reinstalling those items correctly.
The LBC guy told me to remove the transmission from the car, then disconnect the engine mounting bolts, and remove the block from the car. He told me to remove the transmission from inside the car.
What should I be aware of when disengaging the transmission from the engine?
Anything else I should know before I do this?
Thanks
Thanks
