MGB SU HS4 jet height adjustments
torque-drive
I read somewhere that the top of your jet should be flush with the bridge. Is this true, and if so, is this causing any major running issues?
Unfortunately Mickey, your link goes to the procedure for HS2 carbs. The OP was asking about HS4 carbs.
And now that I've purchased my first MGB (a 1973) I find myself in the boat as the OP.
Tim Hollister
Trout Lake, MI
Tim Hollister
Trout Lake, MI
The procedure for tuning HS4 carbs is the same as HS2.
Unfortunately due to the mechanical design differences, the physical procedure is NOT the same -- especially for someone who is very familiar with the HS2 and HS4 carbs but has never seen an HIF4 carb.
I do understand and concede the theory is the same however I have yet to find a place to use a wrench on the HIF4 carb to adjust the mixture.
Lastly, I now have rebuild kits on hand from British Parts Northwest for my HIF4's on my 73 MGB and will enjoy rebuilding, installing, and yes, adjusting these carbs so my car runs right. You see, the rear carb was running very rich and would not respond to adjustments while the front carb is fine and responds as predicted. (yes, I'll make certain the float in the rear carb really floats...)
Bob, thanks for your attempt at helping me.
Tim Hollister
Trout Lake, MI (out in the boonies of Michigan's eastern upper peninsula)
First mention the SU's in question are H-I-F4's:
Have a look at this video for a good procedure.
Specifics matter.
Thanks for setting me straight, Dr Entropy. I just thoroughly reviewed this thread and see the original misunderstanding was mine. The OP was in fact referring to HS4 carbs, not HIF4 carbs as I thought. My apologies to the group.
And thanks for the link to EndFloat's excellent HIF4 rebuild video. I had already found it and intend to use it on my iPad out in the garage over the next day or two as I rebuild my HIF4s.
Thanks again!!
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
bugedd HS4 mixture adjustment help please Spridgets 13
H General Tech SU HS4 Carb Question Triumph 5
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
dklawson Hs4 Float Bowl Failure Spridgets 11
RichBall HS2 and HS4 measurment Spridgets 7
bigjones HS4 needle mystery MG 15
mikecyc72usa Spitfire Spitfire 1500, SU HS4 major issue Triumph 14
fogliner My HS4 plumbing solution MG 13
G Setting mixture on HS4 carbs MG 30
bigjones 1500 - HS4 - improvements Spridgets 3
S Looking for hs4 aud 135r carbs MG 10
G HS4 fixed needle or spring loaded? [which is best] Spridgets 15
G HS4 carb question Spridgets 10
Gundy HS4 plumbing Spridgets 6
bigjones HS4 - quick question MG 6
G Carb floats SU HS4 on triple carb AH BT7 Austin Healey 10
bigjones HS4 - 1500 - slight problem Spridgets 24
JPSmit Quick HS4 Question MG 2
bcbug Installing a HS4 on a 76 Midget Spridgets 12
bigjones Single HS4 on a 1500 Spridgets 25
dklawson Single HS4 Conversion Troubleshooting Triumph 6
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
JPSmit HS4 needle question MG 2
JPSmit SU HS4 question MG 3
dklawson Spitfire ZS Stromberg vs HS4 SU on 1300 Spitfire? Triumph 11
Atrus Carb velocity stacks - are these HS2 or HS4? Spridgets 2
H HS4 to HIF inlet manifold question MG 2
don62 SU HS4 head jets adjustment MG 12
T Spitfire Spitfire HS4 help Triumph 11
T HS4 and HIF4 inter-carb linkages the same? MG 10
T HS4 vs. HIF4 MG 15
Atrus 1275 intake manifolds [Weber, HS4, custom] Spridgets 6
Atrus [2] HS2 vs [1] HS4 Spridgets 10
budk1953 Need a Pic of HS4's Spridgets 8
KLUTZ Properly tuned HS4's.. are they all the same? MG 6
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
RobSelina Air filter housing for HS4 [also need tuning help] Spridgets 21
mgblue79 1500 Midget HS4 conversion Spridgets 8
KLUTZ HS4 Spring count. MG 1
E HS4 SU carb inlet diameter? MG 15
Jay_Nickell SU HS4 Rehab MG 5
sultanoswing HS4 carb question MG 20
RobSelina anyone have .... [now HS4 linkage problem] Spridgets 5
RobSelina plumbing a single HS4 on the 1500 Spridgets 5
mylillooker SU HS4's "vs" Weber 32/36 Spridgets 5
P MGB Choke on SU-HS4 1971 MGB MG 4
A T-Series Switch HS2's for HS4's ??? MG 3
RobSelina Single SU HS4 swap on a 1500 Spridgets 2
