TR5/TR250 Stumped TR250 Running Rough
glemon
My TR250 has developed a bad stumble on acceleration, it starts and idles ok, but even the idle seems a little off, power is way down.
I realized I hadn't replaced most anything since I got the car done 8 years ago. So I got a new cap, rotor, plug wires, and then a coil. No difference, I replaced the carb floats today still no difference, but tried some shadetree diagnostics because it is at my mom's house and I didn't bring a lot of tools.
Anyway, spark is good on all, it jumps to the valve cover from the plug boot. But I pulled the wires one by one and it does what is supposed to for 4-6, but barely perceptible if at all change when I pull 1-3.
Seems like it must be the front carb. I check the float needle, seems fine, double check the diaphragm (TR4A Strombergs) they are fine. When I put my hand over front carb at idle plenty of suction and it stumbles.
Car was running well, but I have been getting an occasional stumble for a while, minor and very intermittent, became constant very quickly this summer, I have been in the middle of a move/house renovation and haven't had much time to devote to the problem (so I tried throwing parts at it.)
Stumped.
Not a 6-cylinder guy, but two things I always check as part of any general diagnostics or maintenance are valve clearances and timing (including timing advance at high RPM).
Just because you didn't mention it : Is there oil in the dashpots? Do the pistons move freely with the plunger out?
Randall, didn't mention it, but yes, oil in the dashpots, pistons moving as they should. Geo, I have a Pertronix in it haven't touched the timing for years, but it wouldn't hurt to check it, I need to pull the valve cover and check valve movement etc. too, also want to run a compression test. Still think the pull the plug test results are weird and a clue.
Also double checked the plug wire/firing order.
When you were checking spark, did you also pull the plugs to check their colors?
Our GT6 gets used infrequently. It is not uncommon for one or both of its carbs to develop gum and varnish deposits in the jet assembly parts... and on their needles to a lesser degree. This mandates pulling the bowls and jet parts and cleaning everything to restore proper fuel metering. When the carbs are gummed up, the engine will often start and idle OK but will not rev or it will backfire out the carbs when revved.
Glemon, give the manifold nuts a quick check next time you are at your Mom's.
Wayne
The 250 I have for sale was doing that some, it sits a lot. I screwed the jets down a couple of flats ( HS6 carbs) and it straightened out. Figured a little varnish already on needles. So maybe pull carbs piston out and check needles, if its been a while, bet the needles are black.
Marv
Wayne, I did check the manifold nuts but just a visual as I was working on the carbs. Marv, I haven't been driving it a lot but strange that the problem seemed to get worse the more I drove it. I think I need half a day I don't have right now to troubleshoot.
There is also plenty of fuel in the float bowls and I do have an original rebuilt pump, it squirts a healthy gob of combustible stuff when I hit the primer lever, I also tried putting more gas in as the tank was quite low when it started getting bad. No difference.
Nothing to add other than I've always been happy with spraying Gumout in the carb throats with the engine running. That can clean any deposits pretty quickly.
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
JPSmit Horns - I am stumped Spridgets 14
JPSmit I'm stumped - wiring Spridgets 2
Lin Name this part - I am stumped! Austin Healey 24
BJ8Healeys This one really has me stumped! Spridgets 4
KVH TR4/4A Stumped Again on Carbs Fouling Plugs Triumph 16
F TR6 starter problem...totally stumped! Triumph 9
S General Tech MIdget Clutch- Totally stumped. MG 2
S MIdget Clutch- Totally stumped. Spridgets 6
Nelson Engine dies - I'm stumped Spridgets 30
B Stumped on Electrical Issue Restoration & Tools 6
JohnnyO I'm stumped... Spridgets 11
6 stumped...engine charging...or not Triumph 12
KVH TR4/4A Stumped on Electrical Wiring--TR4A Triumph 7
JPSmit I'm stumped - headlights/ signals Spridgets 26
6 Stumped: Fuel Pump Austin Healey 7
B MGB stumped by a 74 MGB MG 11
Morris I am completely stumped! Spridgets 30
8 STUMPED AND STUMPED AGAIN Triumph 6
George Zeck I'm Stumped [Interior Panels] ...... Spridgets 7
fmichaels not stumped yet .. but Spridgets 26
M Stumped Again MG 12
S Stumped - Help! Other British Cars 12
Stewart Help Brake servo has me stumped MG 3
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
glemon Wanted TR250 Wheels Triumph Classifieds 1
conan69 TR5/TR250 TR250 seats Triumph 1
9 SOLD!! Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
angelfj1 For Sale TR3, 3A and TR250 Parts for Sale Triumph Classifieds 6
Retired2020 TR250 steering column bushing Triumph 2
Retired2020 TR5/TR250 TR250 smith gauge Triumph 7
S TR5/TR250 "New" TR250 on the horizon Triumph 0
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
C TR5/TR250 Tr250 registry Triumph 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
oldbagpipe For Sale '69 TR6/TR250 Seats now available Triumph Classifieds 0
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S For Sale Triumph TR250 Factory Workshop Service Manual on CD/ROM – 1968 Models Triumph Classifieds 0
K TR5/TR250 TR250 question [Not asking for a friend] Triumph 17
