TR2/3/3A Tearing Down my Free TR3 Engine
G
OK, I have managed to get the pistons out but I can't figure out how to get that split rear oil seal off. It will rotate around the crank end if I tap in the holes and the split line is showing a bit, but it won't come off. I assume I have to get this off to get the rear main bearing cap off. Any suggestions on getting the rear bearing cap off? The front cap tapped right off. Any tricks to removing this piece so I can get the crank out. So far, it almost looks as though someone just ran out of gas and parked this thing about 30 years ago. I can see no major, visible disasters, yet. I did notice that the front cam bearing flange was cracked a long time ago (well oiled crack, not a fresh break) but the cam had all it's lobes. Man, this is one sturdy little engine, looks like it would go in a tractor.
I am asking all these dumb questions because I don't have my manual yet. It is in the mail....
Bill
sp53
Hi Bill that rear seal is held in place with gasket shellac. Try some kind of acetone to break it lose. You should be able to moisten up the shellac once the bolts are off and just knock it off there. Perhaps you might prey gently. I sometimes take a rag and soak it in automatic transmission fluid and just set it on the object I want loosened for a copy of days. (Tranny fluid is relatively benign)The rear oil sealing is mostly done with the crankshaft itself. The crankshaft has a spiraling tread cut into it in the back, so as the engine runs the oil is thrown forward. The spiraling actually makes a wall in the back of the engine, so most the oil will not pass by. For those reasons, people should not park their tr3 facing up hill.
sp53
TR4
I had heard a rag soaked in WD-40 and PB Blaster placed on the bearing would loosen it up overnight. Let us know if you have any luck. I may have to do the same someday.
G TR2/3/3A Tearing Down my Free TR3 Engine/Tranny Triumph 13
T TR2/3/3A Rubber gear shift boot tearing Triumph 14
regularman Well, looks like I will be tearing into the 1500 Spridgets 22
R TR2/3/3A Engine revs up and down Triumph 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Got_All_4 TR6 TR6 Down Pipe How They Last Triumph 6
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
M MGC New book: MGCs Down Under MG 0
shadowfever Shake down run Spridgets 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
Busted knuckles TR2/3/3A Engine tear down, Triumph 13
Rut Cut down windshield Spridgets 22
S TR2/3/3A trim to hold down the furflex Triumph 3
Sopwith_Camel up or down? Jaguar 12
D TR2/3/3A stator tube will not go down Triumph 0
K Austin-Healey Fold-Down Windscreens Austin Healey 27
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
DrEntropy Diesela won't go down... Other Cars 5
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
A Spitfire Spitfire Ride Down The Mountain - Vermont Rt 100 Triumph 12
wangdango BJ8 inner battery hold down? Austin Healey 4
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G Supplier rant from down under Austin Healey 12
RAC68 Cost of Cutting Down an American Rear Austin Healey 12
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
M Hauling a Spridget - Proper tie down technique? Spridgets 15
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
PatGalvin TR2/3/3A Scraping Down Under Triumph 18
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
GTP1960 Drive down memory road. Other Cars 14
AngliaGT MGB When the MGB is Down..... MG 1
KVH General Tech Leak Down Test Triumph 17
aero3113 100 hard top with windshield folded down. Austin Healey 4
N Wire wheel hub removal & suspension tear down Spridgets 3
simon1966 BN1 Strip down well under way Austin Healey 5
mcmillal TR4/4A TR4 suddenly shuts down Triumph 25
SherpaPilot TR6 Engine Will Not Shut-Down Triumph 4
PC the fire down below Spotted 7
S Best Top Down Tune Spridgets 36
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
R Tracking down my dads old Austin Eight Other British Cars 3
healeydan Windshield Seal Won't Lie Down Austin Healey 3
Jeepster BJ8 exhaust down pipe gaskets Austin Healey 6
S rear fold down seat Austin Healey 4
HealeyRick Down East Dickering Midget Spridgets 4
jlaird Miss Agatha jumping up and down Spridgets 0
