Technical: Converting From Wire Wheel To Standard
QuickSilver
I have what is tentatively (until this weekend when I tear into her) a "69" bitsa.
Will a 74 standard complete axle bolt up? How's about rear end ratios?
PS: Please share your thoughts on this conversion. Gotchas, lesson learned, rumors, innuendos, etc
All the MGBs used the 3.90, so all ratios are all the same, after 67 they all had tube axle housing, so here's the deal you don't have to change the housing on your car to convert to bolt on wheels, it's really a easy conversion, I converted my car to bolt on wheels 2 yars ago using the same axle housing, here's a short run down of what it take to do it.
2 front bolt on wheel hubs, just swap your rotors out, and bolt them on.
2 rear hubs, now here you got to do a little bit more, but not much, the deal is the spoke wheel housing is like 3/4 -1" narrower for the extra width of the splined hubs, so you need a slightly longer wheels stud, the part nuber escapes me nopw, but this has been documented on the MG experience over and over, it's a metric stud from the mid 80s camaros and vettes (very common), and it a 12mm 1.5 stud instead of the 1/2-20 stud, but they knock right in, no mods required,. the you need about 3/8" to 1/2" of wheel spacer on each side (hence the need for longer wheel studs) to space the wheel out a tick. This conversion is way nicer than the axle housing change if you ask me because you can more comfortably fit wider tires and wheels. Go the MG Experience forum and use the search feature and you'll find literally pages of folks who have done this. Took me a afternoon to make the swap, pretty easy actually.
Bitsa this, bitsa that. :wink:
Okay so I need to purchase the front and rear wheel hubs.
Any one selling as such?
Try Glen Towery, he hangs out over on the MGex forum, he has atleast dozen of everything, I'll be hitting him up soon for MGB timing covers.
KVH General Tech More Technical Questions—TR4 Triumph 5
X Technical specifications including the maximum technical weight TVR 8
jdubois Wanted Old BMH Original Technical Publications CDs Triumph Classifieds 0
M TR2/3/3A Technical Assistance Needed - TR3B Carb Adjustment Triumph 5
Willie_P TR4/4A Tr4 bonnet latch bracket [highly technical] help! Triumph 6
J Clutch Woes - Need some technical assistance Spridgets 5
MikeAH100M Original Technical Publications from AH Spares Austin Healey 1
Moseso Technical Report: Bronze Spring Bushes Triumph 26
Willie_P TR4/4A tr4 tie rod end/ball joint - technical question Triumph 2
Westfield_XI A good source for technical info Spridgets 2
Don_Racine A technical consideration Austin Healey 3
JodyFKerr Europa Technical and Parts information Lotus 6
jclay Wedge Wedge Technical Site Triumph 5
angelfj1 Bolts - technical resource Restoration & Tools 0
D Technical Questions MG 2
J TECHNICAL INFO IN PDF Jaguar 9
W Ordered Technical CD Triumph 6
jlaird Kina technical question Spridgets 6
tony barnhill Technical Question - Steering Lock-to-Lock MG 9
PeterK Buckeye Triumph technical info Triumph 6
gsalt57tr3 Some technical questions MG 10
jsneddon SU and Stromberg Technical Documents Triumph 0
Webb Sledge Technical questions Triumph 9
nevets interesting article about converting classic cars to electric power Austin Healey 7
D TR4/4A two questions- converting generator to alternator and breather cap query Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
K TR2/3/3A Converting to Negative Ground....... Triumph 12
K TR2/3/3A Converting to Positive Ground....... Triumph 1
T TR4/4A Converting TR4a from wire to TR6 steel wheels Triumph 7
drooartz MGB-GT Decided - converting to bolt-on wheels MG 3
T Converting a BJ8 into a racer Austin Healey 8
drambuie Converting a smiths clock to positive ground Austin Healey 12
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
Mark_Barton TR4/4A Converting to ballasted ignition? '62 TR4 Triumph 8
K Converting a MkII with a V8 back to stock Jag 6? Jaguar 3
T converting disc wheel BN4 to disc brakes Austin Healey 12
T Stag Converting a Stag from auto to a 5 speed Triumph 3
B Converting to Neg ground Spridgets 5
AH67 Converting wheels on a 62 BT7 Austin Healey 3
C Converting to DOT 5 Triumph 6
T TR2/3/3A Converting TR3A to Wire Wheels - Torque Specs? Triumph 3
middie Converting from US to UK radiator in a late 1500 Spridgets 10
L Converting a Midget MG 8
MadRiver Converting to a Surrey Top Triumph 5
Z Converting Power/Torque to Metric Units Austin Healey 1
Newkie Converting Positive ground to Negative ground MG 4
QuickSilver Converting Rubber To Chrome MG 1
M Converting to RHD Austin Healey 8
amcboy Post-War Other Difficulty in converting Volvo 1800 J-type O/D? Triumph 6
T converting rear reflector to brake light Austin Healey 16
