Name this part - I am stumped!
Lin
I came across this little guy. I vaguely recall this part from my BT7 restoration about twelve years ago now. I know that I have seen it before but it is testing my memory and I just cannot come up with what it is or the purpose it serves. Can anyone help?
Thank you!
Lin
pkmh
And are there any movable parts? Or is it one solid piece.
(That poor little guy right now is having an identity crisis).
Lin
Lin
It is solid. No holes in either end. I think the heater cable stop is a good idea, but I do not believe that correctly identifies it.
Lin
pkmh
Well, since no one has figured this out yet, I'm going to approach this from a different angle. That is, instead of trying to guess what it could be (exactly), instead, studying it from a "morphological" view point (ok...maybe saying that was way too deep).
To get deeper, looking at its design, I see it as having a continuous 360 degree reveal close to the top "flange." Therefore, designed to allow a slip-on retaining clip of some kind and which can be clipped in any position, or non specific, therefore (if you get my drift). Then, a perfectly, non deviating and solid cylindrical mass, with a smaller concentric mass following. And mind you the top flange has virtually the same diameter as the rest of the cylindrical mass so having the function of being mounting against a surface as a "stop"(ie. like the choke piece on a wood dash) can be dismissed and for the reason the flange would have to be of a greater diameter for that to function). I also see the outer edge of the flange is slightly tapered--a possible valuable clue (what that clue is, I have no clue!).
Further analyzing this form, from a symmetrical point of view, it has "zero" mirror image (slicing through the form along the "X" axis, or short dimension), infinite axis' of rotation (perpendicularity, as it is called) about the "Y" axis (or long dimension). And if solid with no holes, then I believe this object had a simple function of serving as a stepped spacer and that fitted into something else.
I keep thinking this design was used in some way with a wiper motor setup or related but coming up empty.
(but the more I look at this, the more it reminds me of a piece of cabinet hardware, like part of a shelf. Maybe it had an "O" ring in the reveal).
Paul
Madflyer
That is a fun one for sure. As it has no holes not a 196. As for an O-ring slot question that. As there is little or no rub or wear I think not a pin unless on a peddle arm say brake or clutch that uses a clip not a cotter pin. I am a TR guy and it did not come from my car. Don't give up the year is still young. Madflyer
nevets
Well, since it's been 12 years since the restoration, it's unlikely that the part is critical. Maybe it's not from your Healey... maybe it's part of some tool or from your lawn mower?
My dad and I did a frame-off, nut-and-bolt restoration of a BN2/100M, and I don't recall anything like it (cable stops are the closest). But, the resto took 10 years and it's been almost that since we finished, so I could well have forgotten. It is intriguing, though.
James A Martin
It looks a lot like the piston in a fuel shut off valve placed just upstream if the fuel pump. However, I don't remember how it was moved up & down
Lin
Lin
Well, I want to thank everyone who has given this some thought. I have yet to come up with anything. Unfortunately, I did not take a photo when I found the part, but the yellow dot in the photo below (for illustration purposes only) shows where it was located. I had removed the gearbox cover to do some maintenance work and that cute little fellow was just sitting there looking at me. I am only slightly and certainly not overly concerned, but you must admit it is a strange place to find something like that.
It is conceivable that the part is from some wire cutters or something similar; However, I remain puzzled because it looks vaguely familiar to me - and it looks old, like my car and me! Oh well, we mustn't spend too much time on such things. I am sure that at the most inopportune time I will discover its purpose. Thanks again!
Lin
GregW
When I pulled the carpet up, I found a penny with the same date as the car 1967. Might be something left over from the dealer installing something?
Madflyer
As I am putting my TR6 front timing chain cover back on, how about an alignment pin of a pulley or fan? Madflyer
N MGB Name that part MG 5
Rut TR5/TR250 Name that part! Triumph 5
L Spitfire Name this part! Triumph 11
J MGB Name this part? Or , where does it go? MG 9
CinneaghTR Let's Play "Name That Part!"-Sidescreen TR Triumph 10
T Can you name this part? Triumph 19
T Mystery bracket - name this part Triumph 9
PeterK Name this part Triumph 11
SHG Name This Part Austin Healey 13
jdubois It's time to play Name That Part! Triumph 9
B Name this part... Austin Healey 9
R Can someone please name this part for me? MG 27
T Name this part! Triumph 5
pbraun Moke America lost trademark name "MOKE" Other British Cars 0
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
jlaird MGB His name MG 3
Boink MGC Name that thingy... MG 3
jlaird Name the new Miss Agatha Spridgets 1
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
Sopwith_Camel MGB a rose by any other name MG 10
K TR2/3/3A What is the name of this bracket and is it still avaiable? Triumph 4
H name and address of Jag tool seller located in Chambersburg pa Jaguar 3
JPSmit Both "spotted" and, name that vehicle Spotted 11
Basil Name this car Spotted 9
D The name is GT, Speedback GT [David Brown Speedback GT] Other British Cars 2
GTP1960 General TR Can you name this car? Triumph 9
PAUL161 General MG Do you name your cars? Why? MG 16
Bob McElwee Miss BT has a new home [probably a new name too!] Austin Healey 1
Basil Name that car Spotted 4
glemon Forum Suggestion, Lister's Name FORUM Navigation Questions 1
CJD "The Name's Bond" Triumph 7
PatGalvin Name that fuel tank? Triumph 10
B "Do name or not do name..?" MG 28
justin_mercier Can anyone name this windscreen? Triumph 3
R TR4/4A Tr4a irs, name plate question Triumph 13
JPSmit Name this car Spotted 10
aeronca65t Name This Other British Cars 16
T Name of the store with good prices on brake / clutch MCs Triumph 11
M Need a name Spridgets 20
jsfbond Name tags Triumph 0
aeronca65t Name This Car Other British Cars 14
J TR4/4A TR4A Trunk Lid name plate Triumph 3
S This is screaming my name! Other British Cars 1
S This has the name of someone here on it! MG 2
tony barnhill MGB MGB Thy Name is SSsnake... MG 43
vping Name this potential problem. MG 5
angelfj1 TR2/3/3A Name this toy TR-3A Triumph 6
newmexTR3 Name this id plate / NOS badge Triumph 6
F Name These Parts !! Triumph 5
2wrench Degree the cam....name those tools game. Triumph 54
